2024 Prius XLE Spare Tire solution
Discussion in 'Gen 5 Prius Main Forum' started by Ben in IL, May 21, 2025.
  1. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    This is dangerous advice. A loose spare tire becomes a missile in an accident. A front end collision causes that to LEAP in the air and hit you in the back of the head
    GcinFl likes this.
  2. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    How is that working out for you? Did you ever get the foam pieces? Thanks.
  3. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    I bought the OEM foam when I purchased the spare wheel but did not make the small foam cubes to complete the support of the cargo floor. I put a towel and bubble wrap to level it off and put cardboard on top of the cargo mat for when I put my bottled water or anything heavy in there. Seems to be okay for now. Haven’t made it a priority to cut foam cubes. If I could buy them cheaply, I would. I honestly forgot about it and need to put it on my long To Do list.
  4. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    Thanks. I think I’m going to go with putting a doughnut behind the passenger front seat. I’ll have more room for storage in the trunk this way.
  5. daisy555
    1,729
    716
    CT
    I can’t deal with the tire smell. Be sure to secure it.
  6. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    Wedged behind the front passenger seat back I don't think it's going anywhere, unlike if it was just laid down in the back.
    I don't even have the car yet, so there's that...
    I kind of like that rubber smell, lol.
    daisy555 likes this.
  7. daisy555
    1,729
    716
    CT
    …and don’t block the vents on the back seats.
    VelvetFoot likes this.
  8. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    I think it's behind the driver's seat, where I usually put the shopping bags, jacket, water bottle, etc, lol.
  9. daisy555
    1,729
    716
    CT
    That’s exactly what I used to do. : ) I’ve lost major back seat floor storage. There’s a smaller vent on the passenger side back seat as well. I miss having the vent on the top edge of the back seat. It was more visible and used zero storage space.
  10. KMO
    KMO Senior Member
    2,030
    751
    Finland
    2023 Prius Prime
    Putting stuff there shouldn't really matter much. There's a thermostat-controlled fan.
    If airflow was obstructed, the fan can just run faster to compensate. Same as if the air was warmer.
    I'd be concerned if you were planning to tape it up, or if you were already driving around with that fan at maximum rpm so it couldn't suck any harder, but I wouldn't be particularly concerned about stashing stuff in the footwell generally.
  11. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    It probably wouldn't hurt to at least keep it in mind when putting stuff back there.
  12. Winston Smith
    Winston Smith Active Member
    476
    344
    OH
    2024 Prius
    LE AWD-e
    If the flow of air is genuinely obstructed with pet hair or a plastic bag over the vent, it won't matter how fast the fan runs because air won't flow. People worry about this because the battery is expensive and not changing or clearing the filter has been linked to a shorter useful life.
  13. Hammersmith
    Hammersmith Senior Member
    2,491
    2,547
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    In previous generations, blockage was more of a problem because the intake was mostly flat and placed in an area where it could get obstructed. The gen5 has an intake that has a 45 degree bend in it. It's right on the corner of the rear seat base, so about half the intake face is perpendicular to the long axis of the car(or parallel with the rear seat) and then it angles in and back towards the door. This means it's more likely to remain clear if something is placed in front of it. Even if you place a box in the footwell and it blocks the front(perpendicular) section, the fan will still be able to pull air through the angled section on the side.
    The only way I can see a person being able to block the intake in a gen5 would be to lay a blanket over the entire seat with a large amount overhanging and tuck it in all the way around.
