Featured 2G Prius Plug-in Reveal - March 23 @ 9:10 am EDT - Live Stream here
Discussion in 'Prime Main Forum (2017-2022)' started by PRPrius, Mar 15, 2016.
  1. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    I OTOH want the engine to fire if it is going to be more efficient to save those precious KWh.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I, and I think most others, figured that based upon your question Segiospl, but you asked a question and was just answering it.
    Sergiospl likes this.
  3. austingreen
    austingreen Senior Member
    13,677
    4,214
    Austin, TX, USA
    That isn't what most buyers of phevs say. They want to use all their electricity and the least gas. If its a longer trip they want the option of a button, not a engine that will simply fire up going on the freeway. I am sure the prius prime does better here from user feedback, than the first gen prius phv.
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    A reason given to us why Prime allows for less engine startup and more pure EV is because of owner and driver feedback of the gen 1 PiP, so I have to agree with you austingreen.
    There is nothing wrong with how some feel, such as sergiospl, heck, it makes sense to want to maximize KwH. But that still doesn't mean that more people than not want EV when they want EV, irregardless of what 'makes sense'.
    I can't wait to be able to drive a Prius Prime in depth (man, that still sounds strange to say LoL!) and see just how it all 'operates and comes together' in real world driving this second generation go around.
  5. bisco
    51,996
    agreed. i think john 1701 is in serge's camp. but as usbseawolf put it quite awhile ago, at todays gas prices, most of us are being inefficient by plugging in at all. i do like driving ev though. and i'm not sure of pollution consequences, but i do think less gas burned equals less middle eastern problems.
  6. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    A separate discussion from what we're talking about here for another forum, lol ;)
    Linda likes this.
  7. Mister MMT
    Mister MMT Active Member
    285
    142
    Germany
    Well, with the Prime, you definitely can floor it, and take off faster then in hybrid mode, without firing up the ICE:
    This graphic taken from the Toyota Japan site, shows time in the base and acceleration on the left. During the first seconds, in EV (red) the Prime accelerates quite a bit faster then in HV (blue). It should do a real quick 0-60 mph.
    Of course, this applies only after having selected EV driving and as long as the HV-batterie pack is charged enough to allow driving in EV-mode. After that, the Prime becomes a 4th gen Prius, said to be keeping its 52 mpg consumption rate, and running much like a 1st gen Prius Plug-in.
    Bisco said:
    Is that not a good reason to plugging in as often as possible?
    Why is this?
    The one-way clutch in the new PHEV hybrid system ends up blocking the ICE, preventing it from turning backwards and firing up. This bundles the power output of the motor and generator. Together, they provide 53 (MG2) + 23 (MG1) = 76 kW (102 HP), which is largely sufficient for the battery power output of max 68 kW (91 HP)! For comparison, a Leaf disposes of 80 kW (107 HP).
    If you want to reach 22 miles EV-range or more, it is better not to floor, but you'll still get a nice acceleration. The same holds for driving uphill. Driving downhill subsequently, will reload in part your battery.
    I think most readers here knew that, but I repeat it just in case.
    Jan ;)
    Ackowledgment: much of the information cited here can be found in a clear and accurate article written by Hortevin on Hybrid Life.
    #507 Mister MMT, Mar 27, 2016
  8. Sergiospl
    3,938
    1,351
    28
    #508 Sergiospl, Mar 27, 2016
  9. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I doubt that. I'm guessing with "only" 68 kW that the Prime will be accelerating relatively sedately as it approaches 90 mph and it's top electric-only speed is limited to 84 mph.
    The leaf is not really heavier. There are 3 trims. The cheapest is lighter at 3256 pounds than the Prime's nominal 1510 kg (3329 pounds), the middle trim of the LEAF is heavier by 13 pounds, and the third trim with the 30 kWh pack at 3391 is about 62 pounds heavier than the Prime.
    #509 Jeff N, Mar 27, 2016
    Mister MMT and Redpoint5 like this.
  10. bisco
    51,996
  11. Mister MMT
    285
    142
    Germany
    Correct, I already had corrected it.
    The Prime will never be a sports car, but acceleration in EV will be MUCH better then the 1st Gen
    Jan ;)
    austingreen likes this.
  12. austingreen
    13,677
    4,214
    Austin, TX, USA
    I think he was issuing an opinion which he clearly said was at odds with the majority opinion.
    Nope no quote of john? Do they even know each other?
    We have tens of thousands of surveys saying people want phevs to keep the engine off most of the them if there is available battery, but want a button to choose engine on. Then we have a great hypermiler saying he disagrees.
    If you are trying to sell the cars I would listen to the tens of thousands of phev customers not an individual reviewer. Note plug-ins reduce the need for hypermiling ;-).
    Ursamajor likes this.
  13. Tideland Prius
    16,559
    There are lots of car parks in Canada and the U.S. that are open air with little shade. In those situations, you might as well have the solar roof charging the battery. Of course it doesn't help to have additional heat from charging so hopefully there's a way to keep the battery cool.
  14. bisco
    51,996
    one of the problems of ev in its infancy, is that efficiency is not a big consideration. the buying public simply wants to know how far will it go.
  15. austingreen
    13,677
    4,214
    Austin, TX, USA
    Perhaps the idea that efficiency trumps gas usage is the misconception. As plug-ins mature gallons per year will be a much better metric than mpg after the battery runs low.
    There is a trade off of acceleration and mpg versus battery size, but the bigger one is can the battery fit. In the prius prime it appears that the suspension couldn't hold the bigger battery and a 5th seat, something I expect rectified in the next generation, or better range.
    It appears that mpge charge deplete, mpg charge sustain, price after tax credits, gallons per year, and price after credits all improved.
    What are people looking backwards towards a smaller battery and less electric acceleration and range?
  16. bisco
    51,996
    doubtful. but i think if there was a fifth seat and flat deck, there wouldn't be a single complaint. but eventually, as we swing to more ev, i would like to see kWh per mile, or some such.
  17. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Yes. We go way back. In fact, it was during a heated exchange with me that the term "hypermile" was first coined.
  18. bisco
    51,996
    you had a heated exchange with someone?:p
  19. Sergiospl
    3,938
    1,351
    28
  20. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    When was this?
