299,999+ Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Apr 16, 2010.
  1. JC91006
    16,743
    8,551
    But your car has a different engine, maybe it'll go to 1 million miles
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    It really is an interesting question. I'd tend to think about it like this:
    Say a $23,000 Prius is good for 400k miles, then each 1000 miles costs $57.5. If a replacement battery costs $2000, the car has to be good for ~ 35k miles after repair to break even.
  3. JC91006
    16,743
    8,551
    well the unknown is if the car itself is holding together. after that many miles, all the bolts start rusting and other repair costs can add up. The upkeep on a Prius's first 400k miles won't be the same for the next 400k miles.
  4. SageBrush
    11,627
    2,533
    Southwest Colorado
    Right, the condition of the car besides the battery matters. But not for 400k miles, more like 35k+ miles.
    The other piece of the puzzle is the owner. Brownsnotouk is I gather a very accomplished DIY'r. That makes repairs much cheaper than for someone who heads to the dealership with any problem.
  5. 200Volts
    200Volts Member
    439
    46
    Northern CA
    399,000 on my 2006 with option #6. In service in July, 06.
    I'm amazed, and so are people that ride in it and see it. Oil, filters, 3 trans fluid changes by me, 2 windshields, wipers, 4 sets of tires, 2 sets of HID lights, 1 pair of LED taillight bulbs, and 1 radio (under warranty). I added soundproofing to all the doors and as much of the dash as possible. Currently averaging 50 mpg with my new Ecopia tires (best mpg, slippery tire in the dry, weak sidewall-not quite as bad as GY Integrity)
    Original batteries, struts, brakes, etc. Yes, the odometer works after 300k miles.
    Lifetime average ~50.2mpg. Typical commute (1 way) is 30 miles 60mph 2 lane, 75 mpg freeway for 75 miles, stop and go for 5 miles.
    Total cost per mile of ownership is insanely low = 14.6 cents/mile:
    $25k purchase, $2k taxes, $1900 tires, $2700 oil changes (mobil 1), $200 HID lights, $150 trans fluid, $550 windshield, $100 misc = $32,600 plus gas (8,000 gals x $3.25/gal avg = $26,000) , plus salvage catalytic convert $600 = $58,600 total = $ 0.146 per mile (insurance not included)
    UPDATE: Sold it for $3,300. So total cost is now $58,600 - $3,300= $55,300 for a new total cost per mile of only $$$$$ 0.138 per mile (insurance not included)
    We'll be buying a Prius V, only because we want more room.
    Read more: 299,999+ Mile Club | Page 33 | PriusChat
    #845 200Volts, Jan 10, 2015
  6. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    WOW! Do you jave a pic of the odometer? did you tell toyota? snoutuk, post: 2020963, member: 44299"]600,xxx today[/QUOTE]
  7. stephensprius
    670
    226
  8. stephensprius
    670
    226
    another prius?
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Why not wait and see Gen4 Prius?
  10. cajunprius
    cajunprius Junior Member
    Lafayette La
    I have a 2005 prius that I bought in 2006 with 35000 miles. Just got to 299999 tonight and its stuck. Looks like I need a new combo meter from what I read. Best car I have ever had. had to replace the transmission at 150000 miles but been going good since. Amy suggestions on where to get a combo meter and should I replace it myself??
    Thanks
  11. stephensprius
    670
    226
    did you ask your local toyota dealership? don't mean to sound too obvious, but i think i would only trust this car to them.
  12. Melchior
    Melchior Junior Member
    74
    Netherlands
    On the subject of 'stuck' odometers, I came across an ad for a Prius here in the Netherlands which said the car has 299,999 km on the clock. Found that a bit of a coincidence but in the photos, there it is to see. Then I read this thread and understand why!
  13. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
  14. almostrice
    almostrice Atari Rocks
    33
    16
    Houston
    I have made it to the 299,999 club. Just been a bit busy to post. I'll need to check the brakes too. almost thought I would not make it with the traction battery failure at 291K this past summer.
    1) Did you replace the HV battery pack? yes 1 module
    2) Did you replace the hybrid transaxle fluid? yes
    3) Did you replace the brake pads? no, but only owned it since 205K
    4) Your lifetime MPG (if available)? between 40-48 mpg
    5) How often do you change your oil? What brand / product did you use? 5000 Toyota 0w20
    6) How about post a picture of 300,000 miles on ODO? no
    7) Are you the original owner? no
    8) How many miles under your ownership? 96k
    9) Feel free to add anything else you wish to share. very economical and dependable car.
    Read more: 299,999+ Mile Club | PriusChat
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
    #854 almostrice, Feb 26, 2015
    SageBrush likes this.
  15. longbow
    longbow Recovering SUV Owner
    62
    34
    Bayfield County, Wisconsin
    I am at 322K now and I will be replacing the Catalytic Converter next week. Mileage is down to barley 40mpg.
  16. Melchior
    74
    Netherlands
    Longbow - how does a 'bad' catalytic converter lead to bad fuel economy? Do they become blocked?
  17. telmo744
    2,181
    769
    Portugal
    Thank you.
    About your module replacement, how much did it cost?
    And regarding brakes, you mean finding a cause to the warning lights in the panel?
  18. longbow
    62
    34
    When the check engine light came on and the code indicated the Catalytic Converter I asked my tech what could I expect if I basically ignored the light. He said that over time I would see a very noticeable decline in mileage and eventually the unit would break up. I have let it ride for about 30K miles now and I have experienced a10-15% decline in mpg. I can barely achieve 40mpg now. Since i intend to keep the car rolling and I drive about 800 miles a week on average it makes sense to drop the $2k on the new unit.
    I checked into after market but after reading many comments it seems to be a crap shoot if they will function properly so I will go with authentic Toyota parts for this one and get the car back to good working order.
  19. Yakoma
    Yakoma Active Member
    470
    125
    sss
    I wonder if Toyota Corporate would buy you a new combo meter. A nice letter explaining the history of your car and how you got to 300K might convince them to invest in you a little for customer sat and some future business. I think it's a no-brainer. Besides, it's no fault of yours that the Toyota design doesn't allow for proper clocking on the speedo. Give it a try.
  20. almostrice
    33
    16
    Houston
    I bought 5 modules from a fellow on ebay for $50. He gave me a deal and I was grateful. I was only trying to save on shipping but he came to Houston and I paid him for the extra modules even though I only needed 1. I bought 3 4x chargers with wires from a PC forumer for $350. I used them to cycle the batteries. In total just under $400. I have 4 of the weakest modules as backup for when another module fails. I can probably recoup the $350 by selling the chargers, but I still have 3 hybrids so I am keeping them until I dont have hybrids. That might be a while.
    Brakes, just lit up. I will check them this weekend.
    telmo744 likes this.
