2024 Headlights/ bulbs
Discussion in 'Gen 5 Prius Main Forum' started by longshot, Feb 7, 2025.
  1. longshot
    longshot Junior Member
    84
    16
    Anyone know what is the Headligt bulb type in the 2024 Prius? And are they LED
    daisy555 likes this.
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    The headlights are LEDs and they are a sealed unit. If a bulb goes out, the entire thing has to be replaced.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    But the LEDs should last the life of the car if they are properly engineered.
    Some manufacturers deliberately over-drive them to make them fail prematurely.
    At least that's what I've learned from watching Big Clive's YouTube channel.
  4. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    Sounds like a pricey replacement. What about the red tail light along the back of the Prius? Thanks
  5. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    LEDs Gen 4 Prius had one replaceable bulb in the back, not sure if it is the brake light or blinker. Primes tail lights are all LED for Gen 4, I'll assume the same for Gen 5 Prime as well. You'll have to wait for a Gen 5 owner to confirm of debuke that assumption. And maybe a Gen 5 Prius owner can confirm if there is still one replaceable bulb in the tail light assembly clusters.
  6. daisy555
    1,729
    716
    CT
    Thanks. I’m going to give the parts department a try too although I’m typically correcting them on their misinformation. : /
  7. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    My Gen 3 had both LEDs and incandescents. The only bulbs that needed replacing were the incandescents.
  8. PriusCamper
    PriusCamper Senior Member
    13,466
    5,433
    Pacific Northwest, USA
    Reminds me of all the promises I've heard about how LEDs last forever and now that most street lights have been converted to more efficient LEDs there's more street lights that are out than there were back when they didn't use LEDs.
    Classic Toyota quarterly profit at all cost routine to make a headlight casing that doesn't allow you to change the bulbs "because they're LED will last forever." What a joke!
    #8 PriusCamper, Feb 9, 2025
  9. CooCooCaChoo
    962
    544
    Cow-lee-fornia
    2023 Prius
    I had my 2017 Two Eco for 6 years I think. The headlights were never replaced. I wouldn't hesitate to trust the LEDs on a Toyota.
    Now, other brands, however, I wouldn't dare do the same. I've seen brand new domestics with already burned out LEDs that need to be replaced. I've even seen luxury versions of their vehicles burn out early.
