$2400 repair: Junction box & water pump
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jennifercdouglas, Mar 19, 2012.
  1. jennifercdouglas
    jennifercdouglas New Member
    San Diego
    this is my first post, so I'm nervous, really hoping to get some useful input. The gist is that my 2006 Prius would not start, even with an attempted jump, and now the dealer (Keany Mesa Toyota in San Diego) says total cost of repair will be $2400 for a new junction box relay and water pump ($800/$2400). I am stunned at the cost and am questioning the need for both jbr and wp -- but apparently wp is leaking. About a year ago, the expensive battery was replaced, luckily under warranty , so no cost. Don't know if jbr, wp and battery failures are related, typical repairs or we just have a lemon or getting ripped off. is the water pump recall from years ago relevant here? Should we get a competing bid from a non-dealer/Prius expert (is there one in SD, a search of priuschat found 1 recommendation but it was rather weak), or just get the damn work done and have a stiff drink to deal with it, or maybe it is time to get a new car - Prius or other (what's the chance the dealer give us a good trade-in deal?)
    What would you experienced/tech savvy Prius owners do? What questions do I need answers for (from dealer or elsewhere) before making a decision? thanks much for any help! -jennifer
  2. waldhorndude
    waldhorndude New Member
    22
    denver
    There is a inverter coolant pump, which was the "recall".
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    http://priuschat.com/forums/gen-ii-...pair-junction-box-water-pump.html#post1499853
    Per http://priuschat.com/forums/toyota-...tsbs/89220-water-pump-recall.html#post1255411, 2nd gen Prius has four water pumps, not of all which run all the time.
    Can you be more specific about the "expensive battery"? Are you talking about the HV battery pack (the large pack in the silver box) that weighs ~100 lbs. or the 12 volt?
    How many miles on the car?
    Did you by any chance jump the car improperly and reverse the polarity? If so, you could've possibly blown the inverter, which apparently has a 4 digit price tag.
    More details about the consequences of reversed polarity jumping (Patrick Wong is one of our resident repair experts):
    http://priuschat.com/forums/gen-ii-...i-messed-up-what-do-i-do-now.html#post1207131
    http://priuschat.com/forums/gen-ii-...885-12v-battery-adventure-warning-lights.html
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Post the DTCs (error codes) the mechanic pulled from the car's computers
    Have you replaced the inverter coolant pump (under warranty or otherwise) ?
    When was the last time the 12 battery was replaced ?
  5. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The water pump if it is leaking must be the engine coolant pump, an easy job any workshop should be able to do. The junction box relay if that is what they called it is complete BS.
    The pump would not stop the car from starting. The other problem is obviously electrical and should through some fault codes that we kneed to now. It is possible that when you tried to jump start the car you may have connected it up wrong (reverse polarity) if that is the case serious damage can be done, but this is not always the case. Try to get the fault codes and or some more detail.
    Good luck
    John.
  6. jennifercdouglas
    San Diego
    Waldhorndude: thanks. dealer just told me the pump that needs replacement is not the one was that was recalled, bummer. and the other problem is the junction "block" relay (not the junction "box" relay as my husband told me) and it is an electrical problem. When i asked about why it failed, she said the dealer doesn't determine that, only Toyota itself. When I made further inquiries, she said she would call Toyota and see if it would "participate" in covering the cost partially or totally. Not sure if that is a real possibility or just a ploy to appease customers.. Wondering if junction box issue is just random or an emerging problem or what.
    BTW: the car has 85k miles.
  7. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    I've never heard of this as an emerging problem.
    As for them calling Toyota, yes, dealers sometimes do this (sometimes at customer request) to see if Toyota is willing to cover part/all of the cost of some expensive out of warranty repair, out of goodwill.
    If you have a part # for the parts they claim need to be replaced, that'd give us a better idea of what's going on.
