2023 Prius Reviews
Discussion in 'Gen 5 Prius Main Forum' started by Danny, Dec 14, 2022.
  1. Exerted
    Exerted Member
    110
    100
    2023 Prius Prime
    Close your eyes, @Gokhan!
    Downrange likes this.
  2. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    So, he is saying that no matter how you sit, you can't see the gauge display. This was my impression when I sat in the bZ4X. :(
  3. Preebee
    Preebee Senior Member
    898
    783
    Midwest
    2026 Prius Plug-in
    SE
    The only person that can't LEGITIMATELY see the portion of the gauges that you're supposed to see, would have to be extremely tiny - to the point where raising the seat all the way up doesn't help. In 99% of the "can't see the cluster" cases, it's user error, or just being uncomfortable with the HUD styling (looking over instead of through the wheel). And like anything else, you'll get used to it quickly.
    I don't even have the steering wheel in a low position. In fact, I think I have it higher than I did in my G4.
    My only issue is I have to be very careful when I get into the car. Take my time and sit down into the seat before turning around or I will bump my head. But I used to bump my head sometimes getting into the G4 as well. Definitely a bigger risk bumping the head on the G5. An "inconvenience" I'll gladly take in exchange for the incredible pride of ownership.
    tovli likes this.
  4. GeoJ
    GeoJ Active Member
    225
    203
    United States
    I have no problem with the gauge over the steering wheel. You can easily adjust the seat to be comfortable and see the entire gauge with room to spare - I like it! I am not that tall, 5'8- 5'9 (depending on the day). And, no problem getting in and out - guess I'm just an athlete;). I still have some concerns about buying the first year of a completely redesigned car, but this review actually makes me feel like perhaps it won't be a problem given how he emphasizes it is in many respects not a "new generation" because so much is taken from known and tested stuff. I am very glad to know that the hidden compartment is labeled as such, something I did not realize. I do wonder, with the complexity, if I will ever be able to take this car for repairs to anything other than the Toyota dealer. Also wonder whether there will be issues with the coolant lines running back to the hybrid battery. And wonder about the catalytic converter getting stolen, although seems like the lower clearance actually may help on that issue. And, one of the comments on this review speculated whether there might be a safety issue with the placement of the gas tank. Yikes! hope not.
    tovli likes this.
  5. Exerted
    Exerted Member
    110
    100
    2023 Prius Prime
    No problems seeing the gauge once correctly set. Hurry and join the Gen5 family already
  6. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    I’ve been waiting for this review!
    hill likes this.
  7. Exerted
    Exerted Member
    110
    100
    2023 Prius Prime
    Anything Toyota related, he's the one I'm always looking forward to.
    daisy555 likes this.
  8. daisy555
    1,729
    716
    CT
    Seat all the way up and steering wheel in my lap. That’s me. Still searching for suitable wedge cushion. : ) Does anyone have time to measure the dimensions of the seat? I’m searching. Are dimensions posted online? I recall someone saying the seat is shorter than standard seats but it’s mostly width I’m concerned about. Thanks!
    #328 daisy555, Jul 15, 2023
  9. Preebee
    898
    783
    Midwest
    2026 Prius Plug-in
    SE
    2023 Toyota Prius Limited – Review by David Colman +VIDEO
    "Right from the get-go, this beauty scored a solid 10 in the appearance department. In Limited form, with its Op Art alloys and ultra short sidewall 19-inch rubber (195/50R19 Toyo Extensa A/L), the new Limited is stunning. Finished in "Cutting Edge" silver, the Prius Limited that landed in my driveway is a sure sales winner. None of the great Italian design houses (Ghia, Pininfarina, Bertone) could have surpassed the refined beauty of this show-worthy product from Toyota. Study the sweep of the side sculpting, or examine how elegantly the rear door handles have been blended into the C pillars. Not a line is amiss. Even when you partially lower the windows, the outline of the lowered glass perfectly matches the contours of the upper and lower body side character lines. Blissfully simplified front and rear valances transform what once was the mongrel of the Toyota fleet into a stylistic purebred.
    The elation continues once you climb into the comfortable, logical, and simplified cockpit. In Limited trim, the supportive front and rear seats are all heated, as is the steering wheel rim. The Limited boosts the standard Prius' 9-inch Multi-Media panel to 12.3 inches. Toyota situates an additional 7-inch Multi-Information Display panel directly in front of the driver, displaced nearly a foot forward of the steering wheel. This positioning puts it more clearly in your line of sight than a normal instrument binnacle's location. It's like having a head-up display without the fuzziness of window refraction."
    tovli and daisy555 like this.
  10. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    355
    277
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    From my tailbone to the front edge of the seat measures about 19 3/8 inches (lumbar support fully retracted).
    With the seat in the maximum height position and the steering column at the lowest height position, if your seat to eye measurement is over 24 inches you will be able to fully see all info on the Multi-Information-Display. With this combination, my legs touch the bottom of the steering wheel when entering/exiting but not when seated.
    daisy555 and bisco like this.
  11. bisco
    52,876
    i was surprised to see the car care nut criticize the screen placement without trying to adjust the seat and wheel
  12. daisy555
    1,729
    716
    CT
    Thank you so much for these measurements! My seat to eye measurement is exactly 24 inches. Entering and exiting with the wheel touching my legs would drive me nuts. Hopefully a wedged cushion might help with this.
    A red or acidic blast Corolla Cross Hybrid is starting to feel really appealing. Time will tell.
    tovli likes this.
  13. hill
    9,041
    That guy's voice is like fingernails on a chalkboard.
  14. Preebee
    898
    783
    Midwest
    2026 Prius Plug-in
    SE
    My seat dimensions in the LE are as follows: 19.75 in. deep, 20 in. across. Seat back height = 25 in. Headrest is 12 in. from top of seat back to top of headrest.
    If your seat height is at the highest position, you will NEVER have the steering column at the lowest IMO.
    #334 Preebee, Jul 17, 2023
  15. daisy555
    1,729
    716
    CT
    Thanks. When I referred to seat being shorter than average I meant depth. Thanks for including the width. Helps with deciding on seat cushion.
    Preebee likes this.
  16. Tideland Prius
    16,683
  17. Preebee
    898
    783
    Midwest
    2026 Prius Plug-in
    SE
    They were absolutely dumbfounded trying to find something bad to say about the Prime. :ROFLMAO:
    Just maybe a wee bit too expensive for what you get - especially when you can have 90% of the Prime in the normal LE.
    Canadians are getting a helluva "deal". If you want to call tax funded subsidies a deal... :whistle:
  18. Preebee
    898
    783
    Midwest
    2026 Prius Plug-in
    SE
  19. daisy555
    1,729
    716
    CT
    Ok…I could listen to James talk about cars all day long.
    Thanks for this entertainment on a stressful day. Now they need to get a move on with production! :LOL:
    tovli, Tideland Prius and Preebee like this.
  20. Tideland Prius
    16,683
    Throttle House has interesting reviews. There’s a bit of entertainment in there but not as brash as Jeremy Clarkson.
