2023 Prius Prime - Share Your EV Mode Range, Rate
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by tovli, Jul 13, 2023.
  1. Zyrian
    Zyrian Member
    49
    32
    ATL
    2023 Prius Prime
    SE
    11.6kWh from the grid on Level 2 to get 10.6kWh into the battery sounds about right. But with XSE wheels and with climate control anything over spec is great.
    Ignore the Toyota app to the tune of completely, though.
    PrimeDan likes this.
  2. wstt
    wstt Member
    148
    26
    What are the highest ranges, or highest miles/kWh, you have heard people get when they were driving at lower speeds, and weren’t driving downhill or on highways?
    I have a 2021 RAV4 Prime XSE. It’s supposed to get 42 miles of range on its approx 18kWh, (approx 14kwh EV mode), battery. I live in Hawaii, where it’s mostly low speed and flat areas. I can normally average 4.5 per kilowatt hour, or about 58 to to 60 miles of range. (In fact after a full charge my dash used to show 60 miles EV range). My vehicle is much heavier than a Prius prime. I’m wondering in ideal conditions, flat, low speed, but not cheating (meaning not downhill) what the best numbers people are getting for stats for the Prius Prime as I’m considering one for my wife.
    Thanks.
  3. Trollbait
    12,831
    The new Prius Prime has a range around that of your Rav4P, so it should get about the same as the Rav under the same conditions.
  4. Eagle2024
    Eagle2024 New Member
    Carson City, NV
    2024 Prius Prime
    In low speed (<45 mph) driving around town with no hills, just typical traffic lights and stop signs, I'm getting a range of about 50 miles on a full charge, which is about 11 kWh. The Prius Prime battery capacity is 13.6 kWh. The usable EV only range is a bit less. Highway driving, with hills and aggressive merging is getting me about 36 miles EV only on a full charge. I have a 2024 XSE Premium.
  5. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    It's not really the best time of year to compare best EV range from HI to the mainland. Summer EV range is typically higher, until it gets too hot and heavy A/C usage brings max EV range back down for many. owners.
    Only way you're gonna know for sure how good or bad the Prius Prime is compared to your Rav4 Prime is to drive it the same way you're currently driving the Rav.
  6. wstt
    wstt Member
    148
    26
    I know recent time of year is an ideal for ranges in cold environments. That’s why I’m asking Not what people are getting now, but just what the best they have heard that people can get, or have gotten in terms of range.
    vvillovv likes this.
  7. Zeromus
    Zeromus Active Member
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    Well the last few days its been above 10C and I went from getting around 55-60km with winter tires and some use of the hvac to now having done the same daily commute twice this week which would drain almost all the charge, to having 30% left on the capacity meter over the same distance. Before changing my winter tires/steel wheels back to stock I may add. I have the 17 inch wheels if that provides context.
    I also havent run hvac at all since its so mild and comfortable out, which I am sure makes a big difference as well.
    With the stock all seasons back on (bridgestone Ecopia where I live) with the aero covers, I suspect range will improve a little more again.
    The car's kwh/100km went from averaging around 16.5 to 13.5 too. Which is a change equivalent from 3.75mi/kwh to 4.6. So quite nice.
    Only a couple day's driving but the temperature change is very very apparent in its impact and just makes me happy again that we chose a PHEV over a full EV given the fluctuation which I had heard before could be quite large.
  8. wstt
    wstt Member
    148
    26
    What’s the distance of your commute and how much range (km or miles) does it show is left when you get home now? And what speed is most of the drive done at? Mostly flat driving? Thanks.
  9. wstt
    wstt Member
    148
    26
    Did your drive finish at the same elevation as you started? Meaning was it downhill overall?
    When you're getting 52mi of range what is the mi/kwh it says you’re averaging?
    I just got an XSE premium, 1 year old, (the recall in April messed up my new purchase), and after a few days driving I was expecting more range and higher m/kwh.
    I have a RAV4 prime, where I get 60 miles range regularly (42mi is Toyota advertised), bc most driving is slow, flat, 79° l, and I have owned Prius before and know how to max mileage. I thought I’d be able to take the new Prius to 60 miles too and just seeing the miles/kwh I’m getting, I see it’s not likely possible. I’m trying really hard and only getting 4.6 m/kmh. I was hoping to get 5.5, maybe 6. (All driving < 45mph, a little a/c, temp 80° outside.
  10. Will B
    Will B Active Member
    454
    419
    Denver
    2023 Prius Prime
    XSE Premium
    Here in Denver I can reliably get about 50 miles of EV range on my PPPXP (Pretty Prius Prime, XSE Premium with the not-so-efficient tires) on nothing but round trips (no altitude change). My record is 57. Even though I'm "in the plains", there is still a lot of altitude change leaving town and it is amazing how much of a difference it makes. Heading out of town south and uphill about 1500 feet and usually 65-ish MPH I only get about 35 miles of EV range. If I head north which is mostly downhill (maybe 1000-ish feet) and slower through the city highway speeds I can get 55+ miles of EV range. If reasonably temperate I prefer the windows down for in-town driving and then close the windows and use the fan for highways. Getting the car to just "blow air" and not use AC took some figuring! :)
    will
  11. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    #91 Maxwell61, Oct 2, 2024
