240 volt chargers at home for 2018 Prime?
Discussion in 'Prime Technical Discussion' started by Rainydave, Feb 2, 2019.
  1. MrHockey
    MrHockey Member
    66
    51
    Minneapolis
    2020 Prius Prime
    Thinking 6-20 p
  2. MrHockey
    MrHockey Member
    66
    51
    Minneapolis
    2020 Prius Prime
    Actually told they want to put in 14-50.
  3. john1701a
    john1701a Prius Guru
    12,800
    5,282
    57
    That makes sense. An older lower capacity standard isn't the ideal.
    Rob43 likes this.
  4. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Like John said, it makes sense.
    What's funny is I'm building a ~4ft long 10 gauge 14-50P to 5-20R pigtail tonight for someone so they can use their Toyota OE EVSE at 240 volts.
    Rob43
  5. MrHockey
    MrHockey Member
    66
    51
    Minneapolis
    2020 Prius Prime
    Turns out that my breaker box is basically full and he wanted to add a sub-panel; it sounded expensive and so went to plan B and added a dedicated line (120v) for plugging in the Prime. If/when we get an EV, we will upgrade and seek a rebate from our energy provider. Still waiting on the 2020 Plus or the new base name—it is on a boat in the Pacific. Thanks to everyone that added an idea or thought. Lots of smart folks in Prius Chat World!
    jb in NE likes this.
  6. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    That was my solution as well, for the short term. My house was wired with one 120 VAC to the garage front wall, on the same GFCI as three bathrooms and front and rear house outlets. Not so good when the air compressor kicks on when somebody is running a hair dryer, plus the one GFCI on the circuit is in the upstairs master bath - not so handy to reset.
    So, I tapped into the overhead receptacle for the garage door opener, which also powers the overhead lights and lights in a family room (maybe an amp or so total load there). Put in a quad box there and surface mount conduit over to the garage door end of the garage, put a GFI in there and four outlets on that GFI. Now the car can charge without interfering with the garage power loads. Total cost for outlets, GFI, boxes, conduit and wires less than $75, no charge for my labor.
    At some point I'll pull a 40A to the garage and put in faster charging, but for now the 120 works fine for my needs.
    2018-03-11 14.14.11.jpg 2018-03-11 15.56.05.jpg 2018-03-11 16.56.37.jpg 2018-03-11 16.56.50.jpg
  7. MrHockey
    MrHockey Member
    66
    51
    Minneapolis
    2020 Prius Prime
  8. MrHockey
    MrHockey Member
    66
    51
    Minneapolis
    2020 Prius Prime
    Dedicated 120 v
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    GIF protected? If so, they neglected to put the sticker on it.
  10. MrHockey
    MrHockey Member
    66
    51
    Minneapolis
    2020 Prius Prime
    Yes. Good observation regarding missing sticker.
  11. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    587E0FE0-2971-45A3-9B2F-7BD26203C6A8.jpeg Mine has the sticker, although not shown in my previous post. That photo was taken during installation, before the sticker was added. This is the final install.
    #51 jb in NE, May 22, 2019
