2825 Bulb Assembly
Discussion in 'Gen 3 Prius Technical Discussion' started by FacetiousPrius, Aug 15, 2024.
  1. FacetiousPrius
    FacetiousPrius New Member
    Lakewood, WA
    Does anybody know where I can get the assembly that holds the 2825 bulb on top of the headlight assembly? 20240815_110550.jpg
  2. Tombukt2
    Tombukt2 Senior Member
    13,745
    2,487
    Durham NC
    That's a generation 3 the top of the headlight assembly is a 194 bulb I have to go look at my generation 3 that's either plastic twist in or push in either of those can be had I believe that Menards advance Auto online should be real easy that holds the little t type bulb 194 T10 looking base You could also just walk up to another Toyota and clip that same base back a little ways with some wire strip it crimp connect it right up to the correct color wires right where you're broken one is put a new bulb in it usually an LED shove it in the hole and never visit this problem again.
