2023 Prius Prime Official Release - 44 miles range, 52 MPG, 220 HP, $32k
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Apr 5, 2023.
  1. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    Check the manual. The total from both can't exceed 1500W. You don't get 3000 W.
    "●With these power outlets, use
    devices which operate on 120
    VAC and have a combined maximum
    power consumption of 1500
    W or less. If a device is connected
    and the power consumption is
    exceeded, a protection circuit may
    be activated and the power supply
    function may be stopped."
    drash likes this.
    51,895
    sounds like it's still coming out of the 12v :(
  3. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Do you know if the SE trim has a single 120V outlet or the same two?
    Obviously both outlets are coming out one inverter as @Tom_06 pointed out.
  4. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    That's great! (I wonder why the 1500W inverter is not mentioned in the Prime's Specs on Toyota's website?)
    The Prime Owners Manual here:
    https://assets.sia.toyota.com/publications/en/om-s/OM47E73U/pdf/OM47E73U.pdf?_gl=1*izu7dp*_tmna_ga*MTg2OTEyNzY1MC4xNjgxMDk4MTgx*_tmna_ga_EP43E5EFVZ*MTY4MTE4MjUzMC4yLjEuMTY4MTE4Mjk5Ni4xNS4wLjA.
    starting on page 468 there are a lot of instructions about using the 1500W power outlets, such as "Do not refuel or wash the vehicle while using the power outlets." :LOL:
    There are two outlets: 1) behind the center console in the rear seat area, and 2) in the luggage compartment.
    While using the power outlets, the key fob will not operate, nor the alarm system. You can lock the car with the physical key.
    #44 Terrell, Apr 10, 2023
  5. Maxwell61
    Maxwell61 Active Member
    392
    241
    Italy
    2024 Prius Prime
    XSE Premium
    I can't find the gen 5 on Epa.gov, can you clarify if those numbers are for the non-Prime FWD or AWD or Prime?
    Danny report a combined 52 mpg for the Prime and i guess is for the SE 17".
    Can we deduce that the Prime XSE 19" is at 48 mpg?
    A complete resume for the FWD, AWD, Prime would be great.
  6. Trollbait
    12,520
    The 2023 Prius Prime still isn't up on Fueleconomy.gov, but is at the US Toyota site. The numbers Gokhan posted were just for the old and new Primes. No AWD option for it at this time.
    Xse and Maxwell61 like this.
