299,999+ Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Apr 16, 2010.
  1. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    I was just going to say the same thing! Love it!
    gta_ likes this.
  2. Bob Greenough
    Bob Greenough Junior Member
    23
    Laguna Hills, Ca
    I have 310,000 Miles on my 2005 Pruis.
    To answer your questions:
    1) Did you replace the HV battery pack? Replaced 1 cell a couple years ago. I replaced the whole HV battery Pack at around 270,000 miles.
    2) Did you replace the hybrid transaxle fluid? No
    3) Did you replace the brake pads? No
    4) Your lifetime MPG (if available)? Do not keep track
    5) How often do you change your oil? What brand / product did you use? Every 4000 - 6000 miles, religiously. From oil change #1....Mobil 1, synthetic.
    6) How about post a picture of 300,000 miles on ODO? The new ODO has 9880 miles on it. 299999 + 9880 is appx 310000 miles. I have attached a pic (see below) of the ODO at 299,999 in Sept 2016. I will get a picture of the current mileage.
    7) Are you the original owner? Yes
    8) How many miles under your ownership? All except 5 miles.
    9) Feel free to add anything else you wish to share. This has been a very dependable car. Other than oil, filters and tires. I have Replaced the following (not in this order).... catalytic converter, inverter water pump (yesterday), timing chain (only because I thought I should). Right head lamp, Replaced one cell in the original HV battery, then replaced the complete HV Battery at appx 250,000.
    I now need to replace the 12 volt battery for the first time.
    MilkyWay, m.wynn, Montgomery and 3 others like this.
  3. raymond genato
    raymond genato New Member
    Rancho Cordova
    I
    My prius is also at 299,999. Is this a limitation of the car. I think that it is extortion to force us to fix this problem when an odometer should go to 999,999. I use my car for business. How am I to bill clients?
  4. Moving Right Along
    Moving Right Along Senior Member
    720
    576
    Texas Hybrid Batteries posted a solution they offer to replace the combination meter with one from a 2006-2009 Prius and copy over your current mileage, which would fix your problem.
    iron-icman likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Can you use your tripmeters until the replacement arrives?
  6. Quincy P
    Quincy P New Member
    Herndon, VA
    My 2005 odometer stuck at 299,999 as well yesterday, did not read the whole topic but I will and I am hoping its an easy fix.
    Bought the car from a used car dealer for 5k when it had 220k on it on 2013.
    Since then I didn't do any maintenance other than cat was bad.
    I cleaned the EV fan 10 days ago.
    Only oilchange and breaks thats it. and got new set of tires.
    I have 89 toyota pickup at 240kish miles.
    Owned a 99 avalon that died with bad clynder at 260k.
    I wrecked 2wd 85 toyota pickup at 320k miles.
    I buy Toyota after 200k miles and it pays for it self and i almost technically drive for free :)
    MilkyWay likes this.
  7. peecee
    peecee Member
    67
    39
    Annapolis, MD
    The fix may be as easy as going to the dealer and ask them to replace the combination meter. I have a friend that said Toyota replaced the one in his 2007 last month.
    If that doesn't work, Texas Hybrid Batteries can replace it, matching your existing actual mileage or closes estimate. Great people to deal with!
  8. dolj
    dolj Senior Member
    8,432
    4,285
    Wellington, New Zealand
    Unfortunately, the fix from Toyota for a 2005 (and 2004) will still result in the CM topping out at 299,999 mi. The 2007 you mentioned will not have this problem.
    The only solution to "fix" the 299,999 mi ODO issue is to retrofit a 2006-2009 Light Cluster (modified to move the TPMS light) and CM such as offered by Texas Hybrid Batteries. Toyota do not have an official fix for this problem on the 2004-2005 Gen II models. If they replace the CM, it will still stop at 299,999 miles.
  9. Quincy P
    Quincy P New Member
    Herndon, VA
    Thank you dolj.
    I was trying to share this moment of my life with my subscribers and found out that it was the longest mile I've ever driven :D then found this forum post and linked your post under my video.
    MilkyWay and Aaron Vitolins like this.
  10. Shane Burns
    Shane Burns Member
    94
    126
    SoCal
    For those who wondering about brownsnoutuk's car
    Well... we can agree that Prius is extremely reliable! Maybe little too reliable ;)
  11. Tanderson82
    Tanderson82 New Member
    Covington, LA
    That fixed that "too reliable" I have a 2010 and the engine knocks when the battery is at two bars or three bars ( If you search, that will be popular). We have had issues with the intake manifold and the EGR valve love this car. No CEL yet. I want the miles that you have on yours. I bought this car to defy the perceptions that have been on the Prius.
