225 tires?
Discussion in 'Gen 5 Prius Main Forum' started by potato, Sep 7, 2024.
Tags:
  1. potato
    potato Junior Member
    I just picked up a 2024 Prime XSE. The tires are 195/50R19.
    Yes, this may be early.
    Yes, rolling resistance, mileage.
    Yes, but there's a reason.
    Did anyone try 225 tires? something like 225/45R19?
    Thanks
    P
    #1 potato, Sep 7, 2024
    douglasjre and Xletony like this.
  2. Hotdog453
    Hotdog453 Junior Member
    Ohio
    2024 Prius Prime
    XSE Premium
    Someone calls them out here:
    2023 Prius XLE AWD Snow tire : r/prius (reddit.com)
    "No they are great! The ride and road noise improved. Probably the softer tire. No rubbing. They look pretty good too."
    You're basically worst of both worlds now, though: Large, 19" rim, and a wider tire. I personally downsized to a 17" rim on 215/55/17, which gave me a ton of options, but still "quasi maybe kinda sorta economical", from the 19" on my XSE.
    I had to buy rims though, so it's clearly a cost vs benefit vs desire equation.
  3. Blackat
    Blackat Active Member
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    I'm on 225/55/17. A perfect fit-IMO
    Xse, douglasjre and Xletony like this.
  4. Hotdog453
    Ohio
    2024 Prius Prime
    XSE Premium
    Xletony likes this.
  5. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    The 225/45R19 size suggested in the original post is not officially compatible with the original 19x6.5 wheels, per tyre standards - it needs 19x7.5 to 8.5. That's the sort of detail that could conceivably cause you some sort of legal/insurance bother.
    (215/55R17 and 225/55R17 are fine for the original 17x6.5).
    reservoirblue likes this.
  6. potato
    Wife can't parallel park. She can't change tires. She wants peace of mind to drive A to B. She had run-flat on her Gen-3. Now she wants run-flat.
    The only run-flat suggested by tire-rack is that 225/45-19. So I just wonder if anyone tried 225. I'll see how long I can ignore her request. =)
    Thanks!
  7. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Does your wife plan to pay for the tires that she wants?
  8. Hotdog453
    Ohio
    2024 Prius Prime
    XSE Premium
    It's going to be 'slightly' wider than the 215s other people have run, and they have been referenced as being 'fine' over on Reddit as well, as I linked. *Most* people aren't going to be doing it, simply because it's effectively just <bigger and heavier than the already big and heavy 19>, but I think you'd be fine.
    It might also be worth trying to find, locally, someone to trade your 19s with, for 17s. People like the 19s. Facebook/local groups might be able to align that. Then you'd at least be, ideally, making your MPG slightly better.
  9. Hotdog453
    Ohio
    2024 Prius Prime
    XSE Premium
    I'd say a decent chunk of people are in a shared financial model; I know we are. Her money is my money and all that jazz.
    bbowards22 and Mendel Leisk like this.
  10. Xletony
    Xletony New Member
    Alberta
    2024 Prius
    XLE AWD-e
  11. Winston Smith
    Winston Smith Active Member
    473
    339
    OH
    2024 Prius
    LE AWD-e
    Also so known as "half my stuff is hers" or community property. j/k
    I'd be interested in the reaction to the handling and noise associated with the run flats.
  12. Xletony
    Xletony New Member
    Alberta
    2024 Prius
    XLE AWD-e
    I second this.
  13. Xse
    Xse Member
    76
    34
    Brighton Ontario Canada
    2024 Prius Prime
    XSE Premium
    #13 Xse, Dec 5, 2024
    Xletony likes this.
  14. douglasjre
    2,250
    751
    Null, NL
    Well if she's paying for them then she doesn't need your approval. let her buy the tires and she'll decide if she doesn't like them
