2023 XLE rolling malfunction VSC stability control not detected
Discussion in 'Gen 5 Prius Technical Discussion' started by Diane Stachowski, Nov 29, 2024.
  1. Diane Stachowski
    Diane Stachowski New Member
    CA
    2023 Prius
    Anyone experiencing random rolling malfunction warnings for VSC and stability control not detected while driving?
    Dealer replaced 12v battery twice in 1 year - but still getting warnings
  2. Trollbait
    12,829
    What exactly is happening? Are just the lights coming on? If a brief interval, that could just be from the systems activating normally.
    Is there anything plugged into the OBD port?
  3. Diane Stachowski
    CA
    2023 Prius
    Rolling warnings along with 2 red icons appear randomly on the screen. Nothing is plugged in.
  4. Diane Stachowski
    CA
    2023 Prius
    No error codes even while the warnings appear
  5. Gorgonzola
    Gorgonzola Member
    42
    28
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    To clarify, is actual warning text appearing on the screen that states “VSC not detected” or is it simply the VSC indicator light flashing briefly as if there was a loss of traction? And you have so far replaced the 12v battery twice trying to address this specific issue? Thanks for clarifying
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    I would say check to make sure fuses are firmly in place.
    Gorgonzola likes this.
  7. Diane Stachowski
    CA
    2023 Prius
    This is the exact wording:
    VSC turned off
    Pre Collision Brake System Unavailable
    Traction Control turned off.
    Note that this is random and no buttons on the console were touched.
    Dealers cannot find error codes even while malfunctioning. Because they could not replicate the malfunction I drive to the shop while it appeared in my screen.
    They replaced 12v battery twice and tild me the last battery was sulfated. Car is 1 year 3 months old
  8. Trollbait
    12,829
    Could be a loose wire.
    Maybe a computer is rebooting.
  9. Amcrump
    Amcrump Junior Member
    Gaithersburg, Maryland
    Not sure this is the same thing but sometimes when it’s really cold out I’ll get a similar alert.
