2024 Prius Limited AWD Range Questions
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by Stephen Lance, Jul 23, 2024.
  1. Stephen Lance
    Stephen Lance New Member
    Ohio
    2024 Prius
    Limited AWD-e
    We have had our 2024 Prius AWD Limited for 6-months and have one major issue. We are seeing a range of about 350 miles total. The MPG is 44 and the advertised capacity is 10.6 gallons. Something doesn't add up. On average, we see 359 miles per tank and are only able to put in 8 gallons. Even with that, the low gas light is usually on and range is usually between 10-20 remining miles. Based on my experience, I would suggest that the tank capacity is more like 8.5 gallons. We have contacted Toyota and shared a log of every fill up for the last 12 tanks (all consistent). They have not offered a solutions. I am interested to see if anyone else has this issue. Thanks!
  2. Tideland Prius
    16,680
    Toyota typically reserves 8-10 litres (2-2.6 gal) of fuel when the low fuel light comes on.
    You can typically run 60-100 miles beyond the light if you dare. I use my fuel consumption, round it such that it makes it worse and then use that as the calculation. E.g. you say you're getting 44mpg. Round down to 40mpg so when the light comes on, there's 2.6 gal but again, round down to 2 gal. 40x2 = 80 miles. You can run 80 miles with a buffer (assuming no large change in driving style or temperature or terrain etc) beyond the low fuel light.
    bisco and Winston Smith like this.
  3. fuzzy1
    10,707
    Based on my experience, that matches the "safety margin" built in to the low fuel warnings of my past 2010 and 2012 Prius, and current 2024 RAV4 Prime. And is similar to the warning lights or just 'needle on E' gauges of most of the other-brand cars I have driven over the past half century.
    Here is what your Owner's Manual shows, but my experience is that my OMs have understated the margin, the actual margins have been higher, like you have found and what Tideland describes:
    MPG is far more variable than many drivers realize, depending on conditions: engine warmup status, load, temperature, rain, snow, wind speed and direction, mountain slope, external cargo carriers, etc. And the car has no way to forecast what conditions it will encounter just ahead. So most car makers put in some safety margin on their low fuel warnings to save most drivers from their own miscalculations and MPG ignorance. If the 'miles remaining' gauge truly reflected average driving conditions, then numerous drivers will get caught short on the below-average days or trips, leading to many angry calls to Customer Service with complaints like "the miles-remaining gauge said I had enough miles left to get there, but then it ran out of gas and left me stranded on a dark and stormy night [ in the middle of nowhere | far up the mountain pass road | in a blizzard | in a place with no cell service to call for roadside assistance ] ."
    Building in a traditional amount of safety margin goes a long way towards reducing those angry calls to Customer Service. It won't stop all drivers from running out of gas. But for those who still do run out, the gauges and warnings will have been lit long enough for them to understand that they can blame only themselves, not the car maker.
    This is just one form of 'Customer Expectation Management'. There are additional forms of it built in to most cars these days.
    #3 fuzzy1, Jul 24, 2024
    Gorgonzola and Stephen Lance like this.
  4. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Sounds about the same as mine. My average fill ups on the light are 8.5 gal. I typically fill right when the light comes on but I feel like its usually stating higher than 20mi left at that point. I pushed it and ran the estimated range down to 1 mile last week. Tbh I didn't think about checking how much I put back in at the time.. I think Tideland is correct with the reserve quantity based on other Toyotas I have owned.
  5. Hammersmith
    Hammersmith Senior Member
    2,486
    2,544
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I get about 350 miles of displayed range in the winter(which is really about 400 miles including the safety margin), and the displayed range gradually increases to almost 450 miles by mid-summer(550 miles with the safety margin).
  6. fuzzy1
    10,707
    I pushed my 2010-2012 Prii past 0 miles numerous times, the farthest being about 60 miles past. Based on the refill quantity, it still had nearly a gallon left.
    Another 2010 owner (I'm currently not naming for reasons not relevant here) intentionally ran that Prius (and a previous one) out of gas many times, for a wide variety of engineering and fuel and other tests, reporting many technical findings back to us. In his tests for Gen3 range (and for discovering its fuel starvation behavior), he went a bit over 130 miles past the Low Fuel warning light, which lit up about 25-30 miles before Distance To Empty fell to 0 miles.
    Other drivers beware: that was a different model year, he drove at moderate speeds with better MPG than many of today's freeway speeds, took along a spare can of fuel, and carefully selected the time and area and circumstances where he'd run out of gas. Don't tempt fate by running low in circumstances where running dry would be inconvenient or worse.
