2024 Prius Problems continue
Discussion in 'Gen 5 Prius Main Forum' started by Chi_weezy, Jul 7, 2024.
  1. Trollbait
    12,831
    Designers were likely relying on the curve of the piece to provide the strength to help keep it place.
    This is the OP's second Prius, it might have the updated part. Looks like those side clips were just pulled out when the bar flipped to concave. Perhaps the heat softened the plastic they anchored too, or weaken the tension of the clips. Being left off to begin with is another possibility.
  2. Chi_weezy
    Chi_weezy Junior Member
    35
    Sacramento
    2024 Prius Prime
    the “dent” is a warp from it being hot and bent. But yes you guys are correct the previous owner had the emblem painted (or swapped). Can’t see why you would take the bumper apart to do that.
  3. Chi_weezy
    35
    Sacramento
    2024 Prius Prime
    Thanks for all the insight guys. I haven’t had time to take it in. But I will soon. Yes it was VERY hot out through the desert. I believe it just got weak from heat, soft, and with the hours of constant 80mph wind, it buckled. Obviously I do not know with certainty if the previous owner did anything but the car is in perfect condition with 7k miles. Emblem shouldn’t have anything to do with it. Will report back. And and my previous Prius Prime, well it had a dead battery when I test drove it. I did find it odd but they got a battery pack and I knew it was warrantied but ya ended up wasting a ton of my time. Got all my money back but still. 3 months later.
    BiomedO1 and bisco like this.
  4. Avade
    Avade Junior Member
    california
    2024 Prius
    LE AWD-e
    newly repaired bumper, this time no place to fasten the clips, and the wings are moving loosely.
    i have a newly repaired bumper, this time no place to fasten the clips, and the wings are moving loosely. I uploaded the short video in youtube but I cant share in this forum yet. Not sure what the remedy will be and I just hope it doesn't keep moving in highway speeds
  5. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    So did you get a replacement front bumper bar? If you got part 52111-47901, that doesn't include the retainers, so those should have needed to be refitted from the old one.
    (Can you really re-use the adhesive? I wouldn't have thought so, but the instructions I posted above seem to suggest it's possible.)
  6. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    VelvetFoot likes this.