    Data Daedalus likes this.
  12. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    1) Did you replace the HV battery pack? No
    2) Did you replace the hybrid transaxle fluid? Twice
    3) Did you replace the brake pads? 3 times front once rear
    4) Your lifetime MPG (if available)? 45.4 mpg
    5) How often do you change your oil? What brand / product did you use? every 5,000mi Mobil 1 Synthetic
    6) How about post a picture of 300,000 miles on ODO? I will add a pic when I remember to take one o_O
    7) Are you the original owner? yes
    8) How many miles under your ownership? all
    9) Feel free to add anything else you wish to share: Never thought it would last this long! https://priuschat.com/posts/2548591/
    MilkyWay, m.wynn and Shane Burns like this.
  13. valko
    valko New Member
    US
  14. valko
    valko New Member
    US
  15. valko
    valko New Member
    US
    Just hit 300000
    ImranAs'hab, m.wynn and Shane Burns like this.
  16. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    That's great!!! Congratulations :cool:
    Could you please fill in the questions above to keep up the data input for the thread? ;)
    Raytheeagle likes this.
  17. Priusyipee
    354
    269
    Upstate New York
    Shane Burns and m.wynn like this.
  18. John Kinney
    John Kinney Junior Member
    OK another update.
    I currently have 461,000 miles on my 2005 Prius.
    I recently blew out a few fuses while using a new USB/LIGHTER/POWER supply thing.
    That took me 3 weeks to get all the "mini" fuses checked and find the culprit.
    (NOTE: Be careful when messing around with the lighter accessories.)
    1. For the last 100,000 miles I have been using the cheapest possible WALMART OIL I can find. No more synthetic. I have not noticed the slightest difference at all. I still burn about 1 quart every month or so. I burn much less if I keep speeds below 75 MPH.
    2. Had to replace the CLOCK SPRING in the steering wheel. Not a bad job 2 or 3 great youtube videos on how to do this. I now have to do the same job on my Wife's 2004 (180,000). BTW: Bought new on either Amazon or Ebay. I find Ebay really good for used car parts.
    3. Finally starting to get some surface rust behind driver side rear door. I have been lightly sanding and repainting with silver matching Toyota paint from Advanced Auto. Can lasts me about 2 or more years for all the touch ups. Mainly on the hood and lower front end, from the long Western NY winters.
    4. Have been really impressed with the interior/rug cleaners found at the big box car parts stores. Especially for the stock floor mats.
    5. I can say that my car rides better than my Wife's 2004. I had the struts and springs replaced on mine. I am going to have hers replaced next spring. Her car tends to float and drift more, mine is firm and true. Cornering is still soft, I never installed a sway bar.
    6. Stopped using Michelin Defenders and now use a cheaper 100,000 mile tire from Mavis (just came out).
    7. Needed headlight so decided to try this bulb from ebay. I like it but there is only one setting, no high beam. They are super bright, have to aim bulbs down low to not blind people. I am not kidding.
    PHILIPS COB H4 HB2 9003 200W 20000LM LED Headlight Kit Hi/Lo Power Bulbs 6500K
    ITEM PRICE:
    US $46.70
    8. Also use a great app on ANDROID GALAXY called "TORQUE". It is absolutely amazing. Scans for codes, clears codes, saves trip data, checks coolant temps, RPMS, gas mileage, GPS information, altitude, compass, create multiple car profiles all customized.... and more. Just have to purchase a OBDII reader for under the dash by the steering column. That's for the latest update. I bought this one.
    BAFX Products 34t5 Bluetooth OBDII Scan Tool for Android Devices
    Sold by: BAFX Products
    $21.99
    9. That it until I get passed 500,000. Should be next spring some time.
  19. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    465k miles
    The battery just went the day we picked the car up from Toyota after getting the driver's side hub assembly replaced. We have done the shock twice, catalytic converter, new dash, brakes once (!), lots of tires and oil changes and new headlights. That's it!!
    My job is 62 miles away and we travel from NY to PA every week. My car before this was an XJ8 Jaguar which died at 60k miles with everything wrong with it. I miss having a "nice car" but I sure don't miss living at the Jaguar dealer and spending thousands trying to fix it. The Prius has been incredibly reliable and low cost.
    #998 JMalmsteen, Aug 17, 2017
  20. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Thats VERY impressive! What year? How many times did you get hybrid battery fan cleaned?
  21. JMalmsteen
    287
    266
    It's actually at 469k miles and a few thousand more because the dash wasn't working (husband corrected me).
    I have never gotten the fan cleaned. I never heard of doing that until now! The car is a 2007. We are getting Toyota to put in a new battery
    Shane Burns likes this.
