2nd Gen Project
Discussion in 'Gen 2 Prius Main Forum' started by donzoh1, May 13, 2020.
  1. donzoh1
    donzoh1 Active Member
    450
    153
    Lenexa, KS
    Most of my efforts have revolved around the ICE and I don't know how productive those efforts have been as the motor still will not crank. The only thing I've charged is the 12v.
    I'm guessing the P3000 is generic for HV battery problem. The question I have is whether balancing, charging, or replacing modules makes sense at this point.
  2. George W
    George W Senior Member
    939
    520
    San Antonio
    Does anyone know if warranties are transferable through Green Bean battery? Probably not since the car was known to have been idle all that time.
  3. AzusaPrius
    AzusaPrius Senior Member
    2,257
    945
    Yes it is but only once.
  4. richard203
    richard203 Member
    284
    61
    SF
    green bean warranty is xferable i got it on my prus
  5. donzoh1
    450
    153
    Lenexa, KS
    It can be transferred 1 time only and must be done online within 7 days of getting the car from the prior owner. Some documentation is required as well when registering. No mileage limit or time limit on warranty.
  6. BLNT
    BLNT Junior Member
    37
    Hungary
    Would you be interested to be on the PriusPodcast? I would love to hear your story and share your Prius project!
  7. donzoh1
    450
    153
    Lenexa, KS
    Yes, but I must say, so far, it's not quite ended happily. I'm quite stubborn so I'm likely to finish it. The last issue appears to be the HV battery and I'm trying to work around a low voltage condition. Battery may need to be reconditioned.
  8. donzoh1
    450
    153
    Lenexa, KS
    Does anybody live around KCMO that would charge and balance the modules from my Gen 2 pack? I would pay someone to do that. Or, I could ship them somewhere. I can get the pack out and remove them but I don't have a charger/balancer yet and I don't know what I'm doing in that part of the process. Or, what charger/discharger is recommended.
  9. donzoh1
    450
    153
    Lenexa, KS
    I'm not sure what a forced charge but I haven't charged the HV Pack.
  10. donzoh1
    450
    153
    Lenexa, KS
    This shows the suspect battery module indicated by Dr Prius. It still measured 1v or so but a couple of the plastic caps blew off, apparently due to overheating.
  11. ChapmanF
    19,027
    Good to know that all those expensive pressure relief valves leading into the collecting tubes and vented outside the car are being safely protected by the module tops blowing off first.
    2Fats and George W like this.
  12. donzoh1
    450
    153
    Lenexa, KS
    Also, the HV battery tray was bent upward in the middle on the passenger side/end. I could have bent this on removal but do not know for sure. This would significantly reduce the cooling airflow from the plastic duct...maybe by 20 percent. Its easy to see how this would bend, even during battery installation.
  13. 2Fats
    2Fats Member
    101
    61
    Missouri
    When would they have overheated?
    You haven't ran the car since replacing the engine, right?
  14. donzoh1
    450
    153
    Lenexa, KS
    I don't know when they overheated but I assume it was before I got the car. I don't know whether overheating could happen just by attempting to start the ICE when I heard only clicks from the HV pack. Maybe after the ICE failed, the battery overheated during the previous owner's attempt to get to the dealership? Maybe the car was limping along with one module near death for some time.
    2Fats likes this.
  15. BLNT
    BLNT Junior Member
    37
    Hungary
    Send an email to [email protected] when you feel like talking about it :)
