2024 Prius engine on lock car from outside
Discussion in 'Gen 5 Prius Technical Discussion' started by Kakarot, Oct 11, 2024.
  1. Kakarot
    Kakarot New Member
    Usa
    2024 Prius
    Hello guys, does anyone know how to modify with GTS+ or techstream to be able to let the car idle with all 4 doors locked while being outside of the car? No i dont want to use the key blade to lock the door
    52,817
    what happens if you roll down the window, leave the fob on the seat, get out and lock the door, reach in for the fob and hit window up?
  3. Kakarot
    Kakarot New Member
    Usa
    2024 Prius
    Thats seems like a good idea for a regular person that does it once a day or once a week, unfortunately i work off my car i go to 5-10 clients a day
  4. ChapmanF
    18,999
    Careful, if that works, you may still need to use the key blade to get back in. If your reason for not wanting to use it is you're not sure it works, that could be problematic.
  5. Prodigyplace
    12,711
    11,848
    Central Virginia
    i believe Toyotas with the Remote Start option can do that,
  6. Kakarot
    Kakarot New Member
    Usa
    2024 Prius
    The keyblade option work is just not practical or fast as walking away and pressing the lock on the remote. The toyota remote start is not valid for my operation
  7. purplePriii
    purplePriii Active Member
    275
    123
    Kakarot likes this.
  8. purplePriii
    275
    123
    Link 2:
    can't seem to put two links int he same post. I'm not sure it'll work on US models or PHEVS but there's options. Would be +-$80 USD shipped to the US from Amazon but might be able to find it in other places.
  9. Kakarot
    Kakarot New Member
    Usa
    2024 Prius
    Super nice wow big big thanks i can open link one ur second post i cant not see the link see if you can out the second link
  10. Kakarot
    Kakarot New Member
    Usa
    2024 Prius
    Possible put this second link is not showing up the first link amazon wont let me login from japan is weird
  11. purplePriii
    275
    123
    You might need to create a new Amazon Japan account?
    Second link doesn't want to work here no matter what I try so:
    https://www.amazon. co.jp/-/en/gp/product/B0C5WW9NRX/ref=ox_sc_act_title_4?smid=A2NG5VQGXX5T5Y&psc=1
    remove the space between amazon. and co
    or search:
    PRIUS 60 , Can Be Locked Even While Engine-On Idling Door Lock Function, Switchable, Coupler On, Easy Installation
    Small harness with mainly purple wires.
    Do check you have the connector in your car for the install. From the reviews, seems to work fine for Japan but no one has tried it in North America yet.
  12. Kakarot
    Kakarot New Member
    Usa
    2024 Prius
    Thanks big time yea it will work on usa cars its just a jumper harness on the lower connector of the Body Control Module
  13. Kakarot
    Kakarot New Member
    Usa
    2024 Prius
    Harness arrived works like a charm you can hop off the car without turning it off ac blasting cold, touch the lock pad on the door handle and she closes thanks guys
    daisy555 and purplePriii like this.
  14. purplePriii
    275
    123
    That was fast! Thanks for doing an update!
    How much did it end up costing?
