22.2 MPG going Uphill 4.7 Miles
Discussion in 'Gen 3 Prius Fuel Economy' started by prius4owner, Apr 11, 2012.
  1. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    :pop2:[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  2. justana
    justana Junior Member
    60
    Have you measured average MPG up and downhill yet?
  3. GWhizzer
    GWhizzer not so Senior Member
    120
    24
    Winnipeg, Manitoba
    Even better, on a steeper downhill regenerative braking will store a good portion of that downhill energy for later use. In a non-hybrid, it would just been burned off and wasted. So even after levelling off the hybrid will get some *free* mileage that a non-hybrid would not. :)
  4. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    We live at sea level and every month or so go up Highway 26 for about 40 miles and get our spring water.
    Elevation at max is 1640 feet. If I reset either trip A or B and
    from a cold start when I reach the first pass which is about
    1,500 feet my mpg gauge is reading about 38 mpg this is about
    20 miles or so into the trip.
    At the 1640 ft level about 10 miles away the mpg gauge will read
    about 42-44 mpg. When we get to the spring water fountain
    it will be about 45 mpg.
    When we return back to sea level the MPG gauge will usually read
    about 50-56 mpg depending on the weather conditions.
    In summer it will be about 56 mpg, in winter 50 mpg or lower, calculated of course will be about 3.5 mpg less than indicated mpg.
  5. prius4owner
    prius4owner Member
    84
    30
    Southern California
    Good News.
    Today I drove the same route downhill 4.7miles. I got 99.9 MPG, and battery with all 8 bars full. :rockon:
  6. hoddy4
    hoddy4 New Member
    118
    NC
    What was your mileage going down hill in the Prius, around 70mpg?
  7. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    I love the tongue firmly in cheek answer.
  8. pacohaas
    pacohaas Junior Member
    56
    You were up on that hill for quite some time ;). Good to see newton's thoughts on energy are still holding true.
  9. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    I just drove up a hill (2.7 miles @ 17% grade) and my scangauge was showing 6 - 10 mpg the whole way up. Worse still, going downhill on it (engine not fully warmed up, but above 159F when I started) B mode was limiting my MPG's to 50 MPG or so. Speed limit was 20 mph with many switchback turns.
  10. walter Lee
    1,126
    376
    Maryland
    (22+100)mpg/2 = est +61 mpg + a full battery :D
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I think his screen display maxed out and his real mpg was higher than 99.9mpg. :)
  12. pacohaas
    56
    Yeah, would need to reset the trip meter before the next round trip for an accurate(ish) round trip MPG.
  13. fuzzy1
    10,691
    You know better than that. 22 up and 100 down really averages out to 36 mpg roundtrip. Even in the more likely case that the downhill mpg was infinite, with the display capped at 100, the round trip can't be any better than 44 mpg.