    Later, I ran my Subaru all the way to actual fuel starvation, and found its refill quantity dead-on its claimed amount (when rounded to the nearest tenth of a gallon). Though its low fuel warning lights had a bit less safety margin, and its Distance To Empty gauge had no safety margin. Fortunately, its earlier low fuel warning stages were more glaring, multi-colored, and harder to miss that the Prius warning.
    #6 fuzzy1, Jul 24, 2024
  7. BiomedO1
    BiomedO1 Senior Member
    4,598
    2,412
    Left Coast
    I'm routinely at 0 MTE (miles to empty) when I fill up. I've actually ran my car from South Lake Tahoe back to Sacramento once (90+ miles). The low fuel indicator came on just as I crested the summit. Normally I wouldn't worry about it, but I had 2 adult passengers onboard. It was mostly down hill on the way back that gave my traction battery a chance to recharge. When I eventually refueled, there was still a 0.75 gallon in the tank, when I did the math. I was joking with my passengers, that they've have to get out and push, they pointed out every gas station we passed on the way back down the mountain. :D
    The computers can only give you estimates - you need to make your own guesstimate under real life driving conditions. I would've never attempted the above in winter or wet driving conditions.
    #7 BiomedO1, Jul 24, 2024
  8. Hammersmith
    2,486
    2,544
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I try not to take it down near 0 MTE just because I don't want to put extra wear on the fuel pump. The pump uses the gas in the tank to keep the housing cool, and running the tank near empty can cause it to overheat and prematurely fail.
    That being said, Toyota makes some of the most robust OEM fuel pumps, so you're not going to kill the pump running it near empty every now and then. But getting in the habit of keeping it near empty and only filling the tank partway up is a recipe for damage. And the side effect of the Toyota pumps being so well built is that they're pretty darn expensive* to replace. So best practice is to always fill all the way up, and try not to let the tank drop much below 1/4 or 1/8 tank(roughly 3-4 gallons).
    *I think I'm looking at the correct part, and it's $520 MSRP for just the pump, and $550 MSRP for the whole pump/gage assembly.
  9. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Hi Steph, The fuel gauges are only one set of gauges in the newer Prii (plural for Prius) that confuse many new owners. There are many gauge set in the car that work together. You're not the only person to ask about the fuel and estimated miles to empty gauges. There are many posts asking how they work and what to expect form them.
    Stephen Lance likes this.
  10. sclevine
    sclevine Active Member
    170
    160
    Northeast Florida
    2024 Prius
    Whenever I refill close to 0 MTE, it usually takes about 9.2 gallons.
    Your MPG is on the low side and perhaps that is because you drive a lot of fast highway miles? When I have tanks like that on long highway road trips, I find that when I fill at 0 MTE it takes even less gas, more like 9 gallons or even less. If that is your case, mostly fast highway miles, just a guess on my part, but maybe the computer does an even worse job of calculating MTE.
    (Note: My Fuelly tag below is broken - I have 61 fill-ups currently in my 2024, not 1!)
  11. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Legendary folk tale there. I'll agree though that this was a thing, but more so on the real old stuff. Previous gens of Toyotas for example had the venturi bucket pump assemblies with brushed motors. The returned fuel sprayed into the bucket where the pump lived. The returned fuel also siphoned gas into the bucket assembly. On my truck which I ran down quite often the pump had some apparent heat discoloration on the pump body so I have no doubt in my mind it was getting warm.
    The newer pumps are brushless , and the system return-less. They only run as much as is commanded by the ECM. They aren't under nearly as much load as a constant pressure pump, and the brushless motors are inherently far more efficient and durable.
    Out of curiosity I did some googling to see what the Prius pump looks like. Take a look at this monstrosity. o_O
    The pickup filter being right on the bottom looks like it will be very pretty effective at getting the last of the fuel from the sump in the tank. Compared to other fuel pump assemblies the float also seems to go right down to the bottom of the pump as well.
    I've got to give it to you all, I thought I was being brave running it down to 1mi to empty. TBH I haven't really had to push it that far before but I knew there would be a lil extra in there. It's good to hear people are having success with pushing the limits. (y)
  12. fuzzy1
    10,707
    Note also the more than 7300 foot descent from Echo Summit to Sacramento. That was worth probably 35-40 extra miles, compared to a level route.
    I wouldn't have tried it with passengers either.
  13. BiomedO1
    4,598
    2,412
    Left Coast
    that's what I was counting on. I was half way through my HV battery when I hit the summit. On the way back, I was able to get the Prime pack back to 80% SOC with the addition 300-400 pounds - but it discharged quickly on those up hill legs. Just a matter of timing and avoiding slow moving traffic, so I don't break the cars momentum and chew too deeply into the traction battery. I've made this run on many occasions.
