2026 Prius Plug in won't start
Discussion in 'Gen 5 Prius Main Forum' started by sistersinhim, Feb 11, 2026.
  1. sistersinhim
    sistersinhim Junior Member
    30
    Central Virginia
    2020 Prius Prime
    Technology AWD-e
    I was iced-in for two weeks. I tried to start my car this morning, and just different things were popping up on the front screen. My brake pedal won't push down. The car was plugged in the whole time.
  2. AgentPTFC
    AgentPTFC Member
    63
    42
    PNW
    2025 Prius Plug-in
    XSE Premium
    12v battery is dead. You'll need a jump to get started.
    PrimeDan and BiomedO1 like this.
  3. Mendel Leisk
    42,355
    If you've got a multimeter, check the voltage. Anything less than 12.0 volts, it's seriously depleted. 12.0 to 12.5 is so-so. 12.6 or higher you're in good shape.
    If you don't have a multimeter, a good-enough one is around $20~30, any hardware or automotive store will have them, or Amazon.
    For a better assessment, one of the new generation of electronic load-testers is your best bet.
    Barring DIY, try a jump-start. Be very careful with polarity, red to positive, black to ground. Beforehand, phone a few automotive places, verify they have compatible battery in stock, and can run a load test on your current battery.
    Or maybe someone like AAA can come to you.
    GcinFl likes this.
  4. BiomedO1
    BiomedO1 Senior Member
    4,628
    2,425
    Left Coast
    Please read manual....
    Toyota Manuals and Warranties | Toyota Owners
    12V battery ONLY receives a small charge while it's actively charging the traction battery. Your traction battery was fully charged on day ONE; so the other 13 days was discharging your 12V battery - due to more readiness testing while plugged-in. That's why the manual states to unplug the car when the traction battery is fully charged. Fully charging the traction pack and not using it for two or more weeks is another discussion - again read the related sections of the OM, because your degrading your traction battery pack faster than engineering projections.
    You've probably killed that 6 year old battery 12V battery. Try recharging it and get it tested at any auto parts store for free. Since the battery was drained, you may get some phantom error codes (CEL), just erase them and see if they come back. AFTER you take care of the 12V battery issue.
    Good Luck......
    Sorry; that's a 2026??? It's similar to a gen4; just a larger traction pack. Call the nearest dealership's roadside assistance number. They will fix it for free and replace the battery, if needed. I wouldn't mention leaving it plugged-in for 2 weeks solid; since that places the system fault at your feet.... Operator error.
    #4 BiomedO1, Feb 11, 2026
  5. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    This is to be expected with my car. Leaving it parked for more than 4 days usually results in a dead battery, or rather a battery at too low a charge to start the car.
    When the battery voltage falls below about 11.5, the car enters an error state, and will not start up. The only solution I found is to use a booster pack. The rest of the time, I use a battery maintainer if power is available.
    This seems to me like a serious design flaw; it seems absurd that you need to get a boost or make a dealer service call every time the battery goes flat, which is quite often, especially considering that there are kilowatts of available power in the hybrid battery. It seems simple enough to me that it could be designed to transfer some power to the DC-DC converter, when needed (as long as there is sufficient charge in the hybrid battery). But Toyota has been no help at all with this problem, so I get by with my workarounds.
    Post edit: Plugging in the charge cable will maintain the 12V battery in a limited fashion, but I found it to be unreliable over longer periods.
    #5 Paul Gregory, Feb 11, 2026
  6. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I use one of these in my live socket:
    #6 Paul Gregory, Feb 11, 2026
  7. Mendel Leisk
    42,355
    Paul, if you highlight some text, then embed the link in it, using this function:
    It works better. Right now I'm just seeing blank space.
  8. bisco
    52,863
  9. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    Yes, if you leave the Gen 4 or Gen 5 Prius PHEV plugged in for two weeks, it will drain the 12-V battery. You should only keep it plugged in during active charging and unplug it within a few hours once the charging is completed.
    Now, at this point, you must buy and hook up a Noco Genius and manually charge the battery for about 60 hours; otherwise, it will be seriously degraded.
    Last but not least, you should not keep the traction battery at over 50% SOC if the car will not be driven immediately, as this will cause serious degradation of the lithium-ion cells. Ideal long-term storage SOC is around 25%.
