2023 Prius Reviews
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Dec 14, 2022.
  1. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    samsprius1 and mikey_t like this.
  2. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Wow! Already? ;)
  3. Tideland Prius
    16,681
    52,858
    eek, the clubs that fit in gen4 won't fit in gen 5? that's regression.
    that was a nice comparison of the rear view, gen 5 looks better. interesting how the hatch glass appears to go higher on gen 5.
    DogDaze and Tideland Prius like this.
  5. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    Some screen shots. :)
    :ROFLMAO:
  6. bisco
    52,858
    beauty is in the eye of the beholder
  7. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    The Edmunds review officially lost me when he mentioned the gen 5 suspension upgrades and then proceeded to say with a straight face that with the last generation “whenever you would go over some kind of bump in the road it felt like the car would shake and it was going to fall apart
    That’s some over dramatic BS if I’ve ever heard it. And the only price I believe he quoted was for the Limited edition. No mention of the LE being about 10k less.
    GcinFl, Tightwad77, scona and 3 others like this.
  8. prius16
    462
    246
    New England
    2022 Prius Prime
    Fwiw, just about every media review is 99.999999% pure BS, with barely any hint of truth.
    As for me, I'm going to buy the highly rated, by Edmunds, 2016 Prius. :)
    :D
    Code:
    https://www.edmunds.com/toyota/prius/2016/review/
    2016 Toyota Prius Review
    Edmunds' Expert Review
    by the Edmunds Experts
    Pros
    notably quieter and better-riding than past iterations
    Edmunds says
    Look no further than the 2016 Toyota Prius if fuel economy is what you're after. But you'll also enjoy more sophisticated ride and handling qualities and a quieter powertrain.
    2016 Toyota Prius Review & Ratings | Edmunds
    Edmunds says
    Look no further than the 2016 Toyota Prius if fuel economy is what you're after. But you'll also enjoy more sophisticated ride and handling qualities and a quieter powertrain. Going green with a Prius has never been better.
    Pros
    Outstanding fuel economy
    generous cargo space
    significantly improved driving position.
    As for the car's underlying architecture, a lower and wider stance combines with the new double-wishbone rear suspension to improve the car's ride and handling. Bumps are now more readily absorbed, and the steering's added heft is reassuring. This new Prius is still not speedy or all that exciting to drive, but there are far fewer failings to overlook. It's a pleasant car to drive in its own right.
    With these refinements, the Prius also has fewer peers than ever before. Honda has shelved its slow-selling Insight, and no other automaker is attempting a Prius rival. At this point it's a matter of size, mpg, configuration and, yes, styling. Is the 2016 Prius hatchback big enough, or do you want the extra passenger space of a midsize sedan that has a trunk? If so, the 2016 Ford Fusion Hybrid or the 2016 Toyota Camry Hybrid might be worth a look. If a plug-in hybrid is more to your liking, the redesigned Chevrolet Volt is pretty impressive. But for a regular hybrid, we highly recommend the 2016 Toyota Prius.
    o_O o_O
  9. TinyTim
    TinyTim Active Member
    418
    243
    Seattle
    My biggest complaint about the new Prius. The Prime version should be standard and it should be able to get 50 miles on all battery. In the winter months that would mean 30-35 miles of electric in cold climates. I think AWD should be standard as well. Honestly with BEV vehicles. The Prius Prime should be the base trimline on the new Prius. Other than that, it looks good.
    Dimitrij likes this.
  10. Trollbait
    12,830
    We did have a Volt available for a bit.
    AWD reduces efficiency, and thus EV range. The electric versions are better than mechanical, but they still have an impact measurable in EPA testing.
    Tightwad77 and Prius blog like this.
  11. Sue Case
    Sue Case Junior Member
    89
    44
    Maryland
    2023 Prius Prime
    Sorry to bust your bubble but if you get the Prime XSE or XSE premium you're only going to get 32 miles on battery power, if that. But I bet in cold winter areas that number drops to below 30 miles, say from November to March.
    Sadly it appears that the Prime mid to upper trim levels will get no where near 38 miles on battery power. Still like the looks of the 2023 model but when you factor in
    Only 28 to 32 miles on battery power (depending on time of year)
    No spare tire
    Low ceiling/head clearance issues
    Above average noise level
    Poor rear view (mirror) viewing
    Odd tire size
    etc.
    The exterior hype starts to fade along with buyer interest. Hybrid is big improvement over previous year models, but doesn't seem to match up well with 2023 competition.
  12. bisco
    52,858
    people get 40 now, i don't think 50 is unreasonable
    Tightwad77 and ukulelegeek like this.
  13. Tideland Prius
    16,681
    Jesus, aren't you a negative nelly?
    Have you ever driven a plug-in vehicle? Here's my Prime with a lowly 25 miles of range. By your logic, this should be IMPOSSIBLE :rolleyes:.
    I squeeze almost 40 miles out of a "25 mile certified" vehicle.
    Pretty sure if I had a Prime XSE, I'll be able to get closer to 50 miles in the spring/fall.
    You're right though. It won't get 38 miles in the winter. Most likely, it'll be 25-30 miles but how's that different from a gas car that gets better mpg in the summer and worse in the winter? My 2010 got 550 miles of range in the summer and 400 miles in the winter.
  14. Sue Case
    89
    44
    Maryland
    2023 Prius Prime
    Just saying that the "pumped 38 miles per battery charge" is a moving target/number. And mostly a moving "down number". as you add more weight to Prime, drive upper trim models and drive in cold weather.
    Saying 38 miles on battery charge but then getting 30% less driving year round, is a big difference to me. Of course I'm not talking the base trim level which I now think is the best of the three trims. So long leather seats.
  15. Tideland Prius
    16,681
    Of course. It was never mentioned that was the exact number. It said "up to 50% more" and frankly on the base SE, it was more than 50% over the Gen 4 Prime.
    As with any car, adding more weight reduces efficiency, acceleration, worsens braking distance etc. Adding a larger engine reduces range even further but people were fine going with the V6 option over the 4 cylinder or the V8 over the V6.
    It's just that with more highly tuned efficient cars like the Prius (and EVs), these changes are amplified.
    I went from the stock 20" cast alloys to 19" flow-formed alloys and even on winter tyres, my efficiency soared because of the significantly lower unsprung weight (15 lbs per corner, 60 lbs total unsprung weight loss). My range went from 312 miles to 362 miles just by changing the wheel size and losing weight (despite having winter tyres).
    douglasjre likes this.
  16. priusmouse
    priusmouse Member
    255
    85
    Long Island, NY
    2023 Prius
    Ther reviews seem favorable. I wonder if the websites will rank the new Prius above other hybrids like the Hyundai Sonata/Elantra, Honda accord/insign hybrids, perhaps Corolla/Camry hybrids as well. I have always been a little puzzled why those other hybrids were getting better reviews than the Prius tho..
    ukulelegeek likes this.
  17. priusmouse
    priusmouse Member
    255
    85
    Long Island, NY
    2023 Prius
    both of these are very welcome!
  18. Mendel Leisk
    42,349
    I wonder if Toyota cherry-picks reviewers.
    douglasjre and ukulelegeek like this.
  19. Trollbait
    12,830
    Without delving into examples, my guess is the Prius uniqueness works against it with most reviewers. Relative newness could also be a factor.
    I'm sure they all do for the initial wave. These release events are invite only.
    ukulelegeek and Mendel Leisk like this.
