299,999+ Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Apr 16, 2010.
  1. kammssss
    kammssss Member
    287
    86
    SoCal
    Do you see any difference with gen 2 cells vs gen 3?
  2. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    passed 680,000 last week
  3. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Wow...Can you give us some pics of the odo?
  4. brownsnoutuk
    185
    119
    Shepherd, TX
    Im on odometer #3, 2005 was limited to 299,999 miles
  5. telmo744
    2,181
    769
    Portugal
    So you have 80k on the current odo?
  6. brownsnoutuk
    185
    119
    Shepherd, TX
    actually 190k on the third, I bought them used on ebay.
    telmo744 likes this.
  7. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    What's your secret? :) how's your oil consumption now days?
  8. christinec
    christinec New Member
    Sutter Creek, Ca
    I own a 2005 prius and am at 200,000 miles. What kind of problems, if any, have you had since the 200,000 mile mark?? I am trying to decide whether or not to keep it and try to get another 100,000 miles! Its been a great car.
  9. Jeff54
    Jeff54 Junior Member
    46
    fl
    That's insane, especially, considering the condition you described 'like' 5 years ago. and mostly off road usage, beaten and battered years ago. I can't imagine you could do much other than drive it on a farm, yet that would be 1 HUGE farm too! . I mean, with 5 years ago condition it ought to be just a shell by now. And that would likely mean, you're just running it to power a generator with the wheels lifted, right?
    You've just got to post photos of that amazing car!
  10. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    Only that I paid more for them? Ill ask Toyota. They won't say, though rumors that Panasonic refined mfg problems leading to gen 2 failure?? 7.2 V 6.2 Ah labeled the same.
  11. Paul Schenck
    524
    307
    Fresno, California
    Thats why I chose the GEN3 more recent date of MFG
  12. sciencekit
    sciencekit Junior Member
    76
    Norfolk, VA
    Just reached 299,999 miles on the way back from Florida last night (to Virginia) in my 2004 Prius. Of course, now it is stuck on 299,999. To answer the information:
    1. Rebuilt the traction battery at 147,000 miles. Grrrrrrrrrrr
    2. Replace the transaxle fluid every 100,000 miles.
    3. Replaced the brake pads at 247,000 miles.
    4. Lifetime MPG has been average of 53 MPG.
    5. Oil change every 5,000 miles with Mobil 1 5w-30, and add Liqui Moly.
    6. Pic added.
    7. I am the second owner. Purchased at ~32,000.
    8. Miles under ownership: 267,999 +.
    Aaron Vitolins likes this.
  13. Patrick Wong
    18,210
    6,526
    1. Why Grrrr? It appears your rebuild has lasted at least 153K miles? How did you do the rebuild?
    9. We know it is a vehicle, but do you think the Prius has been a good vehicle or a bad vehicle? :D
  14. sciencekit
    76
    Norfolk, VA
    I was disappointed the traction battery failed at 147,000 miles. That was less than acceptable from Toyota. I was going to order a complete replacement until I did a bit of research. I simply replaced the individual batteries that failed, after ordering them from Japan at the time. The bus was the culprit. I live a block from the beach, and the copper bus is not protected against corrosion, which was the issue. When I rebuilt the battery, I cleaned the bus and coated it with PCB coat to keep it from corroding in the future.
    As for a vehicle, it has been better than most. Absolutely horrible in snow due to the traction control system. However, it has lasted almost as long as my 1990 4Runner, and with less issues, honestly. Even with over 300,000 miles I wouldn't hesitate to drive it across country. I cannot say that for any other vehicle I have owned, if they also had the same mileage.
    Dino33ca likes this.
  15. Patrick Wong
    18,210
    6,526
    Are you saying that you bought new traction battery modules? Who was your supplier and what was the price?
  16. hill
    9,039
    It begs the question - how long will the traction pack last - on the last Gen II Prius to get one changed out.
  17. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    That's profoundly bad advice from a mechanical standpoint. By the time it's "giving you trouble", it's too late.
    It makes you wonder what other preventive maintenance they don't feel is necessary.
  18. telmo744
    2,181
    769
    Portugal
    Or...It's the definition of life by the dealer/manufacturer....
  19. Cuepawn
    Cuepawn New Member
    Las Vegas
    I have an 04 prius, bought at 288xxx miles, now with 2966xx miles. I replaced the combination meter because it has the intermittent non functioning display issues, and Toyota wouldn't replace it (they say they extended the warranty till Sept 30 2013 and won't extend it again).
    The CM I got on eBay is a 2008 (see pictures).
    How do I get the miles put on the new CM?
    Why would the gas gauge not read the almost full tank I had before I replaced the CM?
  20. valde3
    valde3 Senior Member
    2,002
    751
    Finland
