299,999+ Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Apr 16, 2010.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Thanks for confirming you can go beyond 300k miles.
  2. bigd2010
    bigd2010 New Member
    worcester, ma
    This thread has almost made up my mind on keeping my prius(buying out right) when the lease is up in 32months lol. In the 4months ive owned her i have put 13k miles on the car. So, in a few years I might be with u guys!
  3. 2 fas 4 u
    2 fas 4 u Active Member
    320
    353
    florida
    If I email u the video can u put it in the post as u did the youtube clip of your car.
  4. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Yes, I can!
  5. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    A picture is worth a thousand words. I edit the first post to include those past 300k miles.
  6. Patrick Wong
    18,214
    6,531
    If an owner with an earlier 2G wants to maintain the odometer readout beyond 299,999 miles, maybe s/he can do so by having a current-design combination meter installed and programmed to start at 299,999 or whatever the current reading should be.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I like how you waied untill it read 300003, symmetry is a good thing, even at 60 MPH..[​IMG]
  8. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I wonder which models are affected. We now ruled out 2009 now. If only 2004 and 2005 models were affected, I think Toyota should do a SSC to replace them.
  9. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Just to be clear, 2 fas 4 u sent me that picture to post. It was from his 2009 Prius. He should be given the credit. :D
  10. priushippie
    priushippie New Member
    330
    Pennsyltucky
  11. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    Thats from a 1st generation prius. If you google 299,999 miles you will get a lot of posts in many different forums about toyota and the pontiac vibe(which is a toyota matrix). I have been at 299,999 for quite a while now. If anyone lives around north houston and is interested in seeing the odo, let me know.
  12. phdchp
    phdchp Junior Member
    28
    Birmingham, AL
    Good show! What is the oil consumption for your ICE?
  13. 2 fas 4 u
    320
    353
    florida
    Update 305,000 At 3100 down 8 ounces, i normally change around 10,000 using synthetic.
  14. uart
    uart Senior Member
    4,220
    1,212
    Australia
    That's not bad for an engine with that many miles on it. :) To be safe you should top off (about a pint) at about the mid-point of your oil change interval.
    What weight oil do use use "2 fas 4 u". Do you use xW20 or xW30?
  15. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    oh great!! so my Pri will start using oil when i hit 300,000 miles...yep about time to get rid of it and get something new!!
  16. 2 fas 4 u
    320
    353
    florida
    Was using 0w-30 synthetic from walmart for over 100,000, and just recently started using 5w-30 high mileage synthetic from walmart both are mobil.
  17. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I gather the Euro blend of Castrol 5w30 synthetic is a bit more viscous than most other synthetics. Perhaps it would be enough to stop the drip yet stay on the extended change interval.
  18. 2 fas 4 u
    320
    353
    florida
    Update: 312000 I am trying to pass 345000 from the guy who had the 2001 prius I believe. That is the only one i saw with the pic to verify. If there is someone else who has pic proof of mileage higher than 345000 let me know. ALSO, for those who change their oil every 10000 with synthetic, i was using oil filter 14467 and found 14477 which is the same size but 1 inch longer, so far no effects. With 14467 i was down 8 ounces at 3100 I am at 1600 now will let u know if 14477 will slow down my oil consumption.
  19. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    I really am enjoying following this thread.
    We, europeans, don't usually travel so much as a commute, so is kind of strange watching odo numbers rarely seen here.
    Please continue, don't stop... :)
  20. Bodgerx
    Bodgerx Junior Member
    86
    NY, UK
    312k!!! I am surprised the car stops long enough for you to change the oil! :)
    nssdiver likes this.
