215/55x16" tires on a 2019 awd-e?
Discussion in 'Gen 4 Prius Technical Discussion' started by davran, Mar 21, 2019.
  1. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    Hello,
    Three friends are Prius nuts, and I said I'd get one when they offered awd, so I drove an awd-e last night: nice.
    I have almost new 215/55x16" bridgestone blizzak ws80 snows from my last car; will they fit on the Prius? They're only 0.4" larger in diameter.
    Thanks,
    Dave
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Here's the complete comparison of the two tires...I'd say the snows would fit okay
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    What was your previous car?
  4. Mendel Leisk
    42,296
    I would put the old tires on craiglist, get some 195/65R15 snow tires for the prius.These rims are compatible:
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    steel rim lug nuts, part no: 90942-01007 (plain, open-ended, galvanized)
    I found the centre hubs rusted up quickly with the open rim centres, so cleaned them up and capped with 2" ABS end cap (available from Home Depot, Rona, etc). It's a slightly loose fit, but pushing on a rubber band snipped from an old bicycle inner tube, it's a snug fit and haven't lost any yet.
    If you're in the lower mainland, where it's mostly bare roads and rain, Michelin X-Ice are good, run quiet and smooth.
  5. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    '05 vw passat tdi.
  6. alanclarkeau
    7,045
    7,593
    You'd need new rims wouldn't you? - I'd have thought it'd be cheaper to just get a new set of tyres, and sell these if possible.
    knockknock_2 likes this.
  7. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    alanclarkeau, yes, that's now the plan.
    #7 davran, Apr 3, 2019
