2ZR-FTXE Teaser Photos
Discussion in 'Gen 3 Prius Accessories and Modifications' started by josh2008, Apr 30, 2010.
  1. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    seawolf: doesn't the entire cars warranty get voided once you throw in a turbo?.... (duh, in a sense)
    i would assume the OP already thought about that.. after all, he is basically gutting the engine bay to install his own mods...
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Yea, talk about stating the obvious. I am glad he ignored my post. :rolleyes:
  3. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    It does seem odd to me that someone would buy a -prius- and then de-cat it? takes all sorts i suppose!
  4. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    I don't want you to think about I ignored your post, been trying to think of a proper response. No emissions laws here, only have 8yr/100k HV warranty. On another note, there will be no "gutting" of the engine bay. I'd *much* prefer this thread stay with a positive attitude/outlook, please.
  5. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    As long as you pass the state inspection, you should be ok.
    Do you have a dyno to verify the end result? To do a comparison, do you have the result prior to the turbo?
  6. josh2008
    365
    144
    Princeton, WV
    I am scheduled to make 6 pre-turbo dyno runs towards the end of this month. Once I put the turbo on and get it running correctly I will get some additional dyno time to see the effect the turbo will have on overall power output. I bracket race my Prius every Friday night so I will have plenty before and after timeslips as well.
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    FYI for others - boosted Atkinson cycle = Miller Cycle.
    Curious - how will you handle fuel enrichment if your goal is HP? Generally, the stock the Prius ECU strives to maintain stoichiometric 14.7:1 (proven on past dyno runs for Gen II, haven't seen it re-validated on Gen III, but nothing in Toyota's docs, NCF guides, etc, suggest that this has changed).
    Are you keeping the stock engine/internals, or going for a more 2ZR-FTE type approach (non-Atkinson, higher red-line, etc.)?
    If I ever had money burning a hole in my pocket for something like this, I'd be interested in a 5PSI boost more from an efficiency/economy gain perspective and thus wouldn't opt to gut cats or remove the exhaust-heat recovery if not required, though a cat-back exhaust would be a must.
    Why sacrifice emissions (laws or otherwise) for pure HP in a car that strives to be eco-friendly first and MPG friendly second? I could think of tons of other cars far more suited for this unless the shift-less nature of HSD is the sweet spot for your cause.
  8. a_gray_prius
    2,927
    783
    IL
    Want: pictures, video, timeslips.
  9. josh2008
    365
    144
    Princeton, WV
    Will be using stock internals. Going for quicker 0-60mph times and improved fuel economy. My reasoning for doing this is it's different and my racing already attracts a ton of interest from folks at the track. The way I see it is, anyone can build a Subaru WRX, however, it takes dedication and work to boost a Prius. How do you think the whole Honda/tuner scene got started?
  10. josh2008
    365
    144
    Princeton, WV
    You bet! :thumb:
  11. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    You have a valid point and worthy goal. You can claim the fastest Prius as well as the first gen3 turbo charged Prius.
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    How about an electric powered super charger? Turbos don't do well up here in the cold temps.
  13. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    now you need that carbon fiber hood.. ;)
  14. josh2008
    365
    144
    Princeton, WV
    **UPDATE** Held off on getting exhaust work performed this weekend, wanting to wait until after I go run on the dyno next weekend (next Saturday). My exhaust plans have changed, going to keep the cats and EHR mess (for now) and have 2.25" piping ran from the EHR back with no muffler other then the resonator in the EHR. The majority of the rest of the parts I need to complete the turbo build are currently on their way to me. So stay tuned, turbo Prius isn't very far away. :D
  15. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    Nice! I remember running T25 on my DSM then the Red on my Evo8...
    I only amused at the thought of boosting my prius...You take the cake!!!
  16. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
  17. MandiRocker
    MandiRocker Junior Member
    45
    WV
    Hhheeeyy....this looks like I have seen it before?.....I think I have driven it? :)
  18. josh2008
    365
    144
    Princeton, WV
    Turbo and turbo manifold have arrived. Waiting on t25 to t3 converter flange to arrive. Will post some pics tomorrow.
  19. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    I'm interested in your mod. Have you figured out how to reprogram the engine? If not how will you get the extra fuel fed?
    Thanks
  20. josh2008
    365
    144
    Princeton, WV
    Thanks for the interest. If the car won't compensate for extra airflow, will likely be using a SAFC or something similar and if neccesary use larger injectors.
