21' Prime Illuminated Door Sills :)
Discussion in 'Prime Accessories and Modifications' started by Bandit_22, Feb 10, 2022.
  1. Bandit_22
    Bandit_22 New Member
    Whittier, CA
    2021 Prius PHV
    Just installed this sweet accessory. Couldn't be happier with the results.
    ONeal and Tideland Prius like this.
  2. ONeal
    ONeal Junior Member
    Birmingham, Al
    May I ask a few questions? Where did you get them? Were they plug and play?
    I have '21 LE, just wanting to know if they will work on mine, lol. Thanks!!
    Bandit_22 likes this.
  3. Tideland Prius
    16,678
    They look like OEM ones, so it should apply to your model.
  4. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    The best price I could find for these was here for $168 but I’d imagine someone else has them for less.
    https://parts.toyotaofgreenville.com/p/Toyota_2020_Prius-Prime/Illuminated-Door-Sills/69550997/PT94247161.html
    Part Number: PT94247161
    Supersession(s): PT942-47161 & PT94247160
    OP- am I correct assuming you run a power wire from the bottom front door lights to power the sills? Since the front door lights come on automatically when the door is open and that’s what these do as well? Or is it from elsewhere ? I was interested in getting these earlier but I didn’t wanna tear up the interior. How easy / difficult was it ?
  5. Bandit_22
    Whittier, CA
    2021 Prius PHV
    I got them for just under $200 from my local Toyota dealership. They should work for your 21'LE no problem. Check the VIN when checking out before purchasing to be sure
  6. Bandit_22
    Whittier, CA
    2021 Prius PHV
    You're right. These tap into the power from the footwell lights. It's actually very easy. The hardest
    These tap into the footwell lights and it's a really easy job to install these. So you need is a Phillips, electrical tape, pliers and pair of cutters for the zip ties. The toughest part was getting the included taps to actually make a good connection. Super easy job overall. With a YouTube video it'll be a cake walk. :)
  7. Robert Giroux
    Robert Giroux New Member
    Montreal
    2022 Prius Prime
    Nice!
