Featured 2023 Prius Prime PHEV debuts with 220-hp engine and 40-mile EV range
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, Nov 16, 2022.
  1. bwilson4web
    16,204
    All this advocacy for slow AC charging and no fast DC has worked. My curiosity matches the AC and DC charging rates.
  2. Gokhan
    Gokhan Senior Member
    6,194
    2,452
    Paramount CA
    Fast DC charging reduces the battery life with the current lithium-ion battery technology. You will soon find out in your Tesla when you need a $20,000 battery replacement. ;)
    Lightning Racer and Prashanta like this.
  3. Gokhan
    6,194
    2,452
    Paramount CA
    It should be at least as efficient as Gen 4
  4. reallyreal
    reallyreal Member
    71
    61
    Italy
    2024 Prius Prime
    IMHO, unless the price of rodium, palladium, and platinum falls back to normal, a cat stolen may mean much more than something occasional like a drilled gas tank to steal petrol or a shattered glass to steal a jacket, because it's deliberate and methodical. Yes, you can mount a shield, even an alarm with tilt sensor, yet they give you no guarantees, just mild deterrents.
    I'll take as example my case. Relatively small city, found the cat was stolen in my job's parking lot. It was too late to call the insurance guy so no free towing that night, had to ask a lift from a family member to get back home. In the about 2-6 weeks in which you're stranded, you can shell out 3K to replace it with OEM, which is the only one that guarantees you will pass the mandatory emission tests. Or, you may buy one from China for cheap and have it soldered, knowing the next fumes check day is the deadline for your car. Or, you can find a good non-OEM maybe and have it soldered for half the OEM price, and your best chance of passing emission tests is crossing your fingers and hope the lower amount of rare earth metals inside will still be enough to keep emissions below the law thresholds. Maybe make a hour-long trip on the motorway with the engine constantly on to get the cat well hot before going in for the tests, it will maximise its efficacy. Except you probably won't reach that day, because in x seconds your new cat can be stolen again from your job's parking lot or wherever. Repeat the loop ad infinitum.
    So for me, until those prices come consistently back to earth, cars with a palatable cat are a no-purchase from the start.
  5. Gokhan
    6,194
    2,452
    Paramount CA
    It could be the same charger in the 2023 Prius Prime.
    Tideland Prius likes this.
  6. Tideland Prius
    16,555
    Most likely. That’ll be 0.5C. Well within reason for Toyota’s long battery warranty.
    drash and Gokhan like this.
  7. Trollbait
    12,531
    Level 1 and Level 2 use the same onboard charger. Level 1 is mostly limited by the outlet supply, but faster than 3.3kW charger can lead to improvement. The gen2 Volt went faster to keep Level 1 charging time around that of the gen1.
    In Level 2, the limit is the onboard charger. The current Prime can't make full use of a 40 amp EVSE.
    Has Toyota released details on the charger or charge time, cause none of the reports I've read mention it? Except for the quote of no time released yet that I quoted earlier.
    Which is my point. The Rav4 Prime with larger battery can have always benefited from a faster charger, yet Toyota chose to equip it with slower for the US market. Maybe the new Prime will have a faster charger, or maybe Toyota will decide that it getting a full charge at Level 1 in 8 hours is good enough.
    So, is Toyota not putting fast DC charging into the Japanese Prime?
  8. bwilson4web
    16,204
    After 86,000 miles over three years, the 8% battery degradation matches my expectations.
    By the time I’m ready for my next Tesla there will be better batteries, more efficient, and lower cost inflation adjusted. After all, it is a 2019 Tesla Model 3 Std Rng.
    So there are no changes in the 2017 Prius Prime we traded in for the Tesla?
  9. hill
    8,803
    Let's hope not. If SOME want/need faster charge speed / they are off put if they can't get it. If you don't need it but get it anyway? Good for resale for those looking for it!
  10. Gokhan
    6,194
    2,452
    Paramount CA
    Is that a typo? Do you mean there is nothing that didn't change?
    If you had a Prius Prime Limited now, you would be trading it close to $40k as opposed to the current $20k trading price of your Tesla. By the time you trade it in, it will be worth only $10k. And you would have paid $20k for the Prius instead of $50k for the Tesla.
