2023 Prius Questions Thread: Let's see what I can get answered
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Nov 30, 2022.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,160
    566
    Alberta
    2024 Prius Prime
    XSE
    I think BMW has a better idea, having one wide display, instead of two separate ones on the Prius.
    I'm a big guy, but I manage to fit when I lower the seat all the way and move it back.
    The center console opens up, but I wish there were more storage room.
    There are two USB-C ports on the front dash, one is marked for data and one for power.
    reservoirblue likes this.
  2. Mendel Leisk
    41,486
    Our eldest son is 6'-7"; I'm 5'-11"ish. On the few occasions he's driven our 3rd gen, it's comical the next time I hop into the driver's seat, like falling into a pit. Think Pappy Yokum...
    douglasjre and GcinFl like this.
  3. midcow2
    midcow2 2023 Prius LE Supersonic Red
    Houston
    2023 Prius
    Okay m but what does Gen3 have to do with Gen 5 size ?
  4. Zeromus
    Zeromus Active Member
    553
    307
    Ottawa Canada
    2024 Prius Prime
    SE
    I think he's saying the seats move and can be quite accommodating in general. He was just relating to the whole "seat pushed back and lowered down" comment, not everything needs to be hyper specifically about the Gen 5 models :p
    ukulelegeek likes this.
  5. Sharol
    Sharol Member
    161
    76
    Kansas, USA
    2023 Prius
    The seats adjust even more in the gen5 I think. My husband isn't terribly tall, but his torso is longer in proportion than his legs. He couldn't get comfortable in my 2012, but he really likes the gen 5. Not sure why, but it seems to have more adjustability.
    ukulelegeek and Mendel Leisk like this.
  6. reservoirblue
    reservoirblue Member
    95
    76
    Woodacre, CA
    2024 Prius Prime
    SE
    I appreciate the split displays with the most relevant info in the traditional position straight ahead. I'm 6"1 and fit comfortably, no issues with roof height.
  7. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    Just bought the car on Saturday and I noticed even when I carry the smart key fob, I cannot open the trunk directly without pressing the open button on the keyfob, but only the front door?! Is it the setting or ???
  8. bisco
    51,973
    it may be that the le only has one door sks. should be on the window sticker
  9. Trollbait
    12,543
    If one door SKS, I believe you have the settings to everything unlocking with the driver's door. Then touching that door handle should be enough to unlock the hatch.
    Winston Smith likes this.
  10. Mendel Leisk
    41,486
    They have to punish base model buyers somehow. Th
    Yeah, the fob can either unlock just the driver's door, or all doors. The function can be switched by owner. Commencing on page 113 of North American Owner's Manual:
    otatrant and Humble Bear like this.
  11. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    Thank you Mendel Leisk for your help.
    Yes, you can set to have the driver door open only or all doors. I changed to all doors, but I still have to touch the door or press the remote before I can open the hatch. I cannot open the hatch directly when I want to load the groceries I bought. Thanks anyway.
  12. bisco
    51,973
    that sounds correct. you need 3 door sks for that.
  13. Mendel Leisk
    41,486
    Always seems to me like Toyota was looking for some way to “punish” buyers of the base model. Maybe not the best descriptive, but it feels like it.
    douglasjre, Trollbait and Sharol like this.
  14. Trollbait
    12,543
    Pretty much. The base Maverick doesn't have cruise control. The old ways of doing so(manual windows, no radio) might cost the manufacturer more these days.
  15. bisco
    51,973
    don't all companies do that? what options should be left off in lower end models?
  16. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    Are you able to roll down the side windows with the keyfob? Owner's manual says this setting must be customized by the dealer (p113). I texted my salesperson and he said it's not available on the Prius...Has anyone been able to setup this feature?
  17. Sharol
    Sharol Member
    161
    76
    Kansas, USA
    2023 Prius
    Very interesting. Now I'm wondering about my husbands new 25 Camry. He likes that function, I don't ever use it so it isn't a issue.
  18. bisco
    51,973
    you may want to ask your questions in one of the other gen 5 threads. more people may see it as this one was danny's when gen 5 first came out.
  19. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    I live in Souther California and weather sometimes gets up to 110, so I use that feature a lot in my Q5 before getting inside(even hotter inside).
  20. SFPhoto
    SFPhoto New Member
    SF Bay
    2023 Prius
    I read on another forum that a 2023 Prius owner purchased:
    Used Camry alloy rims, options were
    205/65R16
    or
    215/55R17 but there might be a clearance issue
    douglasjre likes this.