    Besides, I had two pairs of hands that can push; if I ran out of gas.:D:p:ROFLMAO::whistle:
  14. Stephen Lance
    Ohio
    2024 Prius
    Limited AWD-e
    Thank you everyone for the great responses. There is a ton of useful information and I am still planning on taking this up with Toyota as it feels like 25% reserve is just too much. I had a 2008 Prius that would never have gone past 0 as it regularly took ~11.5 gallons on a 11.9 gallon tank when low.
    We do a lot of freeway miles and the 44MPG is not worrisome, but with long trips the short range is painful. Overall, it appears that this is consistent with what others are seeing and most people seem to be accepting of this. I think I will put a 5-gallon tank in the back next time I try to go past 0. :)
    vvillovv likes this.
  15. Winston Smith
    Winston Smith Active Member
    476
    339
    OH
    2024 Prius
    LE AWD-e
    When I fill my Corolla in summer, the range will typically show at 525 to 535 miles. As miles accumulate on the odometer, the range will typically decrease about 30% faster than the odometer increases. By the time I am to around 400 miles, it's close enough to indicated empty to refill, and I've onl;y gone that far a few times.
    462,3 miles refilled with 10.35 gallons
    459.8 miles refilled with 10 gallons
    470 miles refilled with 10.5 gallons
    With a 13.2 gallon tank, this indicates an enormous fuel reserve below "zero range".
  16. dolj
    dolj Senior Member
    8,645
    4,396
    Wellington, New Zealand
    Gen 2 (2008) does not have an MTE gauge, so what do you mean by this? If you were using the flashing last pip as the "0" indication, you still would have had 50 to 75 miles (depending on driving style and conditions) to actually empty.
    If that is the case you consistently had 0.4 gal to 0 gal left in the tank when you filled. Pretty good considering the fuel bladder and all its issues.
    Maybe, given your Gen 2 experience, you need to reshape your concept of what MTE means in a Gen 5.
  17. Hammersmith
    2,486
    2,544
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Driving at or above 80mph sure kills your gas milage. Lol
    I normally take my time while traveling, but it was better to make my trip to Chicago as quick as possible. I've averaged about 41mpg on the trip back facing a headwind. I think the trip there was a little better since I had a headwind, but I had the screen on navigation, so I wasn't watching mpg.
    (I've been getting 50-60mpg this summer on regular drives.)
    SM-S901U ?
  18. MDell240
    MDell240 New Member
    Rainier, OR
    2024 Prius
    LE AWD-e
    You are right on point. My 2024 le awd gets 40 mpg freeway and 44 highway. If i drive like a grandma i get 2 more mpg. Toyota is a corporation... they only care to sell a car. Toyota is way over hyped... my 2001 civic got 36 mpg. Seems a corolla or camry hybrid is a better bet these days with better or similar economy. Too many duct taped prius's on the road (cheap build). Im super disappointed and wont ever buy another.
    I think your point got jacked and turned to range over economy.
    I think the epa is at fault for allowing such a lie about economy. The EPA deserves a class action lawsuit for 10 mpg over rating of these cars. Once again... super disappointed. Mine only has 7k on it. I'm ready to have a car i like more.
  19. Winston Smith
    476
    339
    OH
    2024 Prius
    LE AWD-e
    MDell, are you sure there isn't something wrong with the car? Do you have the tires correctly inflated?
    I have the same car with the same mileage and my worst tank to date was 47.88mpg, which included single digit temps and snowy commutes.
  20. vvillovv
    4,337
    1,519
    NY
    my 02 civic ex also got 35 local 40 hwy for it's first 100k miles, alot like our 06 civic mx for it's fisrt 110k miles (dealer serviced) got 45 mpg. lifetime and 69.9 high for a 55 mile trip. One outliner over a 100 on a 1/2mile run back from the gas station, a teaser just seein how that happened.
    There are ways to get mileage from a hybrid, the thing is, the driver has to know how, cause if they are driven the same way as most all gassers are driven these days, the mileage is gonna by disappointin.
    40's is not uncommon at freeway speeds and some members here are reporting 80 -90 mph commutes, then 2 liter, well you wanted a prius sport and that's what you got with Gen 5.
    But there are members here that know how to drive them hybrid beasts already, but they're not commuting on the freeway either.
    good luck gettin into the car you're
    gonna like more.
    #20 vvillovv, Mar 6, 2025
