2025 Prius Wish-List
Discussion in 'Gen 5 Prius Main Forum' started by PriusPeep, Apr 26, 2024.
  1. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    With a Gen 5, Apple Car Play lets you display info in a text form on the infotainment screen from some OBD apps (I know that OBD Fusion and Car Scanner do this) and a bluetooth dongle plugged into the OBDC port.
    What would be nice, if you could see the 'gauges' display on CarPlay. I think that would be an Apple thing, but Apple incorporated it in an update to CarPlay, would Toyota have to update the relevant module in the car? I assume at the dealer and not over the air?
    Anyway, that would be nice.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I use the Car Scanner app with a a OBD2 Bluetooth reader, but I don't find it very useful. It used to show me the charge voltage of the hybrid battery, but that feature was removed.
    VelvetFoot likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,456
    5,430
    Pacific Northwest, USA
    If you want battery vital signs you need to use Dr. Prius app or Hybrid Assisstant, which has a companion app known as hybrid reporter.
  4. otatrant
    otatrant Active Member
    349
    212
    San Francisco
    2023 Prius Prime
    XSE Premium
    You can add OBD Fusion to that app list.
  5. PriusCamper
    13,456
    5,430
    Didn't know about that one... What do you like about it? I was just looking at it now.... Is it worth the $6?
  6. otatrant
    349
    212
    San Francisco
    2023 Prius Prime
    XSE Premium
    I bought it a very long time ago ie 2013 in the Apple app store. I bought the Carista dongle soon after I got my Prius in 2023 but didn't think the app was worth a subscription. So since it was essentially free for me to use OBD Fusion it is definitely worth it.
    Not the slickest app but I do like having more information than there is available natively on my Prius. For example the flow meter shows the gas engine is running and providing energy but doesn't differentiate between the engine running to circulate fluids and using minimal gas from running to provide most of the power to drive down the road. In the app you can create a gauges for both the electric motor power and the gas motor power.
    I haven't used many OBD apps but it works. The interface to set up dashboards feels like it could use an update but I do appreciate being able to create custom dashboards.
  7. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    Do you use Apple Car Play to display OBD values on the infotainment screen?
  8. otatrant
    349
    212
    San Francisco
    2023 Prius Prime
    XSE Premium
    No. I have my iPhone 17 Pro Max mounted on the left side of the dash using very thin steel plates with 3M adhesive, Ram Mount small magnetic base, Ram mount double socket swivel and ratchet arm b size, and a Quadlock twist lock mount wireless charging head attached to a ram mount b size ball. I have acquired a bunch of ram mount components over the last 10+ years and quadlock stuff over the last 2 to 3 years and tried to use what I had to make it work. It has been a good 6 months since I worked out how to mount it using all the various parts but it works well. When I say it works well I mean it:
    1. doesn't fall when I am driving
    2. doesn't trigger the driver monitor alert if I want to glance at my phone,
    3. is easy to read the gauges in OBD fusion when I am driving.
    4. is within reach of short usb cable since I used wired Apple CarPlay so the Toyota media center can have a wifi connection to the internet.
    5. doesn't block visibility of the road
    6. is within reach should I want to switch apps or view something on my phone.
    7. is easy to attach and detach my phone
    I think like you noted on one of your previous posts OBD fusion doesn't display the gauges on the CarPlay Screen but instead just minimal text.
