2024 XSE traction battery location & Li chemestry ?
Discussion in 'Gen 5 Prius Technical Discussion' started by RandyPete, Feb 8, 2024.
  1. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Where is the 2024 XSE traction battery location & Li chemestry ?
  2. Trollbait
    12,832
    The hybrid battery is under the rear seat. The Prime is also there, but extends under the cargo space.
    Never saw mention of the actual chemistry myself. It isn't LFP, as that isn't energy dense enough to fit in the tight spaces of a PHEV.
  3. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    I think there is only one traction battery in a Prius Prime 2024. You seem to be implying there are two traction batteries?
    #3 RandyPete, Feb 8, 2024
  4. Hammersmith
    Hammersmith Senior Member
    2,497
    2,557
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No. Both only have one traction battery. The difference is in the size and which side of the sheet metal it's on.
    In the Prius HEV, the battery is on the inside of the car under the rear seat. The sheet metal floor goes under the battery. So to remove the battery, the cargo area and the rear seats are removed to gain access.
    In the Prime PHEV, the battery goes under the car. It's in roughly the same place, but the sheet metal floor goes over the battery, and the battery is encased in a weatherproof container. So to remove the battery, the car is placed on a lift and the battery is lowered like a transmission or rear differential.
    GcinFl, RandyPete, Jabog6 and 2 others like this.
  5. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    As far the Prime's battery is concerned, you'll find all the relevant information in the sticky thread just above.
    The non-Prime also have Li-ion NMC type, not sure if using the same cells.
    Trollbait likes this.
  6. JimLudden
    JimLudden Member
    Taos, NM
    2024 Prius Prime
    How would I gain access to the high voltage conductors from the traction battery -- to attach an Inverter?
