2023 Prius (prime SE) headlight aimed low. Adjust?
Discussion in 'Gen 5 Prius Main Forum' started by tmorrowus, Oct 1, 2023.
  1. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    It's page 451 for the headlight adjustments. Pretty short and pretty vague. That's going to require some trial and error.
  2. tmorrowus
    tmorrowus Member
    514
    Yes, it was p. 542 in my prime manual. The instructions were pretty hard to understand, but I think I figured it out with daylight. There are two screws on each side, one reached by plunging a screwdriver downward through the hole, and another hole right next to it which requires plunging a screwdriver on a steep diagonal toward the front of the car. The diagram is confusing because it shows the A and B adjustment screws far apart, which they are, but the access holes (not on diagram) are right next to each other. I had to get my extra long screwdriver for the latter because a standard 6" Klein PH2 wouldn't reach.
    I have never had any success adjusting headlights against walls; I always find it comes down to adjust, drive, repeat.
  3. CooCooCaChoo
    962
    544
    Cow-lee-fornia
    2023 Prius
    Ah, LE manual is different then.
  4. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    I adjust against my garage wall. Prior to adjusting, I put some tape at the top line of the low beam and then adjust incrementally from there. It doesn't take much to make a noticeable difference on the road.
  5. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    Interesting the difference in DIY maintenance detail between manuals, looking at Japan v Europe v USA.
    The Japanese don't get an "engine compartment" section - the section is replaced with only "refilling the washer fluid". They're not trusted to do anything else in there.
    The Europeans aren't told how to aim headlights, but are otherwise authorised to do all the same as the Americans. Could be regulatory, or it could be that that aim is specific to the non-AHS lights, or that the AHS lights would fight back if you tried adjusting there. (You certainly see them do an up-and-down seek operation at every start-up, as if hunting for calibration).
    tmorrowus likes this.
  6. BiomedO1
    BiomedO1 Senior Member
    4,636
    2,434
    Left Coast
    The last time I adjusted the HID's on my GMC, I used my neighbor's Corolla. She parks on the street, so I aimed it just below her trunk deck. That way, I know I'm not blinding anyone - I've got high beams for that....:D:LOL::ROFLMAO:
  7. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    @tmorrowus, here is the million-dollar question: Does Prius Prime SE have a lighting taillight bar?
  8. tmorrowus
    tmorrowus Member
    514
    Afraid not. The part in the middle does not illuminate.
    Gokhan likes this.
  9. Gokhan
    6,715
    2,672
    Paramount CA
    Thanks, that is unfortunate.
  10. patmine23
    patmine23 Junior Member
    2023 Prius
    I'm a bit late to this party but I also am not a fan of the headlights on this car. Coming from a 2015 Corolla which had amazing headlights, I had assumed that these on this 2023 would be that much better. Sadly they weren't even close. I'm not sure if they are aimed too low or there isn't enough overall lighting. Meaning the beam is very sharp and doesn't have very much "light bleed" (not sure the correct term) that highlights a bigger field of view. Has re-aiming them helped with this issue?
  11. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    It helps. You just need to make sure that you don't raise to the point that ongoing drivers start flashing you.
