2023 Prius Product Information
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Dec 14, 2022.
  1. WesleyRiccipio
    WesleyRiccipio Junior Member
    103
    24
    Glad you guys are ok! That’s very resourceful to be able to use the Prius as a mobile power station. Very cool.. I put a 3000w Renogy inverter in the back of my gen 3. Fun
  2. Trollbait
    12,822
    In Japan, the Prius Prime had an optional widget that was a power off inverter that plugged into the charge port. The new model having an inverter isn't surprising. The window insert and mention of it were from the Japanese unveiling, so it may never leave the island.
    The 120V and 230V label showing up in pictures and video implies Toyota plans to offer it on exported Primes at some time. Or someone felt a label was better than leaving a blank button for the demo cars. If it is something Toyota is serious about, my guess is that they haven't sourced the parts to have it available on launch. Even then, it still may be Prime only.
  3. Rmay635703
    Rmay635703 Senior Member
    2,699
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Did anyone mention the growing problem (CDA)
    “Perhaps surprisingly, the new Prius is not more aerodynamic than the old one. Toyota claims a drag coefficient of 0.27 compared with the old car’s 0.24. Dimensionally, it’s 1.1 inch longer, 0.9 inch wider, and between 1.8–2 inches lower than before, depending on trim level."
    model464 likes this.
    52,843
    what's the problem?
  5. Rmay635703
    2,699
    1,729
    2013 Chevy Volt
    They made the Prius into a Ford c-Max which will likely make the “highway number “ optimistic and unfortunate
  6. model464
    model464 Junior Member
    27
    23
    Colorado
    2023 Prius Prime
    SE
    I noticed. I have to wonder what's responsible for that - the longer hood? No disrespect to the engineers, but I don't really think an aero compromise was necessary for the styling, given the truly beautiful cars that get 0.24-25 these days (e.g. Sonata Hybrid). I was expecting something in the low 0.2s, which would've been a point over the Camry. Now the two are closer to neck and neck for me.
    WesleyRiccipio and JoeBlack like this.
  7. Trollbait
    12,822
    The crude frontal profile of the gen5 is a little smaller than the gen4. The CdA increase could be less than the Cd implies.
    Toyota could have cut belly pans for weight and cost. I think that was the Insight2's issue, and its Cd was 0.28.
  8. model464
    27
    23
    Colorado
    2023 Prius Prime
    SE
    I hope not. I like belly pans. But that's a relatively simple crude DIY fix for anyone who actually cares.
  9. WesleyRiccipio
    103
    24
    Exactly, it’s bullshit. Everything looks the same.
  10. Tideland Prius
    16,678
    I mean, it has an extra inch of ground clearance so that’ll play a role too. Sure, the roof is lower to compensate but there’s still more air underneath.
  11. Prashanta
    Prashanta Active Member
    292
    242
    Technology
    Has Toyota disclosed the maximum tire size? I imagine going too wide would be problematic.
  12. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    Why? That would reduce MPG compared to the stock 195/60/17 Bridgestone Turamza ER300 Ecopia.....
  13. Mendel Leisk
    42,343
    Are they comparable OD? If so, maybe more readily available?
    Rmay635703 likes this.
  14. Rmay635703
    2,699
    1,729
    2013 Chevy Volt
    Instead of $250/tire They are common and cheap.
    Walland clearance was $50 a tread the last time I bought a pair.
    Given this size will only be on the Prius you won’t get any selection, very much like the BMW I3
    Considering there could easily be less than 25,000 examples on the road for several years
    Identical revs per mile if you choose the right Tire brand.
  15. Gokhan
    Gokhan Senior Member
    6,714
    2,661
    Paramount CA
    Great information, thanks! I am looking forward to the Prius Prime information.
  16. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    Well, Page 4 of the Quick Reference Guide shows a 120V AC outlet on the front dashboard. It disappears a few pages later and becomes the 12 V "cigarette lighter" outlet.
    #36 Tom_06, Jan 3, 2023
