2g wheels on 3g?
Discussion in 'Gen 3 Prius Main Forum' started by PA Prius, Dec 9, 2015.
  1. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    Do 15" wheels from 2G fit on 3G?
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    You might do worse than to visit TireRack.com and check out what they suggest when you put the two sets of data (year, make, model into their package-builder). They recognized the subtle differences between the 2009 Gen II base and touring packages. I think provided the offsets and BCD information were the same there shouldn't be any problems! - hope this helps
    PA Prius likes this.
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The offsets are the same for the 15" wheels. So are the bolt patterns. There were no 17" wheels on the GII, it was 16". The offsets on the 16" GII and the 17" GIII wheels are different. There is a slight difference between the two 15" wheel rim designations. They will probably work, as some on this forum use their GII snow tyre wheels on their GIII.
    But, as always, when using non-OEM parts you are fully responsible if there is something not right.
  4. PA Prius
    762
    251
    SE Pennsylvania
    Thanks, that's what I'm considering, we're looking at upgrading to a G3 and I was wondering if I can keep my G2 snow tires/wheels for the G3. It sounds like it shouldn't be a problem.
  5. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    I did, the alloy wheels are melting but the tires still hold air, 15" wheels.
    The gen2 was traded with aftermarket 17" wheels that needed to go away ;)
  6. PA Prius
    762
    251
    SE Pennsylvania
    "melting" ??
    Hasan likes this.
