205,000 mile throttle body removed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 05 200k prius, Aug 27, 2015.
  1. 05 200k prius
    05 200k prius New Member
    Birmingham
    WOW! I cleaned it up shiny again but damn
  2. 05 200k prius
    Birmingham
    Another
  3. orenji
    orenji Senior Member
    5,887
    3,488
    What oil do you use? How many miles between oil changes?
  4. 05 200k prius
    Birmingham
    Ive only had the car for a year. Ive put 10k miles on it. Previously i used firestones kendal part sythetic 5w30. Yesterday i swapped to 0w30 full synthetic. I also remove my air intake resonator. I wish i could find out a way to seafoam the engine via a vaccum hose to get some of this crud out
  5. ETC(SS)
    7,474
    Be careful with the Seafoam.
    It's great stuff, but you may wind up killing your catalytic converter.
    Fortunately, Alabama probably allows you to replace it with a used unit unlike some of the more oppressed states that check into such things.
    The throttle body was pretty fodded up, but the injectors are obviously OK otherwise your car would not be running, and if you're getting decent mileage, you may cause more damage than you're trying to repair. ;)
    Good Luck!
    Hope you make it to 300K!!
  6. 05 200k prius
    Birmingham
    Wow! What a difference 0w20 full synthetic, throttle body and maf clean, and removeing the resonator will do. I averaged nearly 80mpg for 17 miles earlier
    orenji likes this.
  7. tony2ltr
    tony2ltr Member
    165
    67
    North Branford, CT.
    I removed the muffler on mine, straight pipe from the resonator to the tailpipe tip
    XT1585 ?
  8. waynedubjay
    waynedubjay Junior Member
    16
    all ova
    Does your car burn oil, as I see your using lower viscosity oil?
  9. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Have you replaced the PCV valve lately?
