2025 MY changes?
Discussion in 'Gen 5 Prius Main Forum' started by JB88, Aug 23, 2024.
  1. JB88
    JB88 Junior Member
    Thinking about buying new, but would rather wait until the model year turns over if there’s a chance of any changes, however minor (like getting rid of the silly hashtag stuff). Does anyone know/have any guesses as to whether Toyota will make any changes on the 25s?
  2. Hammersmith
    Hammersmith Senior Member
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I would be very surprised if there are any noticeable changes at all for 2025. There will probably be a handful of inconsequential changes, but those won't be seen by the buyer(very, very minor wiring changes, a couple updated parts that are already being used on late-2024 models, etc.).
    I'm more than happy to end up being wrong, but the car has barely been in full production for 1.5 years* at fairly low volumes. I don't see Toyota spending money to change noticeable things until the 2026 model year at the very earliest(more likely 2027 for any kind of refresh).
    *I believe pre-production started in Dec 2022, but things didn't get into full swing until early March 2023
  3. Trollbait
    12,814
    There also isn't anything to really fix. Most midcycle changes are cosmetic, and the response to the gen5 looks has been far better than the gen4's. Nor is there something like the gen4 Prime's rear seat that no one liked.
    Maybe some features will get shuffled between trims, or perhaps the US will get the yellow for the Prime. That's the most to expect.
  4. NonFormulaic
    NonFormulaic Member
    62
    45
    San Diego
    I’d be all in for two zone A/C!
  5. Hammersmith
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    That would actually be an easy add for the Prime, at least. Toyota is already making the needed part for the European market. Less likely for the HEV as that would need a new part that Toyota doesn't currently make.
  6. Trollbait
    12,814
    Is the hybrid HVAC system that different from the Prime that parts aren't interchangeable?
  7. Hammersmith
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yep. Some parts are interchangeable, but this one is not.
    The PHEV AC box has 3 coils inside, while the HEV only has 2. The HEV has the standard heater core(engine coolant) and evaporator coil(AC refrigerant), but the PHEV box has an additional condenser coil(AC refrigerant) for when the heat pump is generating cabin heat. Since the AC box is also where all the servos and dampers are to control where the cabin air is routed, the HEV and PHEV boxes are not interchangeable.
    To visualize what parts I'm talking about, here's a CarCareNut video of him working on an AC box and blower out of a Lexus. The blower assemblies(the right half of the whole unit) are the same in both the HEV and PHEV, but the AC boxes(left side) are different. The Prius version looks pretty similar to the Lexus one on the table, except the Prius one is made out of a slightly translucent white plastic instead of the black plastic in the Lexus.
    He also walks over to the car in the video to show how far you need to go to get the AC box assembly out. It's why upgrading a non-European PHEV to dual zone after purchase isn't really feasible. The box itself will run maybe two grand, then more for a new dash control unit(both of those likely imported from Europe). Then there's extra wiring to add, the three days of shop labor if you're going to have it done by a professional, the cost of evacuating and recharging the AC refrigerant, and the cost of at least partially draining and refilling the engine coolant.
    You're looking at a mid-high four figure job at that point. And there's no way to know if the USA main body ECU can even recognize and operate the dual zone unit until the car is mostly put back together. If the shop gets to that point and discovers the modifications don't work, a person might be paying for three more days of labor to swap it all back out. Now you're pushing $10k for absolutely no gain. It's just not worth the risk.
    Merkey and Trollbait like this.
  8. Trollbait
    12,814
    Ah, I had not considered the heat pump could mean a difference in the venting.
    With TNGA, I suspect there is fair chance Toyota already has a dual climate AC box that will fit the gen5 hybrid. Software is a question mark, but it would be more cost effective for Toyota do develop the code for dual, and install that in every model.
    Returning to the OT, there are some here that watch the Japanese auto sites. Those would be the places to find anything about any changes happening.
  9. Gokhan
    Gokhan Senior Member
    6,707
    2,658
    Paramount CA
    2025 will be identical to 2023 and 2024, but there will be a mid-cycle refresh (Gen 5½) in 2026.
    So, hold on for another year for Gen 5½ appearing as the 2026 model year in late 2025. Dealer discounts should also arrive by then with plenty of inventory.
    What the mid-cycle refresh will bring is not known. Gen 4 Prius Prime (2017–2022) saw the center rear seat in 2020 (Gen 4½) and TSS 2.0 (Gen 4¾) in 2021. So, I was lucky to get a Gen 4¾ Prius Prime in that sense.
    #9 Gokhan, Aug 28, 2024
    Merkey likes this.
  10. Hipparchus
    Hipparchus New Member
    Houston
    If Toyota watches this and wants a suggestion for changes, I have one: More paint and interior color choices. There is only one interior choice: black with red accents. I have been driving red cars for 30 years and I want something different. The only currently available paint color I like is the blue and I don't really like the combination of blue paint and red interior accents.
    Gokhan likes this.
  11. Hammersmith
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    We can swap interiors. lol
    I'm currently (very slowly) converting my red HEV with the black interior with silver accents to the black with red accents from the Prime. I've replaced the dash trim with the red(I've still got the blue/silver original) and I'm trying to find a set of used seats or seat covers to continue the project.
  12. purplePriii
    purplePriii Active Member
    275
    123
    Upholstery/Seat Covers ? | PriusChat
    Post #9 was surprisingly nice interior for covers.
  13. Hammersmith
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm specifically going for OEM for everything in my car. It creates a couple headaches from time to time in sourcing parts(and affording them - lol), but it's a choice I made early in the process.
  14. Cactus
    Cactus Junior Member
    32
    Mountville PA
    Fix the front bumper Toyota!!!!!
    DOHCtor likes this.
  15. ColoradoBoo
    ColoradoBoo Senior Member
    1,345
    970
    Monument, Colorado USA
    Yep, after these past few years with the big Toyota problems with new generations (Tundra, Highlander, Lexus) I'm never going to be buying a first-year model and will research hard before even buying a 2nd year new Gen....just too many problems for folks. (And not small one but stuff like needing new engines.)
    I've been wanting to trade my 2014 Tundra V-8 for a new Tacoma (we traded our old, heavy camper trailer for a lighter one) but I really don't like the turbos and hybrids on the trucks...don't even add much MPGs, either.
    So I'll wait a few years and see what comes down the line from Toyota in their truck division.
  16. Gokhan
    6,707
    2,658
    Paramount CA
    I don't think Toyota updates exterior (and probably interior as well) colors in mid-cycle refreshes, but the interior accents do get updated. Gen 4 Prius Prime lost its white interior accents, which hadn't looked very good.
  17. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    Hopefully they will ad a free 17" wheel option on higher trim.
    Gokhan likes this.
  18. MScelery
    MScelery Junior Member
    83
    25
    Mississippi
    What’s wrong with the front bumper?
  19. Hammersmith
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Nothing. At least nothing major. I'm going to guess that the poster isn't happy with the bump for the license plate. You're in the same situation(states that don't require front plates), so you'll have to decide for yourself if it's an issue.
  20. Gokhan
    6,707
    2,658
    Paramount CA
    I guess we won’t see much change until Gen 6 (2029 model year and later), which is three years from now.
    Gen 4 and Gen 5 are practically the same car despite the modern looks and more power on the latter, just like Gen 2 and Gen 3 are, but Gen 6 will be a total redesign on the Arene platform, with modernized, large displays and much more capable ADAS. They might decide to get rid of the HEV version by then as well and only offer PHEV and BEV versions.
