2023 XSE Prius Prime with electrical issues
Discussion in 'Gen 5 Prius Technical Discussion' started by Amcrump, Dec 18, 2024.
  1. Amcrump
    Amcrump Junior Member
    Gaithersburg, Maryland
    My car is currently at the dealer because this morning it was malfunctioning and wouldn’t start. Lights were rapidly flashing, alerts on the dash display going off etc. it was 7:30 EST time. Turned car off, locked it and plugged it in again to see if it would reset itself. Checked it 35 minutes later and it started and worked fine. Dealer info try and get it to do it again tomorrow morning. Anyone else have a aimilar issue?
    52,839
    12v battery maybe, many are having issues
    Danno5060 likes this.
  3. BiomedO1
    BiomedO1 Senior Member
    4,587
    2,408
    Left Coast
    That sounds like a bad or low 12VDC battery. Have the dealer load test the battery and have them look for parasitic draw on the battery. It's a common issue on the Gen5s.
    Hope this helps...
  4. Amcrump
    Thanks.
  5. Amcrump
    Thanks. I’ll send this to the dealer.
  6. BiomedO1
    4,587
    2,408
    Left Coast
    Forgot to mention, there are also TSBs on this issue - so the dealer knows your not blowing smoke....
