2027 Lexus TZ 3-Row BEV
Discussion in 'Lexus Hybrids and EVs' started by drash, Jun 2, 2026.
Tags:
  1. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    ALL-ELECTRIC THREE-ROW LUXURY: THE ALL-NEW 2027 LEXUS TZ - Lexus USA Newsroom
    • Lexus’ First-Ever Three-Row All-Electric SUV Debuts for the 2027 Model Year
    • A Manufacturer-Estimated 300 Miles Range Rating on Select Grade
    • Designed from the Driving Lounge Concept, TZ Offers Elevated Experiences and Blends a Quiet Relaxing Cabin with Dynamic Driving Character
    • DIRECT4 All-Wheel-Drive (AWD) Standard on all Grades
    • Available Dynamic Rear Steering Delivers Excellent Handling and Reduces Body Sway
    • Expansive Opening Panoramic Roof with Power Sunshade, for First, Second, and Third Row Scenic Visibility
    • Sustainable Craftsmanship with Details Like Forged Bamboo Interior Surfaces Showcase a Luxury, Bespoke Aesthetic
    • Available Front Passenger and Second-Row Seats Feature Ventilation and Power Ottomans
    • Offers the Standard of Confidence with the Lexus Safety System+ 4.0 Active Safety and Convenience Feature Suite
    • Immersive Multimedia Experience with the Latest-Generation Lexus Interface
    • Vehicle Expected to go on Sale at the End of 2026
    Yes, this is the Lexus equivalent to the 2027 Toyota Highlander BEV. This press release is a little devoid of specs, but it does have the same 76.96 kWh and 95.82 kWh battery options as the 2027 Highlander BEV. I’m assuming it’ll be made in the US with the same US sourced battery found in the 2027 highlander BEV.
    Unlike the 2027 Highlander BEV the TZ is offered only in AWD and herein lies the quandary. Typically Lexus differentiates FWD, AWD, and power difference with numbers like 350, 450, 500, 550, etc.. Not sure how they’ll differentiate a TZ trim with the 76.96 kWh battery or the 95.82 kWh battery. They may just put it under the Premium and Luxury trim tags and call it a day. There is no mention of motors or power, so who knows they may have bigger e-Axles in the rear for higher power, like the RZ 550e. Also unlike the 2027 Highlander BEV one option will be Dynamic Rear Steering (DRS).
    So how does it compare to the 2027 Toyota Highlander BEV overall?
    Dimension or Spec Value
    1 Overall Length 200.8 in.
    2 Overall Width 78.3 in.
    3 Overall Height 67.1 in.
    4 Minimum Turning Radius with DRS 17.2 ft.
    5 Minimum Turning Radius without DRS 19.0 ft.
    6 Tire Size Low 255/55R20
    7 Tire Size High 255/45R22
    8 Towing Capacity Up to 3500 lbs.
    About the same size but 2 inches longer but a touch shorter in height. Lexus says the TZ will have a Cd of 0.27.
