2024 Prius Prime PHEV High-Voltage Battery Build
Discussion in 'Gen 5 Prius Technical Discussion' started by RandyPete, Mar 5, 2026.
  1. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    John Kelly of Weber State posted this video of Gen 5 Prius Prime/PHEV battery R&R, disassemble and reassemble about 11 months ago. I could not find a post on this subject here in PRIUSchat so Here ir is.
    Excellent information !
    Gokhan and VelvetFoot like this.
  2. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    No interest in this subject/video ?
  3. BiomedO1
    BiomedO1 Senior Member
    4,562
    2,394
    Left Coast
    It's still under factory warranty - why would anyone mess with it and potentially void their warranty????
  4. ChapmanF
    18,999
    Prof. Kelly's videos are usually great for understanding how your car is built and works. That's of interest to some owners, even if they're not going to tinker with anything right away.
    RandyPete likes this.
  5. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    Exactly my interest.
    Learned a few things about the Gen5 Prius Prime Battery.
    -it uses 12v power to warm the battery.
    <Big edit here>
    -The battery cells have the same dimensions and pole/vent features as prismatic cells used in first Prius Prime (Gen4) batteries.
    I already knew much about the High Voltage battery, as mine was replaced under warranty in July 2024. Leaky refrigeration line in battery.
    Always interested in the hardware and software in the vehicles I drive.
    #5 RandyPete, Mar 12, 2026
  6. ChapmanF
    18,999
    Not by a long shot—maybe you were distracted when that part went by?
    The early Prius generations used "modules", of a prismatic shape, where each module consisted of six NiMH cells (you couldn't take a module apart—non-destructively, anyway—to separate the six individual cells). They weren't exactly the same across all generations: they changed for gen 2 (at least) to get the dimply metallic sides, and different internal connections between cells. They were close enough people sometimes interchanged them.
    The battery in this video is made of big Li-ion single cells, each one of a prismatic shape. The shape is the only commonality with the early Prius battery modules.
    He did say, though, if I remember right, that the cell he held up in his hand came out of "the first-generation Prius Prime" (italics mine). The first-generation Prime is a very different animal than the first-generation Prius. :) And he did say while the dimensions of the cell are the same, the terminals are a little bit different.
    #6 ChapmanF, Mar 12, 2026
    Brian1954 and RandyPete like this.
  7. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    Thank you for correcting my misunderstanding of Mr. Kelley's comparison of the Prismatic cells and that the Gen1 was not compared. The first Prius Prime gen (I think Gen4 Prius Prime ). I will correct my post so as to not add to anyones confusion.
    #7 RandyPete, Mar 12, 2026
  8. mva
    mva Active Member
    176
    105
    B.C. Canada
    2024 Prius Prime
    SE
    It has been posted here before. I agree that it is a great video for those of us interested in the design of the traction battery.
  9. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    I was unable to find that previous posting of this video. Thanks.
  10. LRO
    LRO Member
    93
    96
    United States
    2024 Prius Prime
    XSE Premium
  11. RandyPete
    409
    171
    2024 Prius Prime
    XSE
