Featured 2G Prius Plug-in Reveal - March 23 @ 9:10 am EDT - Live Stream here
Discussion in 'Prime Main Forum (2017-2022)' started by PRPrius, Mar 15, 2016.
  1. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    A state-of-the-art solar panel would still be a gimmick if it's used to charge the traction battery.
    What isn't a gimmick, is a state-of-the-art 5th seat.
    Ashlem and Trollbait like this.
  2. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    According to your seat-of-the-pants calculation....
    51,996
    toyota may well be able to plan for southwest heat without special cooling. what did nissan change in the leaf after the problem occurred?
  4. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    After 2-3 years they changed the battery chemistry slightly to supposedly have better heat tolerance but they strangely did not change to use active cooling if any kind in the LEAF. They did add active air cooling in the small commercial van that is based on the LEAF's powertrain.
    The consensus among LEAF owners is that the newer battery is doing better, I think, but a fair number of owners are wanting better temperature management in a future BEV.
    Toyota is claiming that the Prime battery chemistry is more heat tolerant than average.
    Tracksyde likes this.
  5. bisco
    51,996
    thanks, that's what i figured. i'm sure toyota is planning to get it over the 100,000 mile warranty in the hot states, or 150k if any of them are carb, but i don't think so.
    active cooling might provide longevity beyond that, or less degradation during warranty, but they probably aren't concerned about that. we know they aren't on the lift back.
  6. Trollbait
    12,543
    Many of the Leafs that developed problems spent a lot of time with a full battery sitting in a hot garage. A fan alone wouldn't have helped.
    And how possible will that raise the price?;)
    The new chemistry are referred to as lizard packs.
  7. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    Re: solar what I really want to consider, if technically possible, is putting small panel on the house and power a wireless charger from a small 12v batt storage system, and I don't care if I only get 10 miles EV as that would get me around town.
    #567 wjtracy, Mar 30, 2016
  8. Redpoint5
    1,026
    509
    Portland, OR
    You might as well utilize "net metering" if your utility allows it. That would be way more efficient and cost effective than having another battery at your house. There are losses (significant with lead-acid) when charging a battery, and again in all of the voltage conversions.
    You'd still want the car to charge even if the solar panel hadn't produced enough that day.
  9. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    Yes, that will be another question. Probably at least 500 dollar or euro, given the materials that are needed. But maybe they will ask much more for it.
  10. Trollbait
    12,543
    If you want to deal with the extra batteries, try farm supply stores for info. They have solar and wind systems for 12 volt electric fences.
    wjtracy likes this.
