299,999+ Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Apr 16, 2010.
  1. nssdiver
    nssdiver Me digging' life
    Syracuse, NY
    Four Touring
    Because I had to: IMG_7924.jpg
    iPhone ?
    m.wynn, Banksy, Paul Schenck and 7 others like this.
  2. BLNT
    BLNT Junior Member
    37
    Hungary
    I just had a chat with Matt from Rhode Island on his Prius experience and to what car should a person owning a 2008 with 347k miles and no issues upgrade to.
    Matt is the first owner of a 2008 Prius that now has 347k miles (555k kms). His Prius is holding up nicely without any major faults. Original ABS actuator, hybrid battery. Inverter coolant pump changed during a recall.
    Matt is the second person on the podcast who has a 350k miles Prius with no major issues. We talk about his hybrid journey, examine Toyota's hydrogen and EV line for 2020. If you are interested in hearing the full chat, here is the link to the episode:
  3. GoingGreenDetailing
    GoingGreenDetailing Junior Member
    46
    Raleigh, NC
    Just acquired 2009 Prius with 364k miles that I intend to daily drive. Throwing P0420 and P0301 codes. Wish me luck!
    nssdiver and ozzy1 like this.
  4. dolj
    dolj Senior Member
    8,361
    4,260
    Wellington, New Zealand
    Fix the P0301 (plug, coil or injector) and then wait a bit to see if it helps with the emissions thereby getting the P0420 to clean up.
  5. GoingGreenDetailing
    46
    Raleigh, NC
    Thanks for the heads up!
  6. JBuckPrius
    JBuckPrius Junior Member
    64
    Knoxville, TN
    When was the combination meter recall work done? We're there time and mileage limits on the recall?
    Pixel 3a ?
    nssdiver likes this.
  7. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    Combination meter "enhanced warranty" valid for 10 years from date of purchase.
    JBuckPrius likes this.
  8. sorka
    sorka Active Member
    1,017
    197
    Merced, CA
    2019 Prius
    There was a time limit but no mileage limit. It expired years ago.
  9. AlaskaLad
    AlaskaLad New Member
    Juneau, AK
    Prius is at 310,000 miles and is only now having a problem that Ive joined PriusChat to see if anyone can help with
    telmo744 likes this.
  10. bigblock67
    bigblock67 433K with new cells
    171
    35
    Indiana
    2002 Prius
    Didn’t have any Odometer issue at 300k and also 400 k. Doin it’s job proper.
    Mine just keeps ticking.
  11. bigblock67
    171
    35
    Indiana
    2002 Prius
    What issue?
  12. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
  13. telmo744
    2,181
    769
    Portugal
    The Odometer "limit" was with the 2Gen up to 2006 or 2007, only, AFAIK
  14. dolj
    dolj Senior Member
    8,361
    4,260
    It affected 2004 - 2005 Gen 2. They fixed it in the 2006 - 2009 facelift.
    Post your question in a new thread with all the details in the Gen 2 Prius Care, Maintenance & Troubleshooting forum. Someone will be along then to see if they can help you.
    #1194 dolj, Aug 23, 2020
  15. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    I just did my 310k oil change. I’m doing extended oil drain intervals since I burn about 2-3 qt of oil anyways lol it’s like having an oil change. Anyways my only issue is cat converter is going out so I have the a420 code (I think that’s the code). I just reset it’s d drive like or normal. Oh and my paint is super peeling but that’s my fault for not waxing it. It’s pullin dog duties and Home Depot runs. Still Impressed by this car. Aside from rattles the engine is solid. I really think it came make 500k.
    #1195 golfmk681, Aug 24, 2020
    nssdiver, Raytheeagle and telmo744 like this.
  16. nssdiver
    Syracuse, NY
    Four Touring
    Once in a lifetime reading
    iPhone ?
  17. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,518
    Bay Area, California
    2019 Prius Prime
    Hopefully going 12 mph at the time didn't put you in a precarious position;).
    But a good unique one(y).
  18. ecprius
    ecprius Junior Member
    26
    Livermore, CA, USA
    I hit finally hit 300,000 miles in my 2004 Prius.
    1) Did you replace the HV battery pack? No.
    2) Did you replace the hybrid transaxle fluid? Yes, once at 120K miles service.
    3) Did you replace the brake pads? No.
    4) Your lifetime MPG (if available)? 50.7 per MFD, 49.9 calculated.
    5) How often do you change your oil? What brand / product did you use? Every 5K miles, changed by dealership.
    6) How about post a picture of 300,000 miles on ODO? Looks just like 2006 - 2009 odometers at 300,000. See 9) below.
    7) Are you the original owner? Yes.
    8) How many miles under your ownership? All but 5 miles which were on odometer when I bought it new from dealer.
    9) Feel free to add anything else you wish to share
    I want to thank everyone on PRIUSchat for the things I've learned about my 2004.
    A big THANK YOU to Matt at Texas Hybrid Batteries for offering the upgrade odometer kit so I can see my mileage past 299,999!
    Matt programmed the newer CM with 299,961 miles to match my original one at the time of the swap.
    $150 (after return of old CM) was a big savings over the $700 - $800, and $1400 estimates that two local dealers quoted me.
    The DIY swap was easy. I also fixed my MFD, which, in the last few months was slow to come up and even slower to populate the data.
    Big thanks to Hobbitt for showing how to fix the hairline crack at pin 60 of the big connector.
    Overall, the Prius has been a great commute car that I would highly recommend, especially for someone who keeps their car for a long time.
    cwerdna, Fred_H and SFO like this.
  19. maximusdec
    maximusdec Member
    108
    You are still getting 50 MPG...thats impressive. My 2007 with 250k miles gets 44 MPG and I thought that was pretty good. Also didn't know the ODO didn't count passed 300K. I
  20. dolj
    dolj Senior Member
    8,361
    4,260
    On 2004-2005 Gen 2s only and it doesn't count past 299,999. The limit was removed in the mid-life facelift.