  8. jennifercdouglas
    San Diego
    Re: $2400 repair: Junction block & water pump
    The expensive battery replaced under warrantly was the $3k+ one -- I didn't know that it was called "HV". And yes, I will get fault codes and part #. sorry, I am a pretty smart person but know little about cars. :)
    thanks much for your expertise! :D My husband knows more than me about cars and seems apt in terms of jumping ability, but he was distracted and annoyed at the time of 2nd jump attempt (a day after the 1st attemp). and he is a very trusting person, I am not (when it comes to car dealers, financial advisers, and time share salespeople) and wanted to research the situation before forking over $2400. -jen :angry:
    [/quote]
  9. jennifercdouglas
    San Diego
    I'm sure this is a dumb question but re: the engine coolant pump you mention, is it for gas engine and different from the recalled inverter coolant pump for the electric motor?
  10. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Welcome!!
    Unfort the main anti-freeze water pump is a generic leak problem for our models. You can see this by pointing a flashlight down by the fan belt pulleys as pink liquid or pretty pink salts. Mine is leaking at 105K and I am adding Toyota special antifreeze to watch leak rate. Right now my fluid level is holding well but I am confused if there could be air in the system giving me a fake level.
    So that pump problem is expected and your main recourse is cheaper service. The guys here tell me it is DIY doable - medium difficulty level. Pump costs 60 bucks or so but you put new antifreeze in and all that.
    The other stuff is unlucky as I have no repairs up to 105K miles.
  11. Britprius
    5,194
    1,922
    Yes the pump is just the standard coolant pump for as you say in the US gas engine.
    There is no relay on the Prius that is any where near $1000 let alone $2000 allowing $400 for fitting. I am thinking they want to replace the box with the fuses and relays complete under the bonnet (sorry hood).
  12. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    I wouldn't even worry about the pump till I got it running. I think its the main fuse, and if you had to jump it, a new 12v.
  13. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    I strongly suggest you look elsewhere. $800 for the engine water pump is outright highway robbery. The cost of parts is about $175, for the pump and 2 gallons of coolant. Labor is about 2 hours, even though most techs can do it in an hour. With tax, it should be no more than $450-$500. This is definitely a repair that you can put off for a few weeks, just top off the coolant reservoir with a gallon of Super Long Life Coolant from the parts counter.
    Given that they are grossly overcharging for the water pump, it is quite likely that they are trying to take you on the electrical repair.
    SFO and cwerdna like this.
  14. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I agree with this. The only proviso would be if the other work (necessary to get the car running) just happened to involve draining the engine coolant, in which case it would make sense to do the pump at the same time. At this point however, this doesn't seem to be the case.
  15. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Hi Jennifer. A slow coolant leak is a fairly common issue, but it's not a critical problem, so long as you check the coolant reservoir from time to time and never let it run low. It's certainly not the cause of your current (apparently electrical) problem. I think you should get the immediate (no start) problem fixed first, and then you can shop around for the best price on a water pump replacement.
    Given that the problem was co-incident with the jump attempt I think that this was the most likely cause. Once you've needed to jump it the first time you are probably going to need to jump it again soon, so don't get frustrated, just get a new (12V) battery.
    As others have pointed out, the most likely fault after a failed (reverse polarity) jump is either the main fuse or the inverter. If it's just the main fuse then it's a fairly easy fix. If it's the inverter then it's costly. I'm not convinced that the current diagnosis of "junction box relay" is a good one, nor am I convinced that you're getting a good price. I think you should get a second opinion on this, even if it requires forking out some extra money on a tow.
  16. uart
    uart Senior Member
    4,220
    1,212
    Australia
    BTW. Just a thought. Is it possible that the service techs were actually referring to the "inverter" all along but are just calling it a "junction box relay" because they didn't think the customer would understand what an inverter is? This is definitely a strange one. If possible Jennifer, could you get them to point out under the bonnet exactly what it is that they propose changing. If it's the big silver box shaped thing to the left (to the right looking from the front) of the engine, then it's the inverter. If they point to the smaller black box nearby then it's something in the fuse/relay box that they are talking about.
  17. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The inverter is covered to 100,000 miles, at least in my 2010 California warranty Prius. Of course, the warranty wouldn't cover damage caused by an improper jump start. Not sure if they can tell whether you improperly jump started the vehicle.
    Sounds like Repair One is to replace the 12V battery, but the other people in this thread know more about that than I do.
  18. sorka
    sorka Active Member
    1,031
    199
    Merced, CA
    2019 Prius
    49 state, 8 year 100K. California is 10 year 150K.
