2nd gen Prius a safe reliable buy?
Discussion in 'Gen 2 Prius Main Forum' started by blargity, Jan 21, 2019.
  1. VFerdman
    VFerdman Senior Member
    1,186
    1,215
    Western Massachusetts
    K&N filters are usually reusable, vs. disposable. That's the difference. Again, performance increase may or may not be important here, but if you buy a K&N filter, you never need to buy another one, just clean and re-oil.
    blargity likes this.
  2. George W
    George W Senior Member
    911
    514
    San Antonio
    If you watch product comparison videos, NAPA Gold line of filters is a good alternative for OEM.
  3. oil_burner
    oil_burner Active Member
    249
    126
    I usually buy iridiums because they last the longest, but on the Prius I think my next set is going to be copper tips because if your car burns oil, the spark plug will need changing way sooner because of deposits on the tip long before the actual electrode is anywhere near wearing out.
  4. mjoo
    mjoo Senior Member
    1,159
    1,328
    Michigan
    Couldn't you soak the spark plugs in something to remove the deposits?
    Pixel XL ?
  5. oil_burner
    249
    126
    I don't know if anything is strong enough to remove those carbon deposits, if it were, might require several days of soaking.
  6. JC91006
    16,769
    8,567
    Carburetor cleaner?
  7. Lightning Racer
    Lightning Racer Active Member
    239
    321
    Anchorage, Alaska
    Heat from a propane torch.
  8. George W
    911
    514
    San Antonio
    notice he says that he doesn't do this on his cars! only his power equipment.
    #148 George W, Feb 11, 2019
  9. Lightning Racer
    239
    321
    Anchorage, Alaska
    He said that's only because of the time it takes to access the spark plugs in cars, not the effectiveness of the cleaning. But since this thread turned to discussing how to clean spark plugs, the video does belong. You can decide for yourself if it's worth saving the money to clean vs. the possible hassle of taking them back out again. It'd be a good idea to not replace the wipers and cowl before testing out how it worked though.
  10. George W
    911
    514
    San Antonio
    Sounded to me like he said the reason he didn't do it on his cars was because of the time in the expense, that one should go ahead and do those right
  11. Lightning Racer
    239
    321
    Anchorage, Alaska
    That's an answer to a question not asked by the posters wondering about the best way to clean carbon build up from spark plugs. Every can decide for themselves if it's worth the effort to try to clean them.
    I can see doing it if I had a propane torch in my tool kit. If you are trying to diagnose a misfire for example like I was did a while back, I was already switching plugs and coils around and seeing if and what the misfire follows. It would be trivial to try the torch. It's not like you are going to button up everything (wipers/cowl) until you have everything sorted.
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Personally?
    I'd evaluate the cost of carburetor cleaner, or any other solvent against the value of my vehicle, and then factor in the cost of a brand new set of spark plugs, and the possible greater efficiency they would bring....and probably just buy a new set of spark plugs.
    It's your car, it's your engine, good functioning spark plugs are vital to it's operation, IMO not worth saving a few bucks trying to resurrect a aged, fouled set.
    I'm all for thrift, but given the overall investment our vehicles represent, sometimes the things people do for minimal savings, don't seem to make sense to me.
    George W and blargity like this.
  13. mjoo
    mjoo Senior Member
    1,159
    1,328
    Michigan
    No one said anything about ignoring the maintenance schedule. This was about cleaning the carbon deposits off of new plugs fouled by oil burning.
    I know a hot solution of oxiclean and oven cleaner make short work of carbon deposits and are harmless in a stainless steel EGR cooler. Not sure if those chemicals would corrode an iridium spark plug.
    blargity and Lightning Racer like this.
  14. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    You can get Denso filters on Rock Auto on the cheap. Denso filters are the ones they stick in the Toyota boxes at the dealer. OEM.
    VFerdman and blargity like this.
  15. Skibob
    2,912
    1,505
    Northern California
    When I need to get carbon off brass parts on my Coleman lanterns an overnight soak in Coca Cola does wonders. Never tried that method with different metals though.
    mjoo and blargity like this.
  16. oil_burner
    249
    126
    That's why I would use a copper tip, they're under $2 a plug and last for 20k miles. Irridium plugs are around $8-10 a piece and last 60k miles. Iridium tips are extremely brittle and thin as well, they're very easy to break when cleaning.
  17. blargity
    blargity New Member
    28
    TX
    Four Touring
    Good to know all this. So is oil burning something I might reasonably get fixed or is it just a fact of life and I need to keep a bit of spare oil on hand? I'm getting the impression from comments here that you just live with it. Not ideal but no biggie.
    I'm making a spreadsheet with parts list, btw. Already ordered the EPAuto air filters unfortunately... was like $16 for cabin+engine together. Maybe not as good as the Densos but with like 4.8 stars on Amazon after hundreds of reviews I assume they're good enough? I'll go head and order the Densos now if you guys think there's that big a difference in quality.
  18. VFerdman
    1,186
    1,215
    Oil usage is a fact of life on most cars with ICE. Some use more, some less, none use none. What is important for you now is to determine the rate at which YOUR car uses oil. I found it very helpful to use so-called high mileage oil. Oil that's marketed for high mile cars. Most manufacturers have something like that, but I use Mobil 1 full synthetic. I found my oil consumption was cut practically in half by switching to Mobil 1 oil for high mileage.
    Iridium plugs last well over 100K miles in these cars. I think the recommended replacement interval by Toyota is 120K (correct me if I am wrong). copper plugs last 4-5 times less and cost 2-3 times less. You do the math. If your car burns enough oil to foul spark plugs in less than 20K miles, spark plugs are the least of your concerns. You need a new engine.
    Here are the iridium plugs that are recommended by Toyota:
    Denso SKR11
    NGK IFR5T11
    Both brands are fine and I guess both can be found in new vehicles from the factory, but Denso is the manufacturer that produces much of Prius' components.
    srellim234 and blargity like this.
  19. blargity
    blargity New Member
    28
    TX
    Four Touring
    My 95 Civic uses pretty close to nothing... I get it changed every 5-6k miles with full synth and the dipstick is close to full and not all that dirty when I take it in. Really wishing the wife would just learn to drive stick right about now cause that car is a champ :)
    Just had the oil changed on the Prius unfortunately but I'll have them switch to high mileage oil next time if they haven't already. Already ordered the Denso Iridiums, should be here tomorrow. IMHO the cost difference between spark plugs is irrelevant compared to the hassle of tracking maintenance on them. 20k miles is only every couple years for me on average so no biggie, but if this next set lasts until I decide to sell (which I probably will by 250k) I'll be a very happy camper.
    How often should I be checking my oil levels? Weekly?
  20. Skibob
    2,912
    1,505
    Northern California
    No need if you already ordered them. Just keep it in mind for a future purchase.
