2024 Prius LE alloy wheel cap
Discussion in 'Gen 5 Prius Main Forum' started by Eduardo Vallado, Dec 2, 2023.
  1. Eduardo Vallado
    Eduardo Vallado New Member
    Jacksonville, FL
    I want to remove the plastic wheel covers. But need a wheel center cap. Will appreciate if anyone has already sourced a good one to use. The outside diameter is 63 mm.
    I was told cap 42603-48140 would fit but is too small
  2. wrtboy168
    wrtboy168 Member
    70
    29
    Northern California, USA
    2024 Prius
    either one of these should work.
    42603-06160
    42603-42170
  3. Eduardo Vallado
    Jacksonville, FL
    Thank you so much, 42603-06010 worked perfectly
    I got 42603-06160 and it worked very well. THANK YOU
    wrtboy168 likes this.
