2024 Prius, questions so far
Discussion in 'Gen 5 Prius Main Forum' started by David W. Griffin, Nov 20, 2023.
  1. David W. Griffin
    David W. Griffin Junior Member
    My previous 2012 Prius was obsessed with MPG and it was easy to keep a running tab, not so with the 2024. The only place I can see something like the 5 minute MPG is in the trip screen of the main screen and there is no current or accumulated MPG. Furthermore the only place I CAN see MPG is for the trip for a few seconds when I turn the car off. What am I missing?
    Second, the mats I have are very rugged rubber mats (which are fine but I guess I expected carpets) I just want to make sure those ARE mats and not just the floor you're supposed to put mats on.
    Third, I can't make the Homelink work with my old Genie garage door opener. I think it's because you have to use the learning button on the actual opener which I'm not really physically strong enough to climb up on at least now. Also I'm concerned if I do that my current opener might stop working as well as my two other openers mounted on the garage and inside the condo. Can anyone elaborate on this?
    Fourth, they are trying to sell me WiFi hotspots, but all my devices already have a data plan which I don't need. But I do need Drive Assist and Maintenance Assist to provide nav services and maintenance updates respectively. The question is do I need the WiFi to get those working? I'm hoping not.
    The nav system by means of carlink works great with my iPhone 14. It even feeds into the main speedometer screens for turns. The routing can be weird but that is more Apple Maps I think. I haven't tried google's. A couple of times the destination I want comes up on the destinations screen and other times I have to get my phone out and go to the calendars or contacts and press on the address to get Apple maps up, at which point it feeds to the car.
    Fifth, they have really cut down on storage space. The space beneath the hatch is now taken up with tools for the small spare (pumps and such) and has a giant styrofoam piece. I feel like I could replace it with some kind of custom made plastic tray with space for the tire gear with lots of space left over but I doubt I could find one. There is only 1 glove compartment and the usual center console. I'm thinking about getting an organizer from Amazon to drap over the back seats under the cover to give me SOME rear storage.
    Sixth, the cruise control has mystified me so far. I couldn't intuitively get it to work due to the supercomplex modes (there is no obvious simple mode). Hopefully I'll figure that out.
    I like the new sun visors with the pull out piece and the blind spot monitors. I drove a 2022 and it seems to me that over the last 2 years they have really raised the complexity of the electronics by a pretty big margin and that has made it less intuitive.
    Seventh and last, the passenger door puzzles me. TYPICALLY even if I leave the car unlocked (in my garage), when I go out, I can't open the passenger door. I haven't found the mode to do so yet, and the passenger door doesn't seem to have a system for me to open the door with my hand the way my old 2012 did. I hold it and hold it and nothing happens. Am I doing something wrong there?
    Thanks.
    52,848
    we have the same problem with our '24 hycam. when you power down, the stats flash so fast, i can't read them. very frustrating. i ask the dealer and toyota, and neither had a clue
    if you can lift the mats out, they are the all weather mats. our hycam came similarly equipped. i never wanted all weather, but now i love them.
    i had to get a ladder and hold the learning button on my 20 year old craftsman door opener, while mrs b pushed the homelink button. maybe use your remote until you're strong enough, or get help?
    yeah, the electronics are baffling, even with the manual.
    what package did you get? it's time to update your model year and info, all the best!
    #2 bisco, Nov 20, 2023
    David W. Griffin likes this.
  3. Z ain
    Z ain New Member
    az
    2023 Prius
    1.) Your car has previous trips under the toyta settings if your phone is plugged in you'll need to back out of the phone settings and go to the car's. its not very intuitive though. Like you mentioned when you turn off the car it will displayed the MPG you got during that drive. if somone opens the door you can press the back button on the left hand side of your steering wheel to bring it back.
    2.) Mats yes, you paid extra for those lol.
    3.) Homelink has lots of nice tutorials to follow. you will have to hit the learn button. you have 30 secs after you hit it to go back to your car. its easier with 2 people.
    4.) No.
    5.) less storage yes :(
    6.) Get to speed you'd like to cruise at. Press the cruise control button. Its on the right hand side of your steering wheel above the RES+.
    RES + and - will increase or decrease your speed. the button next to the cruise control button is your lane centering. You should really read your manual. like you said repeatedly in your post. the technology has evolved quite a bit since your last car. All the answers to your questions are in your manual more than likely :)
    7.) are you accidently hitting the lock button on the passenger's door handle? your key fob also doesn't unlock the passenger doors automatically. i believe you need to change the settings to unlock all the doors (could be wrong)
    nerfer likes this.
  4. Mendel Leisk
    42,343
    1. Start a spreadsheet
    2. do not know. I do know: our '10 had carpet-style mats, and the driver's mat had no rubber insert. Wore right through within a year or two. I added a rubber insert, fine since.
    3. I was stumped as well, thank god for off-spring that can manage this stuff.
    4.Seems like the maps are wifi? Not exactly progress...
    5. Cut down on storage, delete the spare, the extra glove box. What's Toyota's motto for that; something like "continuous improvement"?
    6. Complexity seems to follow the Peter Principle after a fashion: it progresses to the point that the typical owner is mystified. Can also create dangerous distraction, when driving.
  5. jeremnyc
    jeremnyc Junior Member
    95
    2023 Prius
    I agree that the mileage is kind of hidden in the 23/4s. In the app you can actually see the trips but I haven't been able to find the mpg in the summaries.
    I've not found an all in one battery, econ, and average in the 5th Gen. You have to toggle though several screens with your left hand.
    David W. Griffin and bisco like this.
