235,000 miles, 2005 Prius suspension refresh.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bunce, Jul 9, 2019.
  1. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I just drove my wife's Prius 2600 miles across the country and it's pretty apparent it needs new shocks. My wife will be driving it back so I'd like to at least get the front shocks sorted quickly while here at her parents house before her return home in 2 weeks.
    I'm considering the KYB KYB Excel-G Gas Strut - plus SR4223 and SR4224
    Front Right - https://amzn.to/2xBGKjB
    Front Left - https://amzn.to/2G2GoXV
    Is there anything else easy and recommended to replace while I'm in there? Or any other tips and tricks I should know?
    Thanks
  2. Patrick Wong
    18,210
    6,517
    #2 Patrick Wong, Jul 9, 2019
  3. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I'm pretty sure those complete units contain those so I think I'm good then.
    The rears definitely need doing to but in the interest of time and impact I'll only have time for the fronts.
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Same struts are 123.00 each on Rock Auto Might be more than Amazon with shipping though. Save your old ones. I have heard stories of some of the strut parts not being as good as original Toyota. The struts themselves are OEM but the other parts???
    Bunce likes this.
  5. Bunce
    Bunce Active Member
    322
    185
    Oregon
    They were cheaper on Amazon, but one of them wasn't in stock so I had to order from Rock Auto.
    Skibob likes this.
  6. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I found a how-to for suspension on here a while back but can't find it now I need it.
    Does anyone have it bookmarked by any chance?
  7. Bunce
    Bunce Active Member
    322
    185
    Oregon
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  9. audiodave
    audiodave Active Member
    800
    272
    US
    The lower control arms sag I'm sure. Causing tire wear on the outsides of the tires.
    Raytheeagle and SFO like this.
  10. Bunce
    Bunce Active Member
    322
    185
    Oregon
    So what does this mean?
  11. Liam howard
    Liam howard Junior Member
    56
    24
    United States
    Four Touring
    What type of symptoms where you experiencing? My 2009 Prius Touring w/ 142,000 seems to still be going strong. The suspension is definitely a little stiff but all in all it is handling like it did when I bought it. The one thing I have been experiencing is a rubbing rusty hinge sound when turning the steering wheel when doing a “K” turn. I did some research and it says that some models have a known steering column defect having to do with “insufficient hardness” of splinders. It seems to be exacerbated by the cold weather. I ran a VIN number search and no recalls have been issued for my vehicle. I think it was a Toyota page if I am not mistaken but this was a while ago. Does anyone suggest any further way to investigate this issue?
  12. audiodave
    800
    272
    US
    Just another part that's worn and needing replacement. Alignment can't be done properly and tires wear fast.
    Liam howard likes this.
