2502 Miles 299MPG in a Prius II PHEV!
Discussion in 'Gen 2 Prius Fuel Economy' started by TheForce, Jul 14, 2009.
  1. zcat3
    zcat3 New Member
    117
    35
    SF Bay Area
    How do you start out in EV mode? My Hymotion software forces the S1 warm up when I first start the car.
  2. Tideland Prius
    16,538
    wow... congrats on an outstanding tank!
  3. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    Thats awesome Force! Congrats and thanks for sharing! In light of some of the negative press lately on PHEVs, its critical that there are people like you out there showing it can work!
  4. miscrms
    2,079
    526
    Phoenix, AZ
    One of the frequent criticisms by PHEV/EV naysayers, is that MPG on a PHEV is meaningless. They claim that all you are doing is trading one source of energy for another without making any real improvement in efficiency. Having a set of real world data allows us to examine that claim.
    Standard Prius:
    Fuel Economy: 50 mpg
    Gallons Consumed in 2502 miles: 50.04 gal
    Energy Equivalence: 1686.6 kWh
    Energy Economy: 674.1 Wh/mile
    Force Hymotion PHEV:
    Gallons Consumed in 2502 miles: 8.355 gal
    Energy Equivalence: 281.61 kWh
    Electricity Consumed: 439.56 kWh
    Total Energy Consumption: 721.17 kWh
    Energy Economy: 288.2 Wh/mile
    Mile per Gallon Gasoline Equivalent: 116.95 MPGge
    I think its worth noting here that the energy economy of the Honda FCX Clarity fuel cell hybrid electric vehicle is I believe estimated at 72.8 MPGge
    While figuring the exact energy efficiency of a car is tricky, we can assume that the work done in each Prius is more or less identical, therefore the ratio of energy consumption or energy economies of the two vehicles will be the same as the ratio of the efficiencies. So in this case the energy efficiency is improved by:
    PHEV Energy Efficiency Improvement = 1686.6 kWh - 721.17 kWh / 1686.6 kWh = 57%
    Which is another way of saying Force's PHEV is more than twice as energy efficient as a standard Prius.
    To put a bracket on the "well to wheels" component:
    Worst case electricity generation and transmission efficiency: 33%
    Best case electricity generation and transmission efficiency: 99%
    Efficiency of Petroleum Production: 83%
    Standard Prius
    Well to Wheels Energy Consumption: 2032.0 kWh
    PHEV Worst Case
    Well to Wheels Energy Consumption: 1671.3 kWh
    Worst Case Efficiency Improvement: 17.7%
    PHEV Best Case
    Well to Wheels Energy Consumption: 783.29 kWh
    Bast Case Efficiency Improvement: 61.5%
    So, it would seem that what the PHEV community claims is true. PHEVs can be more efficient than the most fuel efficient car on the road today using pretty much any electric generation source, and that efficiency improves dramatically if we couple the move toward PHEVs and EVs with an increase in renewable and other high efficiency production and transmission projects.
    Rob
  5. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Hymotion.
    I will try to get that data soon.
    I wont help you much on your commute. My estimate for you would be about 75MPG if you can plug in at work and was lucky.
    The Hymotion does not accept regen.
    I'm shooting for 7500 miles this time since Blackstone labs said everything looked great last oil change.
    I do P&G when I can but I mostly try to stay in EV mode. I cant plug in at work. Yet. :( But I can do a round trip on one charge but I cant do all EV on one charge. :mad:
  6. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    7500 miles?? gee Jay, i think i would do synthetic and shoot for 15,000 or more. you are basically running a little less than a 20% duty cycle, so i would look at 3-5 times longer to change. granted, changes in season can affect oil performance, so i might go for a change in mid spring and late fall only.
    how much is an oil analysis?
  7. jeffreykb
    jeffreykb Junior Member
    85
    TX
    Sweet! :rockon:
    Maybe Toyota will show more interest in mass produced PHEVs.
  8. Nova1
    Nova1 New Member
    San Antonio
    How hard was it to install:
    1 EV button
    2 glass break sensor
    3 how well does shark fin antenna work. does it effect GPS or satellite radio?
    4 What does toyota warranty think about ev button?
    I have a 2008 touring and it is my "toy" can you enlighten me more about PHEV conversion kit. ne site said it was ok to run at 70 pmh on ev and another said it is bad for motor and battery? You seem to live in the real world and these upgrades?
  9. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Very impressive energy efficiency, but how about cost effectiveness.
    Factor in the cost of the conversion and how do the figures tally up?
  10. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I just submitted this to digg so everyone DIGG IT! Why did I submit it to digg now? Because I wanted people to know that a plug-in Prius that you can buy NOW can get better MPG than the volt. ;) :D
    299MPG over 2502 Miles in a Prius II PHEV!
  11. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
