2023 Prius Product Information
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Dec 14, 2022.
  1. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Attached you'll find the official PDF from Toyota with official specs on the engine, battery size, MPG, chassis, tires, measurements, features, packages, options, and warranty. I'll break it out into some web-friendly tables in the next few days.
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I guess, have to wait a bit longer to get information on the Gen5 Prius Prime.
  3. Trollbait
    12,822
    The US is only getting the 2.0L engine?
  4. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    So no 120V 1500W power outlet on the Prius? Perhaps only the Prime?
    And wow, the higher grades take a big hit on mpg. (Extra weight? Extra height from bigger rims?)
    • 57/56/57 (LE FWD)
    • 52/52/52 (XLE/Limited FWD)
    • 53/54/54 (LE AWD)
    • 49/50/49 (XLE/Limited AWD)
    #4 Terrell, Dec 14, 2022
  5. Mendel Leisk
    42,343
    Here we go, from danny's attachment:
    The way this is presented, seems they're not to proud of it? At first glance a bit of a head-scratcher, that (as usual) only the base level has a spare. When you look at the vehicle weights you see their logic, though it seems short-sighted to me:
    LE is a bit of a stripper though, short list of deletes I care about:
    No Smart Key (borderline deal breaker)
    No Auto-dimming rearview mirror with Homelink (I'd miss this)
    No Softex upholstery or steering wheel (a plus in my estimation)
    ^ Am I missing something; these two are the same??:
    More'n likely the units are feet:
    #5 Mendel Leisk, Dec 14, 2022
  6. MalachyNG
    MalachyNG Active Member
    304
    227
    Northern NY
    2022 Prius Prime
    The auto on and off headlights on the higher trims
    LE only auto off like previous years
    Tideland Prius and Mendel Leisk like this.
  7. christiandflores
    christiandflores Junior Member
    26
    San Diego
    How did it gain so much weight while adding almost nothing of value?
    Current eco is 3010 and xle at 3075
    the le is at 3097 and xle at 3164
    the limited awd weighs almost as much as an m3 e46. But that's old performance engineering
    daisy555 likes this.
  8. fsu23phd
    fsu23phd Active Member
    186
    114
    Wilmington, NC
    Ok, so the ground clearance didn't shrink, that's good.
    The cargo space did. I can barely get 2 28 inch suitcases into my 2016 2 Eco. Has anyone tried to put suitcases in the 2023 hatch?
    I'm on the fence. I've had 3 Priuses, and I'm ready to replace my 2010. I'm really tempted by the Kia Sportage Hybrid and the Rav4 Hybrid, but wait times are long (I'm guessing the Prius will be the same). :) Decisions decisions.
  9. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Beefed up suspension, steering and brakes to accommodate the extra horsepower?
    moto g power ?
  10. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    I think the bigger tires. They add a lot of weight, perhaps. Plus, they raise the car up higher, and lower the mpg.
  11. theRob
    theRob Active Member
    103
    119
    2023 Prius
    Anyone have any idea when the new Prius will start shipping to dealership’s?
  12. WesleyRiccipio
    WesleyRiccipio Junior Member
    103
    24
    The added height apparently has little to do with mpg (to an extent) from what I’ve researched here. Are the tires any wider? If so that has major impact.
    side note: does anyone know how the cubic feet of space compare for the trunk or rear area? I really want the 2023 Prius to be a great car for making into a camper..no back seats with a bed platform. But sadly, the gen 3 looks like it will have more cubic feet of space.
  13. Rmay635703
    Rmay635703 Senior Member
    2,699
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    I foresee a lot of 215/55r17 energy savers selling in 3-5 years
  14. Trollbait
    12,822
    Sounded like the inverter was only on the Prime from earlier release. Power out systems were only available for the plug in on past Japanese models.
    The MPG difference is mostly from the weight difference between the wheels. The larger wheels add weight to the worse place on the car for efficiency and performance.
    In addition to the braking and suspension, there is weight from the bigger wheels, and bigger engine. Isn't the 2023 also a little bigger overall?
    Frontal area is an important metric for aerodynamics. Motorcycles have a worse cD than semi trucks, but their tiny frontal area compensates for it. Lowering a car will help with aerodynamics. Aero just doesn't have a big impact if all the driving is low speed.
    The tires are both 195mm wide. Wheel weight alone is enough to explain the difference. It is in line with the difference people that switched wheels have seen, and the difference between the Camry hybrid LE and higher trims.
    Took a moment to spot the headlight difference. The LE being auto off likely means the light sensor for auto on is deleted.
  15. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    This video from Toyota USA clearly shows the 120V 1500W power port at 6:00 in the video, but not a word is said about it, nor which build levels will get it:
    Toyota also has this video for the Prime, which shows the 120V 1500W power port at 3:48. Also no mention about it.
    #15 Terrell, Dec 14, 2022
    Sarge likes this.
  16. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    The 2010 Gen 3 is rated at 51/48 with a combined of 50. So I'm not very impressed with the 2023 mpg for the higher grades. And the Prime will get...?
  17. Arcoril
    Arcoril Junior Member
    Southern California
    I haven't seen any mention of the video recorder feature in the PDF or any of the reviews. I wonder if support was quietly dropped.
  18. Trollbait
    12,822
    Those videos were very likely pre-production units. What features they have may not make it to production.
    Toyota and others have been deleting some features due to parts shortages. An inverter could have been intended to be available, but it isn't something Toyota is going to delay the launch for if parts are scarce.
  19. WesleyRiccipio
    103
    24
    Same. Decades of R&D and this is what they make? Maybe less advertising spend is needed lol.
    at first I liked how it looked because it was different. Then I realized no it’s not they’re just copying designs from other cars..this thing looks like a $25k Chevy in the front and a dodge in the back lol.
    sigh
  20. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Why am I so interested in the 120V 1500W inverter, which shows up in various videos, but goes unmentioned by the commentators (including Toyota)?
    Well, camping, for one. Rice cooker, small microwave, etc.
    And... this morning at 4:20 AM, due to heavy, wet snow, a huge pair of branches fell from our white pine directly onto our power lines and ripped them right off the house! We were without power for nearly ten hours. During the power outage, I ran our freezer, router, internet, phones, security system, and computers off of a 1kW inverter in my Prius. So having a Prius with a 1500W inverter system would be a nice option. Hopefully all those videos that show this 120V power port in the back next to the USB ports isn't just marketing stick-on labels! There's even a picture of a special window insert which allows the power cord to run out the window without letting the rain in.
    It's in the videos. But I've seen no mention of it in materials nor heard anyone in the videos mention it. So???
    Sarge, daisy555 and bisco like this.