    Your total cost of opting for a Model 3 instead of a Prius Prime Limited: $50,000. ;)
    #70 Gokhan, Nov 17, 2022
  11. bwilson4web
    16,204
    Not a typo, I understand the more recent Prime may have improved. The same is true with Teslas. Most adults expect product improvement. For example the Prime greater EV range. Yet our 2014 BMW i3-REx has more EV range, 30 A L2 charging and CCS-1 fast DC charging. The Prime still trails our 2014 BMW and not even in the same class as our 2019 Tesla Model 3.
    No problem as our Tesla is working as expected. In another ~15,000 miles, the last warranty will expire. So I’ll drive it until the wheels fall off. Or is that someone else’s EV.
    Our first Prius achieved 175,000 miles before the brake booster failed. Located between the firewall and engine while wrapped by the air conditioning tubes, it was impractical to repair.
    #71 bwilson4web, Nov 17, 2022
  12. Trollbait
    12,531
    Where are you getting those figures?
    KBB trade in value outside Philly for a 2019 with 60k miles in very good condition:
    Prius Prime Advanced; $24,821 - $27, 205
    Model 3 SR+; $27,171 - $30,551
  13. davemo
    davemo Junior Member
    29
    Iowa, USA
    Good points.
    Agree those are options, but the Corolla Cross Hybrid seems a step in the wrong direction for taxi fleets (at least in terms of climate impact), as the MPG is estimated (no EPA mileage as far as I know) at 37 combined. The Camry LE Hybrid would be closer to staying even, but I don't see them in taxi fleets. I see Prii (although the plural is Priora, but that seems to be the common plural used). Arguably most in my area are Gen3 with some Vs, and few Gen4s, so maybe the the days were already ending for the Prius as a key part of taxi fleets).
    #73 davemo, Nov 17, 2022
  14. davemo
    29
    Iowa, USA
    One of the issues facing Toyota on this is that touting "And Now Harder to Steal Our Car's XXX!" is probably on the Marketing 101 list of "Things to NEVER Tout in Your Marketing Material!" somewhere down the list from "Now With XX% Fewer Fatalities!"
    You can picture the development team meeting after the engineers present the their great new idea on making it harder to steal the CAT and are surprised when they are told by marketing: "that was a great job folks, now we'll never speak of it again."
  15. bwilson4web
    16,204
    Just curious:
    One kWh gives 4-5 miles.
    #75 bwilson4web, Nov 18, 2022
  16. We had a bunch of thieves steal cat converters from Hondas close to where I work. It's not just Toyota. Basically, anything that uses palladium, rhodium, and/or platinum is a theft target because of the bullion/precious metals market.
  17. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    I'm betting like all the generations before it, if you don't want metallic you get black, red, or blue. I'm also willing to wager a small amount that Toyota's going to ditch the LE or equivalent and try and capitalize on people being forced to pay extreme prices these days.
    Some thieves stole so many catalytic converters from one of our lots that they stole TWO trucks to transport the stolen catalytic converters.
    "Around town" in any metro area easily exceeds 40 miles, usually more than 40 miles in any one direction. I run out of charge every single day that I've owned a Prius.
    #77 PiPLosAngeles, Nov 18, 2022
  18. Gokhan
    6,194
    2,452
    Paramount CA
    Unfortunately, in California, EV driving doesn't save you much.
    I get 70 mpg on Prius Prime. The gas is $5.40 a gallon. So, it costs $7.70 per 100 mi.
    I get 33 mi per 7 kW in EV driving. The electricity is 30¢ per kWh. So, it costs $6.40 per 100 mile.
    If I drove 12,000 mi a year, I would save only $160 a year.
    The problem with BEVs is depreciation. Your Model 3 will be worth only $10,000 in two years. You paid $50,000 for it. $40,000 depreciation in five years is not something I can literally afford and does not justify saving $810 in fuel costs. Buying a Tesla is a moot issue for low- and middle-income people because they can't afford it.
  19. bisco
    51,899
    can i find a 5 year old model 3 for 10k?
  20. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    wait so $40,000 depreciation in two years or five years? either way that seems off, i’d have a used tesla or similar by now
    drash likes this.
