299,999+ Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Apr 16, 2010.
  1. DMC-5180
    DMC-5180 Active Member
    294
    134
    Correct.
    Fwiw, NEVER was not mentioned or suggested in my post.
    Change filter once between Complete Oil Changes was.
    iPhone X ?
  2. dolj
    dolj Senior Member
    8,655
    4,405
    Wellington, New Zealand
    Sorry, I didn't mean to imply it was.
    I was merely trying to circumvent anyone taking your advice and extrapolating the logic to arrive at the conclusion that they now never need to change their oil.
    Sorry again for the misunderstanding.
  3. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    How did you rack up so many miles?
  4. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    I'm not quite there yet at 282K miles. Would have flow by it two years ago had I not been using my Tesla as my primary commute car (260 mile round trip).
    The only issue that has been repaired so far has been the combo meter (replaced by Toyota under enhanced warranty) and the coolant diverter valve. 5 minutes for me to replace it with one bought on Amazon.
    The cat failed several years ago. I'm not spending $2K on a CARB cat. If I were out of state, this would be a cheap fix. I tried the oxalic / citric acid bath which lasted about 3 months but it failed again after that. It last long enough to smog it. It's coming due again this September.
    I also proactively replaced the TPS units the last time I got the tires changed since they were 10 years old already and I didn't want them to fail and have to pay to dismount a tire solely for the purpose of replacing the sensors. They were $35 each on Amazon. I used my Techstream to program the ECU for the new ids.
    At current rate, should hit 300K in about 9 months.
    My mom just bought a 2007 with 118K miles on with a bad traction battery and she didn't know it. It's throwing P0A80 and P3018 codes constantly and going into limp mode every few miles.
    SFO likes this.
  5. audiodave
    audiodave Active Member
    800
    272
    US
    I had a cat sent to a friend out of state than to me to fix that issue.
  6. DMC-5180
    294
    134
    Interesting end around move. What was the difference in cost and cat?
    iPhone X ?
  7. audiodave
    800
    272
    US
    Magnaflo cat. Cut the pipe and clamped it myself. 350 plus the shipping. Not paying 1700.
  8. DMC-5180
    294
    134
    The toyota price seems extreme. Is there something special about it other than you live in CA?
    iPhone X ?
  9. audiodave
    800
    272
    US
    It's just California. Magnaflo one meets the carb requirements but California hasn't signed off on it. Bullshit
    pashko90 and SFO like this.
  10. DMC-5180
    294
    134
    Okay, just wanted make sure it wasn’t some magic pixie dust ingredient that had to be added to a CARB qualified cat vs one in any other state.
    iPhone X ?
    audiodave likes this.
  11. popptj2001
    popptj2001 Member
    79
    52
    Winning!
  12. DMC-5180
    294
    134
    Awesome . How many Pack changes?
    iPhone X ?
    telmo744 likes this.
  13. Sparky’s Mom
    Sparky’s Mom New Member
    Orange County, California
    Paul, my Sparky (Red ‘07) only has 160,000 but can I keep in touch with you as she gets older because, I’m going to want to keep her for as long as possible!
    #1053 Sparky’s Mom, May 9, 2018
    Paul Schenck and markabele like this.
  14. nssdiver
    nssdiver Me digging' life
    Syracuse, NY
    Four Touring
    My hero!
    Coming up on 300kmi myself.
    I feel like a rookie...
    iPhone ?
    Paul Schenck and telmo744 like this.
  15. gordonmcds
    gordonmcds New Member
    Auburn, WA
    It stays at 299,999. Mine has been there for about 50,000 miles. But that's an educated guess. I'm using the trip computer to track mileage. Today, the drive battery that I replaced last year failed again. It's under warranty but I just need to get it to the shop. They said that because the catalytic converter is throwing a P0420 code that caused the drive bat to fail prematurely. I don't think that's possible or true.
  16. dolj
    dolj Senior Member
    8,655
    4,405
    If that is the level of their competence, I'd give them a wide berth. Shame you are locked into the warranty.
    You got that right. Sounds lie they are grasping at straws, looking for any reason to squirm their way out of the warranty.
  17. audiodave
    800
    272
    US
  18. Tim Hayes
    Tim Hayes Junior Member
    Pittsboro
    2009 just crossed 300K! Original batteries, original brake pads. Still gets 46 mpg..eats oil. Only thing replaced has been the coolant control valve and the catalytic converter.
    VFerdman, m.wynn, nssdiver and 3 others like this.
  19. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    Wow that is amazing. I’m hoping to get mine to 300k. It has 260k at the moment and I drive 27k a year. Still on the original pack and gets 46mpg.
  20. Karen O.
    Karen O. Junior Member
    SF, CA
    2019 Prius Prime
    my 2004 Prius is at an estimated 350k or so. odometer stopped at 299,999. it's just now needing a new battery, having never replaced the original. has needed a new catalytic converter, but i'm waiting on that until i need a smog check - due next year. haven't done anything to it other than usual car replacement things. have been trying to figure out if it's worth replacing the battery now ($3k) and then the cat in a year ($2400) or get a new Prius... haven't found much online yet to give me good guidance on what to do, so i'm leaning towards replacing the battery for now and making the call in a year...
    m.wynn and VFerdman like this.
