27.9 EV Miles Max for Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by dlegate, Feb 27, 2018.
  1. dlegate
    dlegate Junior Member
    30
    16
    SF Bay Area
    I noticed today as I was fully charged and heading down a steep hill that my EV miles remaining was at 27.9 at the top of the hill and didn't go any higher, when I expected it to continue to climb because of B mode and braking. I figured, well, the battery can't hold *more*, so it's maxed out.
    Then at the bottom of the hill, I made a quick right turn and accelerated into traffic, and traveled a good mile and it stayed at 27.9 the entire way, which I was expecting to see it drop quite a bit due to the speed I was demanding.
    Does the meter simply stop displaying anything above 27.9 miles, but the battery still holds more?
    Sure seems that way. Anyone else have a similar experience?
  2. xray22
    xray22 Junior Member
    31
    Vanouver, WA
    I can't explain that phenomenon but I can tell you that I've seen my meter go up to 33 miles after charging (in the summertime).
    52,776
    the 'meter' is not a gauge of how far you can drive in ev. it is a calculation of previous drives plus ambient temperature.
    still, it should go up if your battery is charging. it may be that the battery was full, and wouldn't accept anymore charge.
  4. dlegate
    30
    16
    SF Bay Area
    Interesting...
    Not sure I understand how the "calculation of previous drives plus ambient temperature" is a good estimate, though.
    Although getting 33 in summertime does seem to lend itself to the ambient temperature statement.
    Guess I'll have to keep watching it. Thanks to you both for the feedback!
  5. Wuzki
    Wuzki Member
    101
    34
    los angeles
    How can you get 33 out of ev mode lol... no matter how I drives it I only can max out at 21miles :(
    HPrimeAdvanced and bisco like this.
  6. bisco
    52,776
    it depends on speed, acceleration, terrain, weather, hvac and etc.
    try driving 20-30 mph on quiet back roads sometime.
    HPrimeAdvanced and Wuzki like this.
  7. bisco
    52,776
    it an't unless you drive the same commute all the time, and etc.
    there's no way for a software program to accurately convert battery charge into driving distance, since different types of driving require more or less energy.
    so instead, they just average past performance, and assume your next drive is going to be close to that average. sometimes it is, and sometimes it isn't.
    HPrimeAdvanced likes this.
  8. Oh I've seen it go higher... wait until summer and fall:
    bisco, HPrimeAdvanced and benagi like this.
  9. Wuzki
    Wuzki Member
    101
    34
    los angeles
    That is impossible speed to do in my areas. Max road speed 50-55. Lol I should had buy ev bicycles, if I’m rolling on 20-30 mph
  10. Gianni I
    Gianni I Member
    72
    40
    Long Island
    Interesting conversation as i've had mixed results as well. I plug in at home and plug in at work. My commute is 23.5 miles each way. On the way in to work the most i've ever made it on EV only is with about 1 mile to spare. This morning I actually ran out of EV a mile before I got to the office. On the way home, however, I've had almost 6 miles to spare and I don't think i've ever run out of EV.
    Speed plays a huge part of it as well as weather. I got my Prime end of Dec so I've yet to experience the great milage of summer time. I've gotten close to 27-28 on 50 degree days so I assume that will easily go up during summer time.
  11. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    Now that the weather is in the 40s I am getting 28/29 EV range again. Will be in 30s soon.
  12. bwilson4web
    16,512
    I use the SOC and current %/mile but then I need something to entertain me when driving.
  13. bisco
    52,776
    beatles?
  14. bwilson4web
    16,512
    Severely married, I often drive with ‘terminator’ vision. My wife doesn’t understand it either.
    HPrimeAdvanced and jtv like this.
  15. dlegate
    30
    16
    SF Bay Area
    Very interesting! Makes sense. Thanks!
  16. Digloo2
    Digloo2 Active Member
    124
    132
    Phoenix, AZ
    It's clearly adaptive. Mine started out at 19, and now shows 28+ after charging, apparently based on my driving habits.
  17. Oniki
    Oniki Active Member
    652
    500
    Colorado
    The range meter is no where near as granular as a drive down and up a hill would require to see a change, and that is a good thing.
    Think of it this way: your car has been averaging 29 miles EV per 5.5 kWh for a consumption rate of 189.6 Wh per mile.
    Now you go down a hill, say for 0.2 miles and perhaps gain 100 Wh into the battery. Your new average consumption is 29.2 miles from 5.4 kWh, for a consumption rate of 184.93 Wh/mile. Your consumption per mile rate has improved about 2.5% and so your range will be 29/0.975 = 29.7 miles.
    Not a lot of change, as your can see. The car is not showing the difference because the improved consumption is only during a small fraction of the distance it monitors. If you keep up the lower consumption the software will slowly update the expected range to reflect the presumed future lower consumption.
    But in your actual driving the consumption rate jumped after the downhill, in a sense telling the computer it was right to ignore the first blip ... and the second one too. The alternative is for the range meter to jump up down from a range say of 5 miles to 100 miles with every terrain or acceleration change. You have the instant consumption meter for that data. The range meter is instead trying to guess how far you will go over the next 5 kwh of consumption, and for that it looks backwards over the most recent 5 - 10 kWh.
    I'm not positive, but the range calculation may occur each charge. In between there actually is an acknowledgement by the computer of a range change but it is a little subtle: you range per full charge is the sum of miles driven and miles remaining. If you drove e.g 0.5 mile and the miles remaining stays the same, the computer has estimated that your full charge range has increased by 0.5 mile.
    #17 Oniki, Mar 17, 2018
  18. a_gray_prius
    2,927
    783
    IL
    Our Prime regularly reads 31 miles range after a full charge.
  19. benagi
    benagi Active Member
    525
    280
    Utah
    Since the weather has warmed a bit here in SLC, I’ve been seeing 34 miles per charge.
  20. Garmy
    Garmy Junior Member
    68
    I regularly get 36 on my entune display here in FL. In car it will read 32. Anyone get higher readings?