  10. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    If I had a PHEV, I'd use a home automation product (I am a Hubitat'er) and a smart switch that can monitor watts, and write a rule that when it gets down to whatever low level 'charge complete might be', shut off the switch. You could even charge it up to something less than 100% if you could roughly correlate it to watts.
  11. Gokhan
    6,715
    2,672
    Paramount CA
    Again, you don't want to leave the Gen 4 or Gen 5 Prius PHEV plugged in for longer than overnight, as it induces a significant parasitic draw on the 12-V battery once active charging is completed.
    The Gen 5 PHEV has an adjustable SOC limit on the traction battery. The Gen 4 PHEV doesn't have it.
    VelvetFoot likes this.
  12. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    My iPhone is set to charge to 80%. Every once in a while it charges to 100%, for calibration purposes.
    I ran across calibration with my Bluetti LiFePo power stations. I charge them 100% ('cause in a power outage-you need it), and drain them and recharge periodically. LiFePo apparently is not as sensitive. This is interesting:
    BLUETTI Pioneer Na Sodium-Ion Portable Power Station
    Gokhan likes this.
  13. ETC(SS)
    7,568
    If you're going to drive a car with an eensy-weensie start battery then you REALLY need to invest in a 'jump pack' and learn how to use it properly.
    No.
    I'm not picking on Priuses.
    MOST cars these days have undersized batteries and MOST of them will fail with zero warning.
    Priuses just seem to be worse than most.
    Jump packs are 'crayon eater' easy to use and most of the modern units have polarity protection built into them - meaning they won't hurt your car if you mess things up.
    Even the best models are under $100 these days - but you WILL WANT TO read the instructions on the unit that you pick otherwise it might be more useful for you to just keep the $100 bill in your cargo bay.
    Really.
    Leaving the house when you want to (or a gas station in the middle of the night!)....can be kind of important.
    As stupid as it sounds, you're probably better off driving without a spare tire these days than you would be without a jump pack - especially if you have a patch kit and a pump. :p
    Good Luck!
  14. bisco
    52,863
    They just need a larger 12v to handle the drawdown, it’s not that complicated
  15. Gokhan
    6,715
    2,672
    Paramount CA
    No lead–acid battery is large enough to be left undriven for extended periods. The 45-Ah battery on the Gen 4/Gen 5 is sufficient. Aftermarket versions are 50-Ah.
  16. Gokhan
    6,715
    2,672
    Paramount CA
    It is very unlikely that you will have a dead battery on the road. It usually happens at home. Although, it happened to me once in Vegas because of the 120 ℉ heat, and once in a parking lot because I forgot to turn off the headlights. In the first case, it came back to life after it cooled down (and I made a trip to a Vegas Walmart to get a replacement the next day), and in the second case, a friend gave a jump start.
    And a AAA membership helps with tire and battery issues.
  17. BiomedO1
    4,628
    2,425
    Left Coast
    Neither is unplugging the car when the traction battery is fully charged. I've left my car on the driveway for 2-3 weeks at a time on multiple occasions, w/o issues. I don't top-off the traction battery, unless I'm going to drive it the next day.
    Bottom line; if you follow OEM recommendations and don't hang a bunch of electronic garbage on the car's systems - it should perform as expected. That's been my experience...
    PS: Fobs live in a Fariday bag when not in use. Prevents people from amplifying the fob signal to steal the car and also prevents the car from 'seeing' the fob - no unintended readiness testing.
    beemerjean likes this.
  18. sistersinhim
    30
    Central Virginia
    2020 Prius Prime
    Technology AWD-e
    Thank you everyone! Sorry for the late reply, I did not get the email notifications. I got the jump and the car stared just fine. Once a day, I'm leaving it in the Ready Mode, with the automatic cut off of an hour. The problem I'm having is my odometer and outside temperature gauges aren't working. I've not driven the car yet. Will driving it for a few minutes reset these to normal? Unfortunately, I'm one of those 'little old ladies' that drive it to church and back 2 times a week and it's only about 3 miles away.
    What battery should I replace this one with?
    Gokhan likes this.
  19. bisco
    52,863
  20. sistersinhim
    30
    Central Virginia
    2020 Prius Prime
    Technology AWD-e
    I bought a trickle charger from Amazon. It seems that I have to keep the trunk opened to use it. Won't that further drain the 12V?
