2026 Gen. 5 Prius Wish-List
Discussion in 'Gen 5 Prius Main Forum' started by PriusPeep, Feb 23, 2025.
  1. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    DO you have a picture of that location without shutters ?
  2. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    If you prove me wrong, I'll count that as a win.
    I'll wait for a better day to take a pic to confirm.
  3. hyo silver
    hyo silver Awaaaaay
    15,273
    1,605
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    The black slats, right?...mostly horizontal, tilted up at the leading edge...there seem to be central supports as well, anchoring the pivot points.
  4. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    "count that as a win" What the heck does that mean ?
    No need to win from my point of view.
    It’s a beautiful sunny day here, about 70 degrees F and sunny out.
    Here’s the images of the louvers on my ‘24 Prius prime.
    IMG_2784.jpeg IMG_2780.jpeg IMG_2784.jpeg IMG_2780.jpeg IMG_2784.jpeg IMG_2780.jpeg
    #24 RandyPete, Feb 24, 2025
  5. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
  6. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    I'm in the same boat. Had to put a pad down, lay on my side and then take the pics. It's a bitch getting back up.
  7. Mendel Leisk
    42,389
    Override your camera's auto-exposure too, if possible. If you've got a bright outer grill, the camera's naturally going to adjust to keep that from blowing out, and something deep in the shadows goes to near-black.
    Post 24 not convincing?
  8. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    No need. I believe you.
    hyo silver and Mendel Leisk like this.
  9. Winston Smith
    Winston Smith Active Member
    476
    344
    OH
    2024 Prius
    LE AWD-e
    These are very hard to see. It's all black plastic in poor light. Without Hammerrsmith's and RP's pictures, I'd have had no idea what I was looking for.
  10. hyo silver
    hyo silver Awaaaaay
    15,273
    1,605
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Back when people were putting cardboard on the radiator, some kind of automatic blocking system seemed like a great idea. So great that when some of us Priuschat peeps were invited to Detroit to witness the unveiling of the 2010 model, I took the opportunity to ask the head engineer about them. He said 'yes, we have thought of that, but I'm told it's too expensive. Maybe next model...' and here we are.
  11. mva
    mva Active Member
    178
    105
    B.C. Canada
    2024 Prius Prime
    SE
    Yes, I remember doing the grill blocking with foam pipe insulation on my 2005 Gen 2 Prius.
    hyo silver likes this.
  12. Trollbait
    12,836
    IIRC, they active shutters started showing up in the eco trims of other cars around that time. Now they are pretty common.
    hyo silver and RandyPete like this.
  13. Gokhan
    Gokhan Senior Member
    6,722
    2,672
    Paramount CA
    None are happening for sure, perhaps with the exception of wheel options. There is no DC charging for Prius; so, it can't have a Tesla plug.
    The 2026 model-year mid-cycle refresh will hopefully see some headlight/taillight improvements as the previous models and probably nothing else.
  14. Prodigyplace
    12,720
    11,852
    Central Virginia
    They introduced the shutters for Gen 4,
    In fact, one poor Alaskan Prius was lost due to fire because of a clueless dealer. They installed a block heater & ran the power cord through the shutters, It eventually wore through the wires, causing the car to catch fire one night in the garage,
  15. Mendel Leisk
    42,389
    You could grind off a corner of a shutter slat I suppose. The Toyota block heater install instruction doesn't consider routing through the grill, just leaves it in front/left corner of engine bay, assuming you're going to pop the hood to use it.
    Way off-topic, but as long as we're here. :)
    #35 Mendel Leisk, Feb 25, 2025
    Gokhan and Prodigyplace like this.
  16. Gokhan
    6,722
    2,672
    Paramount CA
    Way off-topic and way irrelevant but still can’t resist. ;)
  17. Mendel Leisk
    42,389
    Well, considering this wish list is never going to catch Toyota's attention, and even it did, it's gonna be bumper-and-light mods and maybe a blacked-out emblem version, why not.
    bisco and Gokhan like this.
  18. Prodigyplace
    12,720
    11,852
    Central Virginia
    The 2017 mid-year update added some features by default. (They charged & then credited it). The Two Eco lost its cargo cover to keep weight down. I had regret I bought an early 2017 Two since the mid-year had some features I wanted but were not available on my chosen trim.
  19. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I don't know how well the shutters worked, but when it was very cold, it wasn't very warm inside my car. After the cardboard was put in, the inside was always nice and toasty. I'm sure I'll get a warning if it ever overheats.
  20. Mendel Leisk
    42,389
    IIRC, in sub-freezing temps the shutters remain partially open, due to concerns about them freezing.
    Prodigyplace likes this.