  6. Numtini
    Numtini Member
    91
    94
    Cape Schrod
    2023 Prius Prime
    XSE
    You don't need the wifi hot spot for any services. It's purely for devices. I guess if you had two or three kids with ipads it would be useful. We just make sure our kid downloads stuff before long trips.
    If you want to use the built-in Toyota navigation system, that's under the Drive Connect subscription now. It doesn't require the wifi plan. If you want to use Google Maps or Waze or whatever through Carlink/Android Auto you don't need any plan.
    Cruise control is the cluster of buttons on the right side of the steering wheel--top left button to turn on. The top right turns on lane tracing, which you probably want as part of cruise--you can press this once and let it be. The cruise control is wonderful. Keeps speed without racing the engine, stays in lane even through curves, and gives good space between you and the next car. Put on the turn signal and it will automatically change lane. Really impressive. You do have to keep a finger on the wheel and your eyes on the road. P343 in the owner's manual.
    I don't think you can get a 5 minute MPG, but you can change the "eco" sub-view on the left side (the leaf) of the speedometer to show MPG. Then you can go into the settings and go to the settings and change it to be MPG since last manual reset, MPG since HV mode was entered (ie, this trip or the portion of the trip where you put it into HV mode), or since last fuel up.
    On the door, do you have an LE? The LE only has the smart key auto-unlock on the driver's side door.
  7. David W. Griffin
    My car is an LE. Yes, it does seem like you can't open it from the passenger side which is annoying. You can open it from my phone though.
    Yes, I'll wait till after my surgery and maybe get a handyman out to my house to help me with the homelink. It's not exactly critical.
    Where do you find the "eco" sub-view on the left side of the speedometer? I'll look for that.
    I need to click the little arrow for the in car nav system but it apparently has a procedure requiring it to text me to start it off. Does this subscription cost anything and if so what? How is that nav system? My iPhone's working with the car quite well, but I wouldn't mind having a backup.
    I'm going to have to approach the cruise control cautiously until I get used to driving the car. It's quite a change from my 2012.
    Has anyone heard of a replacement tray to hold the tire stuff without the styrofoam? Has anyone tried those cloth caddies that droom over the back of the seats and hold stuff? I'm afraid I couldn't reach those. There are just things I don't want to use most of the time but are nice to be there like a first aid kit. I don't need a LOT of room.
    Yes, Toyota has reached the mystification level for sure. Thanks for replying everyone. Keep it up with ideas.
  8. 23PriLE
    23PriLE Member
    95
    67
    North Central Florida
    2023 Prius
    Wait, your car has a spare tire? The '23s don't. Did they add one for the '24s?
  9. Trollbait
    12,825
    Toyota started cutting useful storage space with the gen4. I think lost all under floor storage. Just the foam holding the spare or goo pump and tools. The gen5 actually gives you some bins for stuff there.
    There is a spare option in other markets, and swapping the parts isn't difficult. Just pricey for something that will be out of sight under the cargo deck.
  10. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    There's a setting in the display to have all doors unlock when you either pull open the drivers door or hit the keyfob.
  11. Mr.Vanvandenburg
    1,361
    660
    2020 Prius Prime
    If I open the front door, then turn off the car, then get out, then close the front door, the back door is locked. If I turn off the car without opening the door, the back door is open. I think this is how it goes, pretty annoying when back door is locked. Then I open the front door and press the unlock switch. My dog is back there so always opening the back door. Gen 4.
  12. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    Mr. Griffin,
    The answers to some of your questions depend on the country and model of the car. Please follow up with that information or, better yet, update your profile with that information. As far as I know, in the USA, there are two configurations for the area under the hatch floor, but no model sold has a spare tire. Similarly, the options related to door locking are model-dependent in the USA.
  13. Argyros
    275
    142
    2023 Prius
    As I said above- I also have the LE, and programmed all the doors and hatch in the multimedia to unlock when either auto-unlocking the drivers door OR the keyfob. Simple.
  14. Ngenovesi
    Ngenovesi Member
    51
    28
    Pittsburgh
    2023 Prius Prime
    I noticed the other night driving my turn signals and wiper arm does not light up when I have lights on. Is this normal. All my previous Toyota primes and hybrids did. Can’t see to set to automatic at night.
  15. Ngenovesi
    Ngenovesi Member
    51
    28
    Pittsburgh
    2023 Prius Prime
    2023 Prius Prime Premium
  16. I Throw 99
    I Throw 99 Junior Member
    28
    2023 Prius
    XLE AWD-e
    I’m pretty sure you can also change the setting by holding down the lock and unlock buttons at the same time until the car beeps as well.
  17. Heather Anderson
    Heather Anderson Junior Member
    Cincinnati
    Did you ever figure out the mpg mystery? I had a 2016 and now a 2019 and I pay attention all the time to the mpg of each trip. My husband has a 2024 and we can't figure out why Toyota would remove the ability to see your real-time mpgs. It almost feels like they don't think they are going to live up to what they've promised. I also can't find a list like I have on the 2019 that shows yesterday's, last month's, and last year's mpgs. Again, why would they remove that?
    How is your fuel economy so far?
  18. bisco
    52,848
    our 2024 hycam is a huge info reporting downgrade from our 2013. all i can figure is that they've made these screens so complicated, they've even baffled themselves.
  19. Mendel Leisk
    42,343
    Peter Principal applies to automotive controls i guess. Would be nice to be able to select cabin vent mode, for example, without nearly going off the road. :cautious:
  20. Numtini
    Numtini Member
    91
    94
    Cape Schrod
    2023 Prius Prime
    XSE
    Go to settings and it's in there somewhere. It lets you swap between all-time, this tank, and trip MPG.
