2023 Prius Prime Official Release - 44 miles range, 52 MPG, 220 HP, $32k
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Apr 5, 2023.
  1. Gokhan
    Gokhan Senior Member
    6,190
    2,447
    Paramount CA
    Yes, the full tire/wheel specs were posted on this forum.
    Tideland Prius likes this.
  2. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Here is the official publication from Toyota Japan.
    Gen 5 17" wheel covers | PriusChat
    The center hub is slightly larger than the Gen4. I am not sure what options are available for the North America market for the wheel change, but IIRC, PriusV 17" wheel has the same spec as the Gen5 Prius 17" wheel.
    Tideland Prius and Gokhan like this.
  3. Tideland Prius
    16,554
    Thanks!
    So this could work as winter rims or summer rims.
    Fast Wheels | Canada’s Leading Direct Fit, Performance Alloy Wheels
    It’ll stick out by 10mm or barely noticeable.
    Excellent. So once we know the weight, we can determine if the FAST wheels are worth the cost for weight savings.
  4. Gokhan
    6,190
    2,447
    Paramount CA
    It sounds like you're getting a Gen 5 Prius Prime PHEV. ;)
  5. Gokhan
    6,190
    2,447
    Paramount CA
    One additional detail is that the reservoir blue is also available for the Prius Prime PHEV.
    Sarge likes this.
  6. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Yeah I kind of worded that wrong. I should have said, "as an option it's cheaper than the panoramic glass roof option on the XSE".
  7. Gokhan
    6,190
    2,447
    Paramount CA
    Another interesting observation:
    Solar roof and advanced park/panoramic-view monitor (PVM) are not compatible with each other.
    The options and packages on the XSE Premium are indeed complicated.
  8. Hammersmith
    Hammersmith Senior Member
    2,315
    2,340
    North Dakota - USA
    2023 Prius
    Limited AWD-e
  9. Tideland Prius
    16,554
    Haha. I already have an EV.
    In Canada, that’s Maximum Yellow. :D
    That’s hot
    Gokhan likes this.
  10. Hammersmith
    2,315
    2,340
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    My perfect world will be a set of Michelin Pilot Sport A/S 4 on the stock 19" wheels, and a set of Nokian Haakapeliitta R5 in 205/55R17 on the WingDancer XX 17" wheels.
    Right now the closest Pilot Sport A/S 4 is a 225/45R19, which is a bit too wide to be comfortable, but a guy can hope.
  11. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    L2 charge speed is miserable. Is battery pack still cooled by cabin airflow?
    hill likes this.
  12. bisco
    51,895
    excellent question, as someone claimed it was liquid cooled before any information had been released
  13. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Look at post #20
    @Danny already got answers from the head engineer
  14. bisco
    51,895
    Post 20 is wheel sizes
  15. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Tideland Prius and bisco like this.
  16. bisco
    51,895
    found it, thanks!
  17. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    So no 120V power port in the Prime? :(
  18. Gokhan
    6,190
    2,447
    Paramount CA
    Yes, Prius Prime can be used as a backup battery or generator for your house.
    Terrell likes this.
  19. hill
    8,800
    Wonder how many amps can be pulled, 100% duty cycle versus a limited duty cycle.
  20. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    The XSE and XSE Premium have two 1500W 120V outlets. One in back of the front console for rear passengers and one in the driver's side of the cargo area, also 1500W 120V, so about 12.5 amps max for each outlet, but I'd plan on closer to 10A if used continuously. The one on the rear of the front console looks like its a 2 prong while the one in the cargo area is 3 prong. Not sure what the SE is set up for, maybe just one outlet.
