264,000 miles, changing the timing chain and everything else involved.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kevin Cecchini, Mar 3, 2019.
  1. Kevin Cecchini
    Kevin Cecchini Junior Member
    44
    Clinton, Michigan, 49236
    Hello,
    I have a 2004 Prius. I have done some maintenance work to the car, bought it with 200K miles on it.
    I have trouble codes, and running rough, with engine light blinking. I removed the valve cover and found that the timing chain was very loose.
    I am going to replace the timing chain, guides, and the water pump, oil pump, serpatine belt, possible the head gasket and anything else I can think of.
    My question to those who have Prius's with high mileage. Is it worth putting this money into the car? I am going to do the work myself.
    My concerns,
    Will the engine itself last, such as the lower bearing and pistons and so on?
    If I replace the head gasket, what else should I replace?
    Am I better off replacing the head with a rebuilt head and if so, is there a supplier that everyone trusts?
    Also, I saw an inverter online at the price of $900. Is this something I should replace as well, I am thinking not, that I will wait until it goes bad, just figured I'd ask that question as well.
    This is going to be a long project, as I am working full time and a full time college student, so I will devote free time to the project.
    If I come to a point where I am totally lost, I am either going to scrap the car or cell it for parts - unless I can find another car around the same year and use this car for parts for the next Prius.
    I am content with my Prius, I would like to think I will never purchase another car for work, other than a Prius.
    Thank you in advance for you information.
    It is greatly appreciated.
    One final thing, I am not in a financial stand point for a monthly loan, and my Prius is costing me less than $500 a year in repairs, this includes tires, a typical year of repairs since I have had it - 3 years, is $200.
    Thanks again,
    Kevin.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    A blinking CEL is indicative of a serious misfire. This is usually a spark plug issue. You may want to check your codes before digging in too deep. I've had 2 Gen2s with ~290k each and they never had timing chains touched. Not saying the problem isn't the timing chain/tensioner, but it's best to check before tearing too deep into the engine.
  3. Patrick Wong
    18,210
    6,522
    I agree that it makes great sense to understand what the logged DTC are before you start replacing parts.
    How long will the engine last? That is dependent upon the extent to which the engine was abused by prior owners, allowing the oil level to drop excessively, not changing oil at 5K mile intervals etc. Certainly at 264K miles on the odometer, any system might fail tomorrow, however any reasonable person would say that the car has already delivered an exceptionally long service life to get you to this point.
    It is possible that the loose timing chain is due to the tensioner only and that the chain itself might be OK.
    Do not underestimate how difficult it is to access that area of the engine while it remains in the car.
    If you take too long on this project, the traction battery may fail due to non-use. Then you will have another problem to deal with.
    Kevin Cecchini likes this.
  4. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    This was my experience with a Gen 3, so the Gen 2 may differ slightly.
    The HG failed at 213k. The timing chain was loose, but still tight enough that it could not jump on the gear. The tensioner was likely between two slots, or the lack of oil pressure caused the slack.
    The car was apart for three weeks, and I have been driving it since July with no HV battery issues. I believe that even though the battery shows one or two bars, there is likely a reserve capacity, or a slight “no draw recovery” that occurs on an extended period of non use.
    Trying to do a head gasket and/or timing chain with the ICE in the car is a challenge, but can be done. There are videos on YouTube showing that it can be. However, with the proper tools, the ICE can be removed out the top in a couple of hours. I don’t see any major obvious reason a Gen 2 would not be similar. In reality, the exhaust manifold, bellhousing bolts, coolant hoses, and passenger motor mount are the only things holding the ICE in.
  5. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    If you were going to remove the engine wouldn’t it be better to just replace the engine with a lower mileage replacement?
    Kevin Cecchini and johnjohnchu like this.
  6. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Every Gen 3 engine out there in the used market is a) overpriced with lunar mileage, b) already suffering from a bad head gasket, or c) a core needing overhaul.
    I rebuilt my Gen 3 head with new seals, and the valves scavenged from the head of the low mileage Gen 4 engine I bought to replace mine.
    My Gen 3/4 Frankenstein now has about 7500 miles since install, or 13,500 total miles. No issues since install.
  7. Skibob
    2,912
    1,505
    Northern California
    You can’t put a gen 3 engine in a gen 2. I meant a newer than 2004 1.5L with less miles. Could be as new as 2009.
  8. Mendel Leisk
    42,352
    probably just reading along on a phone, lost track of the forum.
  9. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Just passing on my experiences. Not meaning to imply putting a Gen 3 engine in a Gen 2. LoL.
    Maybe someone could try putting a C engine in one?? LoL
  10. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    After all, until July last year, it was thought to be impossible to use a Gen 4 engine in a Gen 3 car. I used the Gen 4 short block with a Gen 3 head, and @Ragingfit has put two complete Gen 4 engines in. One Prius and one V.
  11. Kevin Cecchini
    44
    Good thing to think about. I have a prolong charger, so I can charge the battery in a week and check its voltage as time progresses.
  12. Kevin Cecchini
    44
    I had the codes read and 3 cylinders are misfiring. It started acting up in the morning as I took off from a traffic light. I have the timing chain at its proper placement, however, the engine is not at top dead center, so perhaps I need another revolution, I hope, or it is that the chain jumped. It is severely loose and I doubt it was ever changed. Only one owner before me and I do not know their driving style, but the car does not seem like it was ever driven crazily.
  13. Kevin Cecchini
    44
    I did check the codes, 3 cylinder misfires. I checked the newly installed spark plugs and they were fine. One cylinder had oil in it, small amount, nothing serious.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Why change the timing change?
    If a spark plug well has oil in it the valve cover gasket must be replaced as that oil will short out the cop causing misfire. Spark plug well must be clean and dry any oil in it is bad. Because you cannot know how bad it’s leaking or track it’s condition Without pulling the cop out.
    Rolling misfires usually indicate a blown engine especially in a Prius where so many people run there engines out of oil because no one checks there engine oil correctly or periodically anymore. High mileage car requires hyper maintenance.
    One good low oil event that throws the RTOD usually kills the motors. The RTOD is thrown with zero oil pressure. See lots and lots of those on this site.
  15. Kevin Cecchini
    44
    I have replaced timing chain. Guides. Tensioner. Oil pump. Water pump. Serpatine Belt.
    Note. When installing new chain, I made one error. I did not look as to where the lower sprocket lined up with the chain.
    I had the engine in 'top dead center' and both cams were lined up.
    So I put the engine back together with ther lowest sprocket being off by 1/2 a link.
    This will be a learning curve for me.
    My dilemma now is that the coolant in the engine is oarnge. The recommended coolant is clear or yellow.
    So I'm researching to see of these can mix.
    I will then fill the oil and coolant and see if I messed up.
  16. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    Toyota coolant is orange, not clear or yellow. It is highly recommended to use Toyota orange coolant in this engine. Inverter takes the same stuff, but that's a different topic.
  17. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    In my car, the SLLC is pink.
    edthefox5 likes this.
  18. ChapmanF
    19,027
  19. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Yep stock coolant for both the inverter and the engine coolant is Toyota SLLC and it’s pink.
    NortTexSalv04Prius likes this.
  20. Mendel Leisk
    42,352
